prop rpm question
Old January 18th 06, 01:58 AM posted to rec.aviation.misc,rec.aviation.piloting
Default prop rpm question
Uh, thanks for trying...I guess:
DC "Bob Fry" wrote in message
DC ...
At 1000 rpm or so, my airplane will taxi and get up to, what,
15-20 kts? But at double the rpm it will fly at 80-90 kts,
though it would take a long time to take off. Surely double
the rpm produces more than double the propellor thrust...or
does it? Anyway, it seems very nonlinear, that is, double the
rpm and I get much more than double the performance. Why is
that?
DC The laws of physics (certainly those relating to mechanics -
DC velocity, acceleration, thrust, drag and all that) are rarely
DC linear.
Eh? F=ma and many others are.
DC On the ground your aircraft is probably not in an
DC optimum attitude for drag reduction, so it's probably not fair
DC to compare it with an aircraft in the sky. And will your
DC aircraft fly straight and level at 1000rpm? If so, how fast?
Kee-rist. Drag, and attitude (angle of attack, really) have little to
do with the explanation I was looking for. No, of course it won't fly
straight and level at 1000 rpm. That's nearly full idle landing rpm.
DC The main thing dictating how your aircraft performs is
DC drag. "Normal" drag increases with the square of the speed you
DC fly at
I think you mean parasitic drag.
DC - so if you double the speed, you roughly quadruple the
DC drag (hence everything has a terminal velocity when falling to
DC earth - as you get faster, the drag increases faster than your
DC speed increases, and you stop accelerating once drag equals
DC the acceleration caused by gravity). Remember also that at low
DC speeds you have induced drag, which is high at low speeds but
DC vanishes as you get faster.
Induced drag--drag caused by the wing producing lift at a vector not
perpendicular to flight--never vanishes unless lift vanishes.
Anyway I'll restate the question, plus post to r.a.'s garbage heap,
r.a.piloting.
At 1000 rpm the prop produces some amount of thrust (lift), call it
T[1000]. This thrust is only enough to move the plane in a moderate
taxi.
At double that rpm, 2000 rpm, the prop produces another amount of
thrust, call it T[2000]. Now I'm not positive, but it sure seems that
T[2000] T[1000]
Why, if rpm only doubles, does thrust (seem to) much more than double?
Old January 18th 06, 02:32 AM posted to rec.aviation.misc,rec.aviation.piloting
snip
r.a.piloting.
taxi.
T[2000] T[1000]
The short way around is to look at your engine's power chart and evaluate
how many excess HP it is developing at 1000 rpm vs 2,000 rpm.
If we assume the plane in question is a C-152, the engine is making very
little power at 1,000 rpm. I'd guess 15 hp, of which at least 5 hp is spent
in friction inside the engine, leaving 10 hp for thrust. At 2,000 rpm, the
engine is probably making 60 hp, of which 10 is spent on internal friction.
Therefore, you have 50 hp for thrust.
Another way to look at it is that your prop has an advance rate. Let's say
it the advance rate is 4 feet per revolution. At 1,000 rpm, and no drag on
the airplane (rolling or aerodynamic), the airplane would have a terminal
velocity of 4,000 fpm, or about 48 mph. Of course, there is rolling and
aerodynamic drag, and there is prop drag too, so the engine can only drag
the plane along at, say, 30 mph, assuming a flat smooth runway.
At 2,000 rpm, with no drag, the terminal velocity would be 8,000 fpm, or
about 85 mph. Of course, there is still aerodynamic and prop drag, but there
is no rolling resistance, so you get more bang for your RPM buck. Of course,
it helps that your engine is delivering 60 hp, as opposed to 15 hp when it
turns 1,000 rpm.
Yet another way to look at it is that when your prop spins at 2x the speed,
it requires 4x the power to turn it... KE=1/2MV^2..
And yes, all of this stuff is ideal world, no prop efficiency losses, etc...
KB
KB
Old January 18th 06, 05:07 AM posted to rec.aviation.misc,rec.aviation.piloting
I wish to leave the engine out of the discussion, but let's
continue...
