ATC Altimeter Settings
Old April 11th 05, 03:38 PM
On Mon, 11 Apr 2005 09:27:37 -0400, "Icebound"
Time, arguably, has length. It is true that memory may be able to operate
only on the recent past time-span, and not on the long past time-span as
well ....but what is worse: even if it can operate on a long past time-span,
that operation may be innacurate.
There is no time in a any sense that can be expressed in length.
Time is only a word we use for measuring change.
Things just exist. Just becaause a rock in space has spun around
another rock n times does not imply some "length".
You are not older than you were 30 years ago. Your cellular structure
has simply changed.
  #82
Old April 11th 05, 08:07 PM
Icebound
*** A great civilization is not conquered from without until it
has destroyed itself from within. ***
- Ariel Durant 1898-1981
time-span,
has simply changed.
Time (sic) to re-requote one of the more astute observations in this
sub-thread:
"It is certainly longer than it needs to be, and a shorter thread would
have been better."
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
Altimeter experience HankC Piloting 2 July 25th 03 09:43 PM
