Tower to tower
Old March 2nd 06, 03:47 AM posted to rec.aviation.piloting
Default Tower to tower
This is my first post to this rec.aviation.piloting so forgive me if this
has been discussed before.
A friend of mine who is IFR rated said there used to be a term called tower
to tower to allow for an IFR clearance from one towered airport to another.
This type of clearance wasn't as complicated as a full blown clearance. He
thought that the name had been changed or that it was now called something
else. I googled some but could not find any reference and not being IFR
myself have no clue.
Any comments are appreciated.
Old March 2nd 06, 04:09 AM posted to rec.aviation.piloting
("keepitrunning" wrote)
tower to tower to allow for an IFR clearance from one towered airport to
another. This type of clearance wasn't as complicated as a full blown
clearance. He thought that the name had been changed or that it was now
called something else. I googled some but could not find any reference
and not being IFR myself have no clue.
Not IFR but how about ...Special VFR Clearance?
When normal VFR flight wouldn't be advised, a tower can give you Special VFR
Clearance to get over to another field, next door. That's how it was
explained to me.
Is this what you're thinking about?
Montblack
Old March 2nd 06, 09:44 AM posted to rec.aviation.piloting
SVFR does not allow flight into IMC , just VFR as though the
Class B-E was G airspace. SVFR would interfere with IFR and
is only allowed when there is no IFR traffic conflict.
IFR clearances that stay within the airspace controlled by
the tower [including TRACON] are available for such purposes
as local IFR training and may be issued for enroute if the
airspace letters of agreement between adjoining towers does
not require Center airspace.
To learn about your local IFR options, visit the tower and
ask.
James H. Macklin
ATP,CFI,A&P
some support
"Montblack" wrote in
message ...
a term called
towered airport to
a full blown
that it was now
find any reference
how it was
| explained to me.
| Montblack
Old March 7th 06, 03:27 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
news:w8zNf.108917$QW2.10563@dukeread08...
SVFR operations are not prohibited when IFR aircraft are present. If the
SVFR and IFR aircraft can be provided with approved separation and if
arriving and departing IFR aircraft are not delayed then SVFR operations may
be conducted.
Old March 7th 06, 08:10 PM posted to rec.aviation.piloting
see the word "conflict" in the dictionary.
"Steven P. McNicoll" wrote in
message
nk.net...
| "Jim Macklin" wrote
in message
and
present. If the
separation and if
SVFR operations may
| be conducted.
Old March 7th 06, 08:17 PM posted to rec.aviation.piloting
news:HOlPf.116146$QW2.52213@dukeread08...
You're welcome.
Old March 2nd 06, 04:19 AM posted to rec.aviation.piloting
According to the Pilot/Controller Glossary,
TOWER EN ROUTE CONTROL SERVICE - The control of IFR en route traffic within
delegated airspace between two or more adjacent approach control facilities.
This service is designed to expedite traffic and reduce control and pilot
communication requirements.
TOWER TO TOWER-
(See TOWER EN ROUTE CONTROL SERVICE.)
"keepitrunning" wrote in message
. com...
Old March 2nd 06, 04:39 PM posted to rec.aviation.piloting
"Jon Woellhaf" wrote in message
within delegated airspace between two or more adjacent approach control
facilities. This service is designed to expedite traffic and reduce
control and pilot communication requirements.
TOWER TO TOWER-
Also see AIM 4-1-18
/excerpt
4-1-18. Tower En Route Control (TEC)
a. TEC is an ATC program to provide a service to
aircraft proceeding to and from metropolitan areas. It
links designated Approach Control Areas by a
network of identified routes made up of the existing
airway structure of the National Airspace System.
The FAA initiated an expanded TEC program to
include as many facilities as possible. The program’s
intent is to provide an overflow resource in the low
altitude system which would enhance ATC services.
A few facilities have historically allowed turbojets to
proceed between certain city pairs, such as
Milwaukee and Chicago, via tower en route and these
locations may continue this service. However, the
expanded TEC program will be applied, generally,
for nonturbojet aircraft operating at and below
10,000 feet. The program is entirely within the
approach control airspace of multiple terminal
facilities. Essentially, it is for relatively short flights.
Participating pilots are encouraged to use TEC for
flights of two hours duration or less. If longer flights
are planned, extensive coordination may be required
within the multiple complex which could result in
unanticipated delays.
b. Pilots requesting TEC are subject to the same
delay factor at the destination airport as other aircraft
in the ATC system. In addition, departure and en route
delays may occur depending upon individual facility
workload. When a major metropolitan airport is
incurring significant delays, pilots in the TEC
program may want to consider an alternative airport
experiencing no delay.
c. There are no unique requirements upon pilots to
use the TEC program. Normal flight plan filing
procedures will ensure proper flight plan processing.
Pilots should include the acronym “TEC” in the
remarks section of the flight plan when requesting
tower en route control.
d. All approach controls in the system may not
operate up to the maximum TEC altitude of
10,000 feet. IFR flight may be planned to any
satellite airport in proximity to the major primary
airport via the same routing.
/end
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
Old March 2nd 06, 05:11 AM posted to rec.aviation.piloting
We still have it. Its a prearranged agreement between local airports
how they will route IFR traffic. The cool part for a pilot is you don't
need to prefile an IFR flight plan. When you call ground you just ask
for a "tower enroute" to your destination. Works great for local IFR
trips.
-Robert
Old March 2nd 06, 05:18 AM posted to rec.aviation.piloting
Does anyone know if this is avaliable in the Phoenix area?
--Dan
Los Angeles radio tower crash kills 2 Paul Hirose Piloting 178 August 6th 05 03:46 PM
some funny (but scary) stuff... Mike W. Piloting 18 February 4th 05 09:55 AM
Tower Enroute Control? Sam Jones Instrument Flight Rules 5 June 2nd 04 02:31 AM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
New Oshkosh Tower Jay Honeck Piloting 20 November 25th 03 05:35 PM
