Instrument departure, non-IFR airport
Old March 2nd 07, 09:43 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
Default Instrument departure, non-IFR airport
It looks like,
practically speaking, the only way I'm going to be able to depart KRIR
with a low ceiling is by going SVFR to KRAL first, then proceeding IFR
from there. Receiving ATIS and TWR on the ground at KRIR is not an
issue and, traffic and wx permitting they will provide a SVFR
clearance for KRAL while I'm still on the ground at KRIR.
Works if you can fly below 700 AGL into KRAL CDAS. And not at night.
  #42
Old March 2nd 07, 09:44 PM posted to rec.aviation.ifr
Allan9
Steve where did you find the SOCAL SOP?
Al
On Mar 2, 9:53 am, wrote:
Some specfics will be helpful now: the airport is Flabob, KRIR, field
elevation 764 MSL. I spoke with several folks and each seemed to
have a different take. The TRACON controller was the most helpful/
sympathetic; he told me his Minimum Vectoring Altitude in that area is
3200 [in addition to a small hill off the departure end of RWY 24
there are taller rocks to the North]. I heard from both the
controller and local pilots that zero-zero departures used to be
permitted until about 2 years ago and since then clearances while on
the ground have been unavilable. Now the airport is only 10 NM SE of
Ontario...so I'm guessing that my IFR departure off Flabob negatively
impacts their inbounds into ONT until they have identifed me on radar
or I'm through the MVA. I have suspected this is the funcamental I'm
not permitted a clearance and that until 2 years ago there may have
been a Letter of Agreement between ONT tower and SoCal departure that
permitted Flabob IFR departures. If so, am I not getting a raw deal
on "first come, first, served"?
The current SOCAL SOP specifies a procedure for clearances for two
airports without published departure procedures, Flabob and Perris
Valley. The RIR procedure is, "Cleared to (destination), enter
controlled airspace southwest of
Fla-Bob. When entering controlled airspace, proceed direct RAL VOR,
direct PDZ (remainder of route), maintain 4000' MSL, expect (filed or
TEC altitude) 10 minutes after departure." I can find nothing else
which mentions IFR departures from Flabob.
BTW, the FSDO guy was the least helpful: "No instrument departure, no
clearances on the ground." When I protested that this was clearly in
error he just repeated what he said, adding some impatient attitude.
That was the end of that conversation.
Your experience with FSDO is not unusual.
  #43
Old March 2nd 07, 09:55 PM posted to rec.aviation.ifr
On Mar 2, 1:43 pm, "Stan Prevost" wrote:
It looks like,
CDAS?
The airports are only about 3 miles apart. Given a low ceiling rather
than reduced vis, the topography and obstacles are not a problem.
Departing KRIR from rwy 24 on a left 45 in seconds you are over the
center of KRAL if that is your intent.
But it is a pain-in-the-butt if time is an issue, if the vis is worse
in that direction, if there is very low stratus to the South, as is
sometimes the case. I'm still holding out hope that I can, under the
right circumstances, get an IFR clearance on the ground, from KRIR.
  #44
Old March 2nd 07, 10:29 PM posted to rec.aviation.ifr
Sam Spade
Steven P. McNicoll wrote:
"Sam Spade" wrote in message
You would have to ask the TARCON and FSDO the original poster dealt with.
I can only ask you to clarify what you wrote.
What I wrote was perfectly clear.
  #45
Old March 2nd 07, 10:31 PM posted to rec.aviation.ifr
Sam Spade
On Mar 2, 12:40 pm, Sam Spade wrote:
You should look at the airport and airspace at issue.
I did.
Do you know where the closest SCT ASR antenna is to the OP's airport?
  #47
Old March 2nd 07, 10:32 PM posted to rec.aviation.ifr
Sam Spade
On Mar 2, 12:42 pm, Sam Spade wrote:
I didn't say that it necessarily does. I can also understand why SoCal
and KRAL tower don't want to do it.-
Why do you believe they don't want to do it?
I said I can understand why they would not want to do it. It is more
than a belief.
I don't believe you understand the airspace issues in that area. It is
different than Wisconsin.
  #48
Old March 2nd 07, 10:33 PM posted to rec.aviation.ifr
Newps
Sam Spade wrote:
If controlled airspace was not involved you could do what you want. But,
the rub comes in them providing you a clearance into (presumably
1200-foot floor Class E airspace without some procedure that assures
obstacle clearance until reaching the minimum IFR altitude.
Not ATC's problem. That's 100% on the pilot.
  #50
Old March 2nd 07, 10:37 PM posted to rec.aviation.ifr
Sam Spade
On Mar 2, 11:57 am, wrote:
Is this SOP publicly available?
No.
It would be with a FOIA request.
Departure procedures notice Jim Macklin Instrument Flight Rules 12 January 27th 07 02:57 PM
Fedex Departure (MCO) Glen in Orlando Aviation Photos 0 November 29th 06 11:13 PM
Alternate same as departure? dlevy Instrument Flight Rules 34 December 11th 04 01:15 PM
Uncontrolled airport departure-again... endre Instrument Flight Rules 13 March 1st 04 12:42 AM
gliding back to your departure airport Harold Piloting 34 October 24th 03 11:12 PM
