Tower to tower
Old March 2nd 06, 09:44 AM posted to rec.aviation.piloting
Default Tower to tower
SVFR does not allow flight into IMC , just VFR as though the
Class B-E was G airspace. SVFR would interfere with IFR and
is only allowed when there is no IFR traffic conflict.
IFR clearances that stay within the airspace controlled by
the tower [including TRACON] are available for such purposes
as local IFR training and may be issued for enroute if the
airspace letters of agreement between adjoining towers does
not require Center airspace.
To learn about your local IFR options, visit the tower and
ask.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Montblack" wrote in
message ...
| ("keepitrunning" wrote)
| A friend of mine who is IFR rated said there used to be
a term called
| tower to tower to allow for an IFR clearance from one
towered airport to
| another. This type of clearance wasn't as complicated as
a full blown
| clearance. He thought that the name had been changed or
that it was now
| called something else. I googled some but could not
find any reference
| and not being IFR myself have no clue.
| Not IFR but how about ...Special VFR Clearance?
| When normal VFR flight wouldn't be advised, a tower can
give you Special VFR
| Clearance to get over to another field, next door. That's
how it was
| explained to me.
| Is this what you're thinking about?
| Montblack
Old March 2nd 06, 11:16 AM posted to rec.aviation.piloting
It will only be available where the tower controlled areas
abut, or in some established routes where a letter of
agreement between Center and the towers has been signed when
Center gives control to their airspace below a certain
altitude.
http://www.faa.gov/ats/aglzob/Lesson...0Control.ppt#1
"Morgans" wrote in message
| "Dan" wrote in message
| Does anyone know if this is avaliable in the Phoenix
area?
| Good question, but let's take it one further. How does
one find out about
| such arrangements, anywhere-other than knowing the local
tower?
| Jim in NC
Old March 2nd 06, 01:01 PM posted to rec.aviation.piloting
When I subscribed to Jeppesen stuff there was informations about it it
in the front of the book.
Does anyone know if this is avaliable in the Phoenix area?
Good question, but let's take it one further. How does one find out about
such arrangements, anywhere-other than knowing the local tower?
Old March 2nd 06, 02:18 PM posted to rec.aviation.piloting
AFD
Either that, or FDC Notams?
Old March 2nd 06, 04:39 PM posted to rec.aviation.piloting
"Jon Woellhaf" wrote in message
According to the Pilot/Controller Glossary,
TOWER EN ROUTE CONTROL SERVICE - The control of IFR en route traffic
within delegated airspace between two or more adjacent approach control
facilities. This service is designed to expedite traffic and reduce
control and pilot communication requirements.
TOWER TO TOWER-
(See TOWER EN ROUTE CONTROL SERVICE.)
Also see AIM 4-1-18
/excerpt
4-1-18. Tower En Route Control (TEC)
a. TEC is an ATC program to provide a service to
aircraft proceeding to and from metropolitan areas. It
links designated Approach Control Areas by a
network of identified routes made up of the existing
airway structure of the National Airspace System.
The FAA initiated an expanded TEC program to
include as many facilities as possible. The program’s
intent is to provide an overflow resource in the low
altitude system which would enhance ATC services.
A few facilities have historically allowed turbojets to
proceed between certain city pairs, such as
Milwaukee and Chicago, via tower en route and these
locations may continue this service. However, the
expanded TEC program will be applied, generally,
for nonturbojet aircraft operating at and below
10,000 feet. The program is entirely within the
approach control airspace of multiple terminal
facilities. Essentially, it is for relatively short flights.
Participating pilots are encouraged to use TEC for
flights of two hours duration or less. If longer flights
are planned, extensive coordination may be required
within the multiple complex which could result in
unanticipated delays.
b. Pilots requesting TEC are subject to the same
delay factor at the destination airport as other aircraft
in the ATC system. In addition, departure and en route
delays may occur depending upon individual facility
workload. When a major metropolitan airport is
incurring significant delays, pilots in the TEC
program may want to consider an alternative airport
experiencing no delay.
c. There are no unique requirements upon pilots to
use the TEC program. Normal flight plan filing
procedures will ensure proper flight plan processing.
Pilots should include the acronym “TEC” in the
remarks section of the flight plan when requesting
tower en route control.
d. All approach controls in the system may not
operate up to the maximum TEC altitude of
10,000 feet. IFR flight may be planned to any
satellite airport in proximity to the major primary
airport via the same routing.
/end
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old March 2nd 06, 09:21 PM posted to rec.aviation.piloting
Sorry, I intended to say, it is an FAA training PowerPoint
presentation. If you don't have OFFICE, you can get the
free PowerPoint viewer from
http://www.microsoft.com/downloads/d...displaylang=en
or
http://office.microsoft.com/en-us/of...e/default.aspx
| "Jim Macklin" wrote
in message
| news:utANf.109292$QW2.67315@dukeread08...
areas
when
| altitude.
| What type of file is this, or what program opens this
file?
| Jim in NC
Old March 2nd 06, 09:31 PM posted to rec.aviation.piloting
But for a pilot it means you don't need to pre-file. Know that is there
is nice.
-Robert
Old March 2nd 06, 10:08 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
altitude.
What type of file is this, or what program opens this file?
Jim in NC
Old March 2nd 06, 11:29 PM posted to rec.aviation.piloting
keepitrunning wrote:
This is my first post to this rec.aviation.piloting so forgive me if this
has been discussed before.
A friend of mine who is IFR rated said there used to be a term called tower
to tower to allow for an IFR clearance from one towered airport to another.
This type of clearance wasn't as complicated as a full blown clearance. He
thought that the name had been changed or that it was now called something
else. I googled some but could not find any reference and not being IFR
Tower Enroute Clearance. There's essentially two flavors of this.
In California it is as you describe. They have special TEC routes
published.
In the northeast the publications call it Tower Enroute, but essentially
it's just the routling you get at low levels in the overlapping airspaces.
Old March 6th 06, 03:09 PM posted to rec.aviation.piloting
is nice.
Tower Enroute Control changes nothing in regard to filing flight plans.
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
some funny (but scary) stuff... Mike W. Piloting 18 February 4th 05 09:55 AM
Tower Enroute Control? Sam Jones Instrument Flight Rules 5 June 2nd 04 02:31 AM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
New Oshkosh Tower Jay Honeck Piloting 20 November 25th 03 05:35 PM
