Wikipedia:Yaw string
Old January 29th 07, 10:22 PM posted to rec.aviation.soaring
bumper
Default Wikipedia:Yaw string
Shut up!!
How am I gonna get rich selling these things if you post accurate info like
that?
bumper
"kirk.stant" wrote in message
Darn things work even better when you tape both ends down. Just have
to make sure it's on straight first...
And they last longer on the inside of the canopy, anyway.
66
Old January 30th 07, 12:51 AM posted to rec.aviation.soaring
COLIN LAMB
No one has mentioned that yaw strings work on helicopters, too.
Just as important to avoid adverse yaw on a helicopter - and no, the
"downwash" does not render them useful.
Colin
Old January 30th 07, 12:54 AM posted to rec.aviation.soaring
Sounds like it would be a usefull instrument for a hot air baloon.
After all, you need to know which way the wind is blowing.
Colin
Old January 30th 07, 01:19 AM posted to rec.aviation.soaring
COLIN LAMB
and no, the "downwash" does not render them useful.
I should read twice and send once. I meant:
does not render them useless.
Time for a soda.
Colin
Old January 30th 07, 05:00 AM posted to rec.aviation.soaring
Doug Haluza
The FAA RFH (http://www.faa.gov/library/manuals/aircraft/media/faa-
h-8083-21.pdf) only mentions yaw strings on gyroplanes, so I added
that. Find a ref for helicopters, and add the info to the WP article.
On Jan 29, 8:19 pm, "COLIN LAMB" wrote:
and no, the "downwash" does not render them useful.I should read twice and send once. I meant:
Time for a soda.
Colin
Old January 30th 07, 06:26 AM posted to rec.aviation.soaring
COLIN LAMB
I do not recall seeing it written anywhere, but I am a helicopter pilot and
they are on most of the Schweizers (formerly Hughes) that I flew. The
instructors seem to like them and noted when you think you are doing fine
that the yaw string was not centered. Heck, instructors are the same
everywhere, they like to find things you do wrong and point them out - thank
goodness.
Colin
Old January 30th 07, 12:08 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 29, 9:21 am, Jack wrote:
Tom Gardner wrote:
More surprisingly to me is the information that...
Yaw strings are also fitted to the
Lockheed U-2 high-altitude surveillance
aircraft http://www.barryschiff.com/high_flight.htm
... but given how close U2s are to falling out the sky
at altitude (the coffin corner), perhaps it isn't too
surprising.Yaw strings have also been found on USAF fighters. They aid in gunnery
training.
Jack
Old January 30th 07, 02:52 PM posted to rec.aviation.soaring
kirk.stant
On Jan 29, 4:22 pm, "bumper" wrote:
Shut up!!
that?
Same way everybody makes a small fortune in aviation - start with a
big one!
Actually, you should consider using the blank surface of the yawstring
for advertising - how about string cheese? Or baling wire?
66
light twins? Bellsouth News Server Home Built 83 August 12th 05 02:56 AM
Yaw String in a Spin John Galloway Soaring 52 January 21st 05 10:14 PM
Yaw String refference - Spinning Vassilios Mazis Soaring 1 January 18th 05 07:30 AM
Long Island Crash - Kite String? Neb Okla Rotorcraft 5 September 3rd 04 05:43 PM
String in the middle does not protect you from a spin Jim Soaring 10 January 30th 04 02:57 PM
