Halon Fire Extinguisher?
Old April 26th 04, 02:20 PM
O. Sami Saydjari
Default Halon Fire Extinguisher?
I just got my first issue of "Light Plane Maintenance" magazine.
I am really enjoying it. In their free book "40 Top Maintenance Tips"
(p27), they say "get the Halon extinguisher while they are still legal."
As I recall, there has been some issue that inhaling Halon can be pretty
bad for people's health. Why is a Halon fire extinguisher a great idea.
Also, this might sound dumb, but don't C02 extringuisher work by
depriving fires of 0xygen? It seems to me that in a small aircraft
cabin, one might also end up depriving the pilot and crew of oxygen as
well. Perhaps, one can survive long enough to put out the fire and then
open the air vents?!
Has anyone out there experienced an in-flight cabin fire that they put
out with an extinguisher? What was it like?
-Sami
N2057M, Piper Turbo Arrow III (being overhauled)
Old April 26th 04, 03:50 PM
Dale
Halon itself is non-toxic. When exposed to heat (as in a fire) some
byproducts are toxic. Also, a high concentration of Halon while not
toxic is not a survivable atmosphere. That being said, fire and fire
products are not survivable/toxic...and they also cause a lot of pain.
Use the extinguisher to put the fire out, it's the lesser of the evils.
Halon is a wonderful extinguishing agent in a confined space such as a
cockpit and it does no harm to electronics, avionics, etc.
Generally a handheld extinguisher doesn't contain enought CO2 to
incapacitate you before you can vent the cabin.
No inflight cabin fires, but I worked Crash Rescue for 20 years.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old April 26th 04, 04:15 PM
G.R. Patterson III
Inhaling the contents of just about any fire extinguisher can be pretty bad for your
health.
It doesn't damage mechanical, electrical, or electronic components of the aircraft.
This is why they also used to be common in computer rooms.
Perhaps so. The manufacturers are billing these as good substitutes for Halon in the
usual environments in which Halon is used on the ground.
Check the newsgroups archives for postings by Ron Natalie on this topic.
George Patterson
If you don't tell lies, you never have to remember what you said.
Old April 26th 04, 07:24 PM
Ben Jackson
Halon is a great alternative to water in indoor environments because
it's non-directional. You can't 'flood' a room with a conventional dry
fire extinguisher, but you CAN flood a room with halon. It's heavier
than air so it fills up the room and smothers the fire. That's the
reason I've been told it's dangerous to inhale -- it will sit in your
lungs.
I only deployed a dry extinguisher inside once (small grease fire) and
it was a god awful mess for only a few short bursts.
Ben Jackson
http://www.ben.com/
Old April 27th 04, 03:19 AM
Gerry Caron
"Ben Jackson" wrote in message
news:Ttcjc.25047$YP5.1970503@attbi_s02...
Sort of true, but sprinklers are quite capable of flooding a room with
water. The problem is water can cause as much or more damage than the fire
to a lot of expensive things. Then again, for people, being wet is
preferable to being burned.
It's heavier
lungs.
Yes and no. It is heavier than air, but it does disperse rapidly providing
a relatively constant concentration of Halon in a closed space. At "normal"
concentration levels, it's not hazardous. A properly sized Halon system
will provide a concentration of 6% to 7%. Three to 5% is all that's needed
for it to work. At those levels, there is more than enough oxygen to
breathe without any ill effects (ref: Boyle's Law). The only time there is
a potential problem is when the fire gets really hot before the Halon is
introduced. The high temps can break down the Halon creating some toxic
byproducts. I'd say it's much less of a danger than the smoke from the
fire.
Halon doesn't "smother" a fire. It breaks the chemical reaction. Think of
it as an anti-catalyst. Since it doesn't displace all the oxygen, people
can still breathe. I've been in a computer room that had a Halon system
when it was triggered. When it does, you're supposed to keep the doors
closed so that it can do its magic. The primary risks are 1) Noise - high
pressure gas venting thru little nozzles makes a horribly loud screeching
sound, 2) Limited short-term visibility - that rapidly expanding gas causes
a condensation cloud to form for a few seconds and people trying to move
quickly run into things, and 3) Debris flying everywhere - dirt and other
lightweight items pose a definite eye hazard.
Done that too. A good whiff that stuff will leave you gagging for hours.
I'll take Halon any day.
Gerry
Old April 27th 04, 03:03 PM
Stealth Pilot
On Mon, 26 Apr 2004 08:20:32 -0500, "O. Sami Saydjari"
-Sami
Halon is a banned substance. It is an ozone depleting chemical.
Old April 27th 04, 03:20 PM
G.R. Patterson III
In the Americas, only the manufacture is banned. There's a small industry recycling
the stuff from old systems, and extinguishers are still available and legal to own.
From what I've read, possession is banned in the EU.
George Patterson
Old April 28th 04, 04:56 PM
Ron Natalie
Thank you George.
Neither Halon nor CO2 work primarily by depriving the fire of oxygen. Halon works by
interfering with the chemical reaction of burning. It is effective at concentrations far below
that necessary to stop free burning by lack of oxygen.
CO2 and even water for that matter gets most of it's fire fighting affect from COOLING.
CO2 is frosty cold coming out of the extinguisher and does a pretty good job of it. Any
firefighter who's worked a reasonable size fire knows it the water absorbing the heat and
turning to steam that knocks down the fire.
Remember there are four things you have to have to have a fi
1. Fuel
2. Oxygen
3. Heat
4. Battalion Chief
Take away any one and you can't have a fire.
Old May 2nd 04, 05:01 PM
Jürgen Exner
legal."
Halon has been banned years ago because it is one of the worst chemicals
wrt. destroying the ozone layer.
pretty bad for people's health.
Not really. Halon is non-toxic.
great idea.
Because is it is non-toxic, very effective, non-corrosive, non-damaging,
doesn't leave a residue, and half a dozen other reasons.
Plus cooling the fire below the ingnition temperature.
well.
Only a concern for prolonged exposure.
then open the air vents?!
Normal ventilation would probably even be enough.
jue
Old May 3rd 04, 01:55 AM
G.R. Patterson III
George Patterson
My Engine Fire!! [email protected] Owning 1 March 31st 04 01:41 PM
Fire extinguisher question Kees Mies Owning 9 December 19th 03 10:12 PM
FA: halon fire ext system for homebuilts N329DF Home Built 0 August 16th 03 03:12 PM
FA: AIRCRAFT/RACE CAR HALON FIRE EXT SYSTEM N329DF Aviation Marketplace 0 August 16th 03 03:11 PM
hangar fire extinguisher [email protected] Owning 6 August 11th 03 01:01 AM