"KB" == Kyle Boatright writes:
KB If we assume the plane in question is a C-152,
Close enough, it's an Aircoupe with a C90.
But let's look just at the prop. Why does a prop produce so much more
thrust, much more than double, when it's turned at only twice the
rate?
KB Another way to look at it is that your prop has an advance
KB rate. Let's say it the advance rate is 4 feet per
KB revolution.
Yep, 48" pitch.
KB At 1,000 rpm, and no drag on the airplane (rolling
KB or aerodynamic), the airplane would have a terminal velocity
KB of 4,000 fpm, or about 48 mph. Of course, there is rolling and
KB aerodynamic drag, and there is prop drag too, so the engine
KB can only drag the plane along at, say, 30 mph, assuming a flat
KB smooth runway.
KB At 2,000 rpm, with no drag, the terminal velocity would be
KB 8,000 fpm, or about 85 mph.
Hmmmm...so prop thrust is indeed only twice at double the
rpm?...ideally speaking of course.
The idealized (no viscosity etc.) math seems to say that it is linear,
but intuitive feel says not.
Old January 18th 06, 06:48 AM posted to rec.aviation.misc,rec.aviation.piloting
This won't be a complete ( or maybe even correct answer) but ...
The prop is an airfoil. Here *lift* will be *thrust*. The thrust force
generated will be
T = C A d/2 V^2. V is the speed of the airfoil (prop). So the force is
nonlinear, it goes as the square.
For the rest of the parameters: C is coeff of lift (depends on angle of
attack), A is airfoil area, d= air density.
The prop will have induced and parasitic drag. The relative wind angle of
attack on the prop foil will depend on the aircraft speed. At low speed it
is at high angle of attack. The induced drag is large and the engine can't
get up to full rpm. As the aircraft speed increases, the AOA decreases, the
induced drag decreases and the can rev up to higher rpm (as constnt
throttle). There will be an AOA where the drag is minimum, This is where the
prop is most efficient. It is a narrow range, because, as you go faster,
parasitic drag on the prop kicks in. Constant speed props are used to adjust
the pitch to remian efficient over a wider raneg of airspeeds.
Kershner states that the maximum thrust force occurs when the plane is
standing still (at a fixed throttle setting, I guess), and decreases as you
go faster. I do not understand this. Is it beacese AOA is largest? I am
trying to see how this relates to power. Power would be force*distance/time
or force*velocity. Maybe the thrust decreases slowly with airspeed, but the
power still goes up as you go faster.
This is just a hand waving argument. Please, anyone who knows more, feel
free to correct this picture.
Dave
continue...
rate?
KB revolution.
Yep, 48" pitch.
KB smooth runway.
Old January 18th 06, 03:30 PM posted to rec.aviation.misc,rec.aviation.piloting
go faster.
There are some fast homebuilts for which this won't be true.
They have fixed-pitch props with very high pitches, and the blade is
largely stalled at the start of the takeoff roll, making accelleration
dismal indeed. The pilots report that the airplane seems to come alive
at some point before liftoff when the prop blades finally get to work.
My own Jodel has an efficient wooden prop and I often note a small RPM
drop as the airplane accellerates through about 20 MPH. There's
something happening with the airflow through the blades, probably to do
with unstalling, or, perhaps (less likely) with leaving behind the
larger prop vortex generated in the static condition.
Dan
Old January 18th 06, 08:27 PM posted to rec.aviation.misc,rec.aviation.piloting
If you can find the engine performance plots you will see that the
percent of RPM and percent of power (HP or torque) are not at all
the same thing.
And it's torque that turns the propeller (not RPM).
1000 rpm might be near 1/2 RPM, but barely 10-20 percent max torque.
At full power (torque), the prop can deliver x number of pounds
thrust for any given airspeed. That's the most you'll get.
Rolling off RPM also rolls one down the torque curve.
And you are right, it's a very non-linear curve.
