Sticky Altimeter
Old April 18th 05, 01:20 AM
Kyle Boatright
Default Sticky Altimeter
My altimeter "stuck" this afternoon when I was returning to my home field
from SnF. It seemed to work fine until the last 5 minutes of the trip - the
altitudes looked right, but as I descended towards pattern altitude, my eyes
told me that I was lower than the altimeter showed, so I tapped the
altimeter face and its reading dropped by about 1,000'. It stuck at that
position until I tapped it again after landing.
I'll check the static line going to it, but if that isn't the problem, is
there anything else I can do other than send it to a repair station?
Thanks in advance,
KB
Old April 18th 05, 01:37 AM
Jim Carriere
If it turns out your static line is clear, may the altimeter has an
electric vibrator? Some altimeters have these built in to make up
for friction in the gears.
I know, I'm leaving myself wide open with this one, please keep
humorous responses subtle enough to be family oriented
Old April 18th 05, 03:14 AM
Bill Daniels
"Jim Carriere" wrote in message
field
eyes
that
is
Sticky altimeters are a frequent problem in sailplanes. Silent
vibrationless flight just doesn't shake an instrument intended for a powered
aircraft enough. The tiny DC motors with an eccentric weights used as a
vibration source in pagers and cell phones can be taped to the altimeter and
activated with a push button switch.
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
