Instrument departure, non-IFR airport
Old March 2nd 07, 05:51 AM posted to rec.aviation.ifr
Default Instrument departure, non-IFR airport
Recently I tried to depart from an non-tower airport that has no
instrument approach procedure, and hence no instrument departure. I
was told that I could not get a clearance on the ground, even with
VIFNO etc., and that I would have to depart VFR and pick my clearance
up while airborne. The recommendation made to me by both TRACON and
local FSDO for departing IFR with a low ceiling was to get a special
VFR clearance into the towered airport 6 miles away [which has an
approach and then depart IFR from there.
My question is, if I take responsibility for staying away from the
rocks [assume a low ceiling, above the tops of small hills, but below
minimum vectoring altitude], shouln't I be able to get a clearance on
the ground?
Alan, PP-AMEL-IA
Old March 2nd 07, 09:56 AM posted to rec.aviation.ifr
Sam Spade
the ground?
Alan, PP-AMEL-IA
If controlled airspace was not involved you could do what you want.
But, the rub comes in them providing you a clearance into (presumably
1200-foot floor Class E airspace without some procedure that assures
obstacle clearance until reaching the minimum IFR altitude.
If you were out west in an area that is Class G below 14,500 they would
leave you to your own devices and tell you to maintain your assigned
altitude when entering controlled airspace. In that case that minimum
IFR altitude would usually be below 14,000 so you would enter an airway
laterally from Class G airspace.
Old March 2nd 07, 10:37 AM posted to rec.aviation.ifr
Hilton
Not true. The NTSB law judge said: "In that decision the law judge found
that respondent's takeoff from an uncontrolled airport into clouds without a
clearance or release from air traffic control (ATC) was not a violation of
14 C.F.R. 91.155(a), but was in violation of 14 C.F.R. 91.13(a). She
ordered a 90-day suspension of respondent's commercial pilot certificate in
lieu of the 180-day suspension sought in the Administrator's order. For the
reasons discussed below, we deny respondent's appeal and affirm the initial
decision."
http://www.ntsb.gov/alj/O_n_O/docs/aviation/3935.PDF
BTW: If anyone has an 'overuling' of this, please let me/us know.
Hilton
Old March 2nd 07, 11:56 AM posted to rec.aviation.ifr
Matt Whiting
decision."
Hilton
Just shows how dumb the bureaucrats are in matters related to flying.
Matt
Old March 2nd 07, 01:34 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
decision."
That case was handled poorly.
The pilot claimed, "his operation was not careless because he took
several precautions: e.g., he broadcast his departure intentions on
the Unicom frequency; he monitored the ATC frequency for other
traffic; and he departed immediately after another aircraft which had
received an ATC release and clearance, thus claiming to have assured
himself that there would be no other IFR aircraft in the controlled
airspace above the airport." How does departing immediately after
another IFR aircraft ensure there will be no other IFR aircraft in the
controlled airspace above the airport?
The violation of 91.155 was dropped but probably should not have
been. The pilot says there were clouds at 200 feet, and based on the
other pilot's description of the weather it sounds like a solid layer,
but he was VFR when he reached Class E airspace at 700 AGL. VFR cloud
clearance in Class E airspace is 1000' above.
Old March 2nd 07, 02:22 PM posted to rec.aviation.ifr
Sam Spade
decision."
Hilton
When I said "do as you want" I did not mean without an air traffic
clearance. I meant you could roll your own ODP but have a "when
entering controlled airspace maintain X altitude, etc."
Old March 2nd 07, 01:13 PM posted to rec.aviation.ifr
Why is that a rub?
Old March 2nd 07, 02:23 PM posted to rec.aviation.ifr
Sam Spade
Why is that a rub?
The issue of no FAA procedure to provide obstacle clearance below the
MIA once entering the Class E 1200-foot floor area.
Old March 2nd 07, 03:54 PM posted to rec.aviation.ifr
But why is that a rub? Obstacle clearance is the pilot's
responsibility, it's not a concern to ATC.
Old March 2nd 07, 04:31 PM posted to rec.aviation.ifr
Sam Spade
You would have to ask the TARCON and FSDO the original poster dealt with.
Departure procedures notice Jim Macklin Instrument Flight Rules 12 January 27th 07 02:57 PM
Fedex Departure (MCO) Glen in Orlando Aviation Photos 0 November 29th 06 11:13 PM
Alternate same as departure? dlevy Instrument Flight Rules 34 December 11th 04 01:15 PM
Uncontrolled airport departure-again... endre Instrument Flight Rules 13 March 1st 04 12:42 AM
gliding back to your departure airport Harold Piloting 34 October 24th 03 11:12 PM