Richard
ps:
also on the torque curve, note that max torque and max HP are usually
NOT found at the same RPM...
ta
Old January 22nd 06, 08:18 PM posted to rec.aviation.misc,rec.aviation.piloting
On Tue, 17 Jan 2006 22:48:09 -0800, "skyloon"
Dave
I'll pick up on this one. There's a mechanics equation which is
specially straight-forward. It says if you apply a constant force to
an object,
and it moves in the direction of the force, then the work done is the
product of force times distance.
As expressed in the SI system, it's specially simple: F X D = W
gets the units of
F in Newtons times Distance in Meters equals work in joules
Even more interesting: F X V = P
force times speed = power.
In SI units again:
force in Newtons times speed in meters per second = power in Watts
OK that was the engineering/physics.
Now the application:
An airplane with a constant power recip prop engine.
Lets say the engine is putting out 90 HP say a C-152
90 HP = 90 X 746 watts = 67kW
Lets check the numbers at 10 mph, 50 mph and 100 mph
10 mph = 4.5 meters/sec
50 mph = 22.4 meters/sec
100 mph = 44.7 meters/sec
The unknown in the following equation is F
F X V = P or F = P/V
Now force is the same measure as thrust, so now we can
check available thust at these three speeds:
10 mph
F = 67000 W/4.5 M/Sec = 14890 Newtons
A newton, like a small apple weighs a quarter pound about.
So 14890 Newtons = 3340 pound That's a lot of thrust!
Now 50 mph
F = 67000/22.4 = 2990 Newtons or 671 lb.
Now 100 mph
F = 67000/44.7 = 1500 Newtons or 336 lb.
Or the general rule: the faster you go with constant power, the less
the thrust available.
Same applies to boats.
But think about planes with (some) jet engines,
these can be constant THRUST.
That means, the faster they go, the more HP they put out!
(A reason why jets on slow planes is not a great idea)
Brian Whatcott Altus OK
Old January 24th 06, 10:48 PM posted to rec.aviation.misc,rec.aviation.piloting
On Sun, 22 Jan 2006 at 20:18:32 in message
, Brian Whatcott
No, is not quite that easy. Another way of looking at force is that it
is rate of change of momentum.
In a simplified way the thrust of a jet engine comes from the change of
momentum from the air captured by the engine to the momentum of the air
that leaves the back of the engine. If you think of a Turbofan engine
then the fan is not so different from a propeller. The internal
efficiency of the two types of engine is somewhat different.
In any case the greatest propulsive efficiency comes from a momentum
change of a large mass of air with a very small velocity change.
David CL Francis
Old January 18th 06, 12:07 PM posted to rec.aviation.misc,rec.aviation.piloting
continue...
rate?
KB revolution.
Yep, 48" pitch.
KB smooth runway.
The thrust is probably 4x, like the engine's power. The advance rate makes
the prop want to pull the airplane at 2x the speed, but again, 2x the speed
requires 4x the power...
Old January 18th 06, 01:16 PM posted to rec.aviation.misc,rec.aviation.piloting
: The thrust is probably 4x, like the engine's power. The advance rate makes
: the prop want to pull the airplane at 2x the speed, but again, 2x the speed
: requires 4x the power...
Check your equations. Drag force goes with the square of the velocity.
Drag power (force*velocity) therefore goes with the *cube* of velocity. So, if that's
the governing equation, 2x the speed requires 8x the power.
If you look at the operator handbooks for identical airframes with different
engine options (e.g. PA28-140/150/160/180/235, PA24-180/250/260/400), you'll see that
they almost exactly follow this cubic (i.e. cube-root) equation.
-Cory
* Cory Papenfuss *
Why does a prop ice up so apparently readily? Brian Whatcott General Aviation 2 November 9th 05 12:02 AM
Why does a prop ice up so apparently readily? Brian Whatcott Piloting 2 November 9th 05 12:02 AM
Why does a prop ice up so apparently readily? Mike Rapoport Piloting 2 November 8th 05 02:52 PM
Why does a prop ice up so apparently readily? Mike Rapoport Instrument Flight Rules 2 November 8th 05 02:52 PM
Sensenich Wood Prop Question [email protected] Owning 3 April 4th 05 02:32 PM
