Richard Lamb wrote:
If you can find the engine performance plots you will see that the percent of RPM and percent of power (HP or torque) are not at all the same thing. And it's torque that turns the propeller (not RPM). 1000 rpm might be near 1/2 RPM, but barely 10-20 percent max torque. At full power (torque), the prop can deliver x number of pounds thrust for any given airspeed. That's the most you'll get. Rolling off RPM also rolls one down the torque curve. And you are right, it's a very non-linear curve. Richard ps: also on the torque curve, note that max torque and max HP are usually NOT found at the same RPM... ta It's been a while since I saw so many errors in so little text. Matt |
Matt Whiting wrote:
Richard Lamb wrote: If you can find the engine performance plots you will see that the percent of RPM and percent of power (HP or torque) are not at all the same thing. And it's torque that turns the propeller (not RPM). 1000 rpm might be near 1/2 RPM, but barely 10-20 percent max torque. At full power (torque), the prop can deliver x number of pounds thrust for any given airspeed. That's the most you'll get. Rolling off RPM also rolls one down the torque curve. And you are right, it's a very non-linear curve. Richard ps: also on the torque curve, note that max torque and max HP are usually NOT found at the same RPM... ta It's been a while since I saw so many errors in so little text. Matt That RPM and torque are NOT the same thing? Or that at full power will give deliver full thrust? Ot that the thrust delivered changes with airspeed? Or that it's very non linear? Very oversimplified, but go ahead and straighten me out, Matt. Richard |
Richard Lamb wrote:
Matt Whiting wrote: Richard Lamb wrote: If you can find the engine performance plots you will see that the percent of RPM and percent of power (HP or torque) are not at all the same thing. And it's torque that turns the propeller (not RPM). 1000 rpm might be near 1/2 RPM, but barely 10-20 percent max torque. At full power (torque), the prop can deliver x number of pounds thrust for any given airspeed. That's the most you'll get. Rolling off RPM also rolls one down the torque curve. And you are right, it's a very non-linear curve. Richard ps: also on the torque curve, note that max torque and max HP are usually NOT found at the same RPM... ta It's been a while since I saw so many errors in so little text. Matt That RPM and torque are NOT the same thing? Or that at full power will give deliver full thrust? Ot that the thrust delivered changes with airspeed? Or that it's very non linear? Very oversimplified, but go ahead and straighten me out, Matt. Richard Yes, horsepower and torque are absolutely not the same thing. The following suggests that they are "At full power (torque)..." Rolling off RPM may or may not roll you down the torque curve. If you are running at an RPM above the torque peak, reducing RPM might actually increase the torque available. 1000 RPM isn't 1/2 RPM. It may be close to 1/2 of the maximum allowable RPM, which is what you hopefully intended to say. Matt |
Do you really think including factual data is likely to resolve the
question? And do you know Dr Dan? |
Thrust is a direct relation of diameter x pitch x rpm.
Get a copy of H.Glauert's book: The elements of aerofoil and airscrew theory. isbn 052127494 Also, thrust is a function of the third power of the prop diameter so changing the prop diameter on inch can have a major effect on thrust and vice versa. |
I believe
there is more to it than just VE. I don't believe that bearing friction is linear with RPM for example. Also, speed of the flame front becomes and issue at higher RPM. I believe the drop-off in torque with RPM is a function of a number of factors. Yup you're right, there's more than just volumetric efficiency, but flame front speed in these slow engines is still around 100 feet per second, while average piston speed won't be much over 40 or 50 fps with the midpoint travel being somewhat higher. The intake and exhaust systems present more drag at higher RPMs and start to affect the performance, and in many modern auto engines four valves per cylinder are used to ease breathing. I wonder if the new direct-drive diesel aircraft engines have much higher torques in the right places? Dan |
![]() wrote I wonder if the new direct-drive diesel aircraft engines have much higher torques in the right places? Torque out the butt, and the torque stays high for a longer period of time on the power stroke. In short, it will turn the same size prop of an engine with nearly twice the HP. -- Jim in NC |
On Tue, 17 Jan 2006 22:48:09 -0800, "skyloon"
wrote: Kershner states that the maximum thrust force occurs when the plane is standing still (at a fixed throttle setting, I guess), and decreases as you go faster. I do not understand this. Is it beacese AOA is largest? I am trying to see how this relates to power. Power would be force*distance/time or force*velocity. Maybe the thrust decreases slowly with airspeed, but the power still goes up as you go faster. This is just a hand waving argument. Please, anyone who knows more, feel free to correct this picture. Dave I'll pick up on this one. There's a mechanics equation which is specially straight-forward. It says if you apply a constant force to an object, and it moves in the direction of the force, then the work done is the product of force times distance. As expressed in the SI system, it's specially simple: F X D = W gets the units of F in Newtons times Distance in Meters equals work in joules Even more interesting: F X V = P force times speed = power. In SI units again: force in Newtons times speed in meters per second = power in Watts OK that was the engineering/physics. Now the application: An airplane with a constant power recip prop engine. Lets say the engine is putting out 90 HP say a C-152 90 HP = 90 X 746 watts = 67kW Lets check the numbers at 10 mph, 50 mph and 100 mph 10 mph = 4.5 meters/sec 50 mph = 22.4 meters/sec 100 mph = 44.7 meters/sec The unknown in the following equation is F F X V = P or F = P/V Now force is the same measure as thrust, so now we can check available thust at these three speeds: 10 mph F = 67000 W/4.5 M/Sec = 14890 Newtons A newton, like a small apple weighs a quarter pound about. So 14890 Newtons = 3340 pound That's a lot of thrust! Now 50 mph F = 67000/22.4 = 2990 Newtons or 671 lb. Now 100 mph F = 67000/44.7 = 1500 Newtons or 336 lb. Or the general rule: the faster you go with constant power, the less the thrust available. Same applies to boats. But think about planes with (some) jet engines, these can be constant THRUST. That means, the faster they go, the more HP they put out! (A reason why jets on slow planes is not a great idea) Brian Whatcott Altus OK |
Why does a prop ice up so apparently readily? | Brian Whatcott | General Aviation | 2 | November 9th 05 12:02 AM |
Why does a prop ice up so apparently readily? | Brian Whatcott | Piloting | 2 | November 9th 05 12:02 AM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Piloting | 2 | November 8th 05 02:52 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Instrument Flight Rules | 2 | November 8th 05 02:52 PM |
Sensenich Wood Prop Question | [email protected] | Owning | 3 | April 4th 05 02:32 PM |
