Altimeter discrepancy
Old July 24th 05, 05:42 PM
Gene Whitt
Default Altimeter discrepancy
Y'all,
I have been flying in an aircraft where ATC has occasionally mentioned that
there is a 3-4 hundred discrepancy betwee our
communicated altitudes and that of our blind encoder. We have
acknowledged the difference.
The altimeters were certified some 300 miles away only three months ago.
ATC has accepted continuation of our flights using our indicated altitudes
not those of the blind encoder. The transponder altituded gives encoder
altitudes..
What do the FARs require?
What are the options?
What warranty on altimeter work and for how long?
Opinions wanted.
Gene Whitt
Old July 25th 05, 04:49 AM
Mike Rapoport
Why do you think that it is your altimeter? Does it match field elevation
with the current altimeter setting?
Mike
MU-2
"Gene Whitt" wrote in message
k.net...
Y'all,
that there is a 3-4 hundred discrepancy betwee our
altitudes..
Opinions wanted.
Gene Whitt
Old July 25th 05, 03:40 PM
Gene Whitt
Mike,
Thanks for the reminder...
Fortunately everything is still under new aircraft warranty. Will check
papers to see kind of blind encoder feeding the transponder.
Gene
"Mike Rapoport" wrote in message
nk.net...
Mike
MU-2
k.net...
Y'all,
altitudes not those of the blind encoder. The transponder altituded
gives encoder altitudes..
Opinions wanted.
Gene Whitt
Old July 25th 05, 06:58 PM
Peter R.
Last May I had my altimeter and encoder certified as part of the two-year
requirement. During a flight soon after, I was told by ATC that our
transponder-sent altitude was off about 400 feet when compared to the
altimeter.
After pointing this out to the shop who certified the aircraft, they
discovered that their altimeter that they use to certify aircraft had a 400
foot error in it. Nice...
Peter
----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Old July 25th 05, 08:23 PM
Victor J. Osborne, Jr.
The Octal (Base 8) sections of the xponder could be out of alignment and
therefore output off by the 3-400 ft. you mention. It c/b on their end
although, I only remember "not receiving you mode C."
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
k.net...
Y'all,
altitudes..
Opinions wanted.
Gene Whitt
Old July 25th 05, 08:37 PM
Roy Smith
Peter R. wrote: After pointing this out to
the shop who certified the aircraft, they discovered that their
altimeter that they use to certify aircraft had a 400 foot error
I assume test equipment like this needs to be calibrated against some
NBS-traceable standard on some periodic basis?
Old August 1st 05, 07:11 PM
three-eight-hotel
I received an ATC notification during one flight that my altimeter was
1000' off. They actually had me turn off the altitude encoding.
This, by the way, occured shortly after having my plane in to the
avionics shop for some repairs. Turned out, when they put one of the
instruments back in the panel, they introduced a kink in the static
line. I replaced the kinked section with a new hose and everything
worked fine...
ATC Altimeter Settings O. Sami Saydjari Instrument Flight Rules 81 April 11th 05 08:07 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Local altimeter at BFM Dan Luke Instrument Flight Rules 3 June 15th 04 02:01 PM
Why not use the F-22 to replace the F/A-18 and F-14? Tony Naval Aviation 290 March 7th 04 07:58 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
