Requesting a hold from ATC for descents
Old January 2nd 07, 04:52 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Requesting a hold from ATC for descents
If it becomes impossible to respect your descent schedule, is it
permissible to ask ATC to give you a hold temporarily so that you can
descend in the hold pattern until you're back to your planned descent?
If so, is this a fairly common procedure, or very unusual? I'm
thinking with respect to large commercial jets in particular (or
potentially any jet, since they usually seem to be fast and slippery).
Old January 2nd 07, 07:00 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Never happens. Like the other gentleman says, the spoilers (actually
speed brakes when used in flight) are the "ace in the hole."
Old January 2nd 07, 07:18 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Robert M. Gary
Probably more of an issue for Mooney and Lasair pilots than for jets
that can descend at 3,000 FPM.
-Robert
Old January 2nd 07, 07:26 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Scott Skylane
Sam,
Never say never I have asked for, and received a turn in the hold to
lose altitude, after arriving at the final fix about 10,000 feet high.
This was due to descent restrictions from center because of other
approaches in progress. The flight spoilers on a 727 are *very*
effective, but they can't perform miracles!
Happy Flying!
Scott Skylane
Old January 2nd 07, 08:15 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Sam,
Happy Flying!
Scott Skylane
Your mileage may vary. ;-)
I've got almost 8,000 hours in the 727 and never, ever did an approach
hold or procedure turn. Delay vectors, yes.
Old January 2nd 07, 08:23 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
You also must also factor in pilot incompetence. I can't begin to tell
you how many times these jet pilots, almost always from the majors like
NWA and UAL as well as from the regionals like Skywest, report on the
freq 35 miles out at FL230 or higher. This is not centers fault as the
descent clearance was given about 200 miles out. Center usually gives a
PD descent and these guys continually foul it up. So to illuminate your
mistake I will drive you right at the airport and make you beg for mercy.
Old January 2nd 07, 08:45 PM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Sam Spade writes:
I've tried spoilers, but they aren't always sufficient to please the
FMC. Now I go through every leg of the route checking for
unreasonable-looking descents (or, theoretically, climbs, although the
FMC seems to calculate those more reliably).
Old January 3rd 07, 01:35 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
In the 727 we didn't have any FMC to keep happy. We actually had to
figure it all out by ourselves.
Old January 3rd 07, 01:38 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Sam Spade
to lose altitude, after arriving at the final fix about 10,000 feet
high. This was due to descent restrictions from center because of
other approaches in progress. The flight spoilers on a 727 are *very*
But, for every "incompetent" pilot from NWA and UAL how many do it so
smoothly you actually think they might know what they are doing?
Old January 3rd 07, 02:22 AM posted to rec.aviation.ifr,rec.aviation.piloting,rec.aviation.student
Newps
10% of the crews have this problem.
Different categories of ILS hold short lines at large airports Peter R. Piloting 3 March 6th 06 08:08 PM
Hold at VOR for 2v2 Doug Instrument Flight Rules 21 May 27th 04 11:42 PM
S-TEC 60-2 requires re-trim after altitude hold? Peter R. Owning 7 March 2nd 04 03:46 PM
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
Can I hold both a Canadian and a US license? journeyman Piloting 2 July 19th 03 11:35 PM
