#11
wrote in message oups.com... Well, I removed the innards and (independently) reset the reference pointers to agree with the altitude hands at the correct Kollsman setting. (I'm pretty handy at tinkering with delicate instruments.) But I still don't really know what those little markers are for. If, as you have suggested, they are used to set the altimeter to the correct barometric pressure when the Kollsman window is blanked out, how does one know where to set the markers? Let's say one is in an area where the altitude-barometer combination there renders the Kollsman window useless. If one is given the barometric pressure there, one would then need a table or have to make a calculation to get the correct setting for the reference markers. Does this sound correct? Having read and re-read that article several times.... My latest take is that the correct position for them is zero zero, when the Kollsman window set at 29.92. From the article, they would appear to do nothing more than show the estimated "difference" (not the "pressure altitude" as I first surmised, but just the "difference").... the estimated difference between the *pressure* altitude of the airport in standard-atmosphere conditions, compared to the pressure altitude of the airport in the actual conditions of today. By setting them to show that *difference*, your altitude readout will now show the field elevation when you are on that field. Left of zero would be negative (pressure altitude is less than standard, i.e. actual pressure is higher than standard. Right of zero would be positive, air pressure is lower than standard. ) The article mentions to take care when setting negatives.... 900 would actually mean minus 100.... The only use of these markers would be if the station reported altimeter setting in terms of this "pressure altitude variation", as depicted in the diagram in the article. ( This seems to be something from a bygone era). You would set the appropriate difference on the markers ( in the appropriate plus or minus direction) and your altimeter would now be adjusted correctly..... Since pretty much everybody today reports the Kollsman value directly in "inches of mercury" (or Millibars in Europe), you do that directly with the Kollsman value, so the markers don't matter... you don't really care about the "difference" any more. So the only use today, would be... after setting the Kollsman window, you could check a table .... or make a mental estimate.... of what the difference should be ( about 100 feet per .10 inches of mercury away from 29.92).... Also, of course, that it is on the correct side of zero (left side (negative) if greater than 29.92, right side if less than 29.92).... and see that the markers correspond, as a double check. After moving the markers to zero zero at 29.92, then setting your correct altimeter setting, I would expect: If, like 29.82, the indicators should show about plus 100, 29.72: plus200, etc. If, like 30.02: minus 100, 30.12: minus 200 , etc. |
"Icebound" wrote in message ... .... 900 would actually mean minus 100.... .... but the "thousands" pointer would be slightly left of zero.... |
"Icebound" wrote: My latest take is that the correct position for them is zero zero, when the Kollsman window set at 29.92. That is correct. If they do not, then something is mechanically wrong within the instrument. |
Jon,
Well I have a pretty good jpeg of the altimeter, but can't find the email address for this group to post the pic to! Google says it's at the bottom of the groups "Home Page", but I don't see it? My groups tool (Netscape 7.0), using Google Groups, does not see alt.binaries.pictures.aviation so I can't post there either. If you send me your email address I'll send the pic to you. Or, if someone knows this group's email address, I'll post the altimeter pic for all to view. Dennis |
"Dave Butler" wrote in message
news:1120681100.317410@sj-nntpcache-5... wrote: [...] My groups tool (Netscape 7.0), using Google Groups, does not see alt.binaries.pictures.aviation so I can't post there either. If you send me your email address I'll send the pic to you. Or, if someone knows this group's email address, I'll post the altimeter pic for all to view. Newsgroups look like email, but they're not. Instead of using the browser part of your Netscape 7.0, use the "mail and newsgroups" part. It's the icon at the bottom left of your browser window that looks like a US mail envelope, or it's the part of netscape that you use to read email. Also, there are web services now available that will store files short-term for transfer to other parties. They aren't a perfect solution for all situations, and have no archive qualities (deletion of the files after a week is common), but for quickly and easily moving files from one person to another, they work fine. One such service is http://www.dropload.com For example, using the above service, upload the file, have notification sent to yourself, and post the link here. It's a much better solution than encoding binary files as text, even in a newsgroup set aside specifically for that purpose (the text encoding, used in email or in newsgroups, can add as much as 30% or so to the size of the data being moved around...and of course, in the case of newsgroups, that data gets copied to LOTS of places that will never actually use it). Pete |
Icebound,
Thanks for your interest and analysis. Allow me to digest it while I'm traveling for a couple days. BTW, a link to a pic of the altimeter should appear soon in this discussion thread so that others can see the "extra" reference markers the discussion centers on. Dennis |
To all: Dennis emailed me the picture of his altimeter to post to my website so that all can see it. http://www.AirplaneZone.com/PubDir/Alt_002.jpg (135 KB) David Odum - email: David at AirplaneZone dot com |
Just from looking at the picture, I'd say the third needle is for 10,000
feet increments. Look at how the labels line up when each pointer is in the 12:00 position... "David Odum" MyFirstName@AirplaneZone wrote in message ... To all: Dennis emailed me the picture of his altimeter to post to my website so that all can see it. http://www.AirplaneZone.com/PubDir/Alt_002.jpg (135 KB) David Odum - email: David at AirplaneZone dot com |
Here's a modern Falcon Gauge unit with the same markings...
http://www.falcongauge.com/images/pr...sitiveALT1.jpg "David Odum" MyFirstName@AirplaneZone wrote in message ... To all: Dennis emailed me the picture of his altimeter to post to my website so that all can see it. http://www.AirplaneZone.com/PubDir/Alt_002.jpg (135 KB) David Odum - email: David at AirplaneZone dot com |
| Thread Tools | |
| Display Modes | |
| Altimeter settings: QNH versus QFE | [email protected] | Soaring | 28 | June 6th 05 01:26 PM |
| ATC Altimeter Settings | O. Sami Saydjari | Instrument Flight Rules | 81 | April 11th 05 09:07 PM |
| Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 10:14 PM |
| Local altimeter at BFM | Dan Luke | Instrument Flight Rules | 3 | June 15th 04 03:01 PM |
| Why not use the F-22 to replace the F/A-18 and F-14? | Tony | Naval Aviation | 290 | March 7th 04 08:58 PM |
