adhesive
Old August 20th 06, 05:09 AM posted to rec.aviation.piloting
Default adhesive
After years of looking, I recently obtained a pair of the old Piper
Cherokee logos from the center of the old style bow tie yokes. They
are in fine condition and really jazz up the cockpit
I am unsure of what to use to mount them in the semicircular recess in
the yoke. I would not want to use an adhesive that will react in some
way with the "plastic" yoke and weaken them. There is already a
recurrent AD to check these yokes for cracks, so these pot metal
emblems will need to be removed from time to time for inspection.
Bruce McFadden Birmingham, AL
PA32-260
Old August 20th 06, 05:46 AM posted to rec.aviation.piloting
Jim Macklin
Default adhesive
Hot melt glue should be OK, just a couple of small spots at
the tips and center.
old Piper
yokes. They
react in some
already a
metal
inspection.
| Bruce McFadden
Birmingham, AL
| PA32-260
Old August 20th 06, 12:30 PM posted to rec.aviation.piloting
Jay Honeck
Default adhesive
I've had good luck with silicone RTV. It holds 'bout anything
securely, but makes a seal that is cushioned enough to "give" a little.
And it can be easily cut free, using an exacto knife or razor blade,
if need be.
I used it to attach a similar Cherokee emblem to the yoke in my old
Warrior (one was cracked, so I replaced it), and it was still there
when I sold the plane. I also use it to secure my electric trim
switch in my current plane, which only has one screw hole (the other
one is broken) functional.
It's great stuff.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
structural adhesive circio0 Home Built 5 May 30th 06 09:34 AM
Adhesive removal [email protected] Soaring 8 May 2nd 06 02:37 PM
Plexiglas/canopy adhesive Michael Pilla Home Built 3 May 3rd 04 05:09 PM
Looking for sand paper rolls and adhesive Roger Halstead Home Built 9 August 8th 03 08:58 AM
Structural adhesive question BD5ER Home Built 1 August 3rd 03 06:03 AM
