What about the fact that we expose ourselves to 1,000,000's of
instances of instinctively responding to the string by stepping in the direction the front end points to? Would that not lead to some kind of conditioning that will have disasrtous results (i.e. pro-spin rudder) when making a visual reference to the string, while spinning unexpectedly and under stress? There will have to be some very well rehearsed routine about this, and regular practice. Any human factors specialist out there ? Vassilios |
Vassilios Mazis wrote:
What about the fact that we expose ourselves to 1,000,000's of instances of instinctively responding to the string by stepping in the direction the front end points to? Would that not lead to some kind of conditioning that will have disasrtous results (i.e. pro-spin rudder) when making a visual reference to the string, while spinning unexpectedly and under stress? There will have to be some very well rehearsed routine about this, and regular practice. Any human factors specialist out there ? Vassilios Not necessarily a "specialist" but I do hold an Australian ATPL and several thousand hours in both gliders and powered (airline category) aircraft. That's my resume out of the way.... Any "conditioning" will lead to some sort of automatic response to a given stimulus. So yes, if the string goes out in one direction and I have conditioned myself to react with a certain control input, then there's a good chance I will revert to that learned behaviour in a crisis or when otherwise busy/overloaded. A human needs to consciously THINK to override a conditioned response. If thinking is a luxury due to other stressors, the automatic response will be carried out without conscious thought - this is sometimes called "muscle memory". (This has nothing to do with a muscle being able to "remember" anything, but refers purely to the unconscious, automatic response from the brain.) With regard to spinning: step on the pedal, if things get worse (or don't get better) step on the other pedal. Unless you're doing aerobatics (in which case you initiated the spin) a pilot *should* be able to recognise and recover from the incipient stages of both stalls and spins. If they can't, they have no business being a solo pilot of any machine. Condition yourself to recognise and recover from an incipient stall/spin rather than jumping on a pedal due to a piece of wool/string ![]() My $0.02 worth. James -- We are all agreed that your theory is crazy. The question which divides us is whether it is crazy enough to have a chance of being correct. My own feeling is that it is not crazy enough. -- Niels Bohr |
| Thread Tools | |
| Display Modes | |
| Yaw String in a Spin | John Galloway | Soaring | 52 | January 21st 05 11:14 PM |
| Stalling and spinning generally | Ian Strachan | Soaring | 0 | February 1st 04 09:40 PM |
| String in the middle does not protect you from a spin | Jim | Soaring | 10 | January 30th 04 03:57 PM |
| Spinning or the after effects of stalling. | Dave Martin | Soaring | 0 | January 30th 04 12:24 AM |
| Spinning Horizon | Mike Adams | Owning | 8 | December 26th 03 02:35 AM |
