110kg seat weight
Old October 8th 07, 07:17 PM posted to rec.aviation.soaring
Nyal Williams
Default 110kg seat weight
Who knows when the JAR standards started requiring
this much maximum seat weight, and which were some
of the earliest gliders built to this standard?
Old October 8th 07, 07:20 PM posted to rec.aviation.soaring
Ian
On 8 Oct, 19:17, Nyal Williams
I presume it was the weight of the fattest person on the committee ...
Ian
Old October 8th 07, 07:37 PM posted to rec.aviation.soaring
Marc Ramsey
Actually, JAR 22.25 specifies a *minimum* occupant weight of 110 kg for
single seat and 180 kg for two seat gliders. The manufacturers could
choose to provide for heavier pilots...
Marc
Old October 8th 07, 09:52 PM posted to rec.aviation.soaring
Nyal Williams
No, that is not correct, Marc; there is no specified
minimum other than that required by the CG location.
110kg is 242 lbs, as you know, and gliders do not
require that the pilot and equipment must meet this
minimum.
The requirement is that the maximum must not be less
than 110kg; it was required of manufacturers to design
at least for this much maximum weight. Earlier gliders,
such as Ka-6 and, apparently, the G-102s will not carry
110kgs. On the other hand, the lowly 1-26 will carry
up to 165lbs, which is about 124.5kg.
I'm looking for early glass gliders that will carry
as much as 110kg.
could
Marc
Old October 8th 07, 10:07 PM posted to rec.aviation.soaring
Marc Ramsey
minimum.
Well, that wasn't what I was trying to say.
That is what I was trying to say.
Earlier gliders,
as much as 110kg.
You didn't ask that 8^)
I think you'll find that a number of earlier SZD gliders allow 110 kg or
more, in particular, the Jantar 2.
Marc
Old October 8th 07, 10:21 PM posted to rec.aviation.soaring
Tim Taylor
On Oct 8, 1:52 pm, Nyal Williams
minimum.
Recheck your calcs: 1kg = 2.205 lbs
lb kg
100 45.359
125 56.69875
150 68.0385
175 79.37825
200 90.718
225 102.05775
250 113.3975
243 110
Old October 9th 07, 12:20 AM posted to rec.aviation.soaring
Frank Whiteley
On Oct 8, 12:17 pm, Nyal Williams
JAA started in 1970. JAR 22 was first published April 1st, 1980, and
I think the min maximum of 110kg was contained therein. However there
was certainly OSTIV discussion preceeding this. Some gliders exceeded
this as max cockpit load was often established by maximum weight of
non-lifting parts and C/G. For example, some Open Cirrus may carry
well over 110kg and still within CG with as much as 350lbs in the
cockpit.
Frank Whiteley
Old October 9th 07, 11:33 AM posted to rec.aviation.soaring
Phil Collin
cockpit.
Frank Whiteley
It is also worth pointing out that 110kg or 242lbs is the max load at a
peak of 16G [that'll be whilst crashing] that an aircraft harness
[European directive] can tolerate...
Old October 9th 07, 05:44 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
as much as 110kg.
According to the BGA data sheets, even an H.201 Std Libelle or an H.301
Open Libelle is good for 110 Kg - but would you get a 110kg pilot into
the cockpit?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 9th 07, 06:35 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
as much as 110kg.
the cockpit?
I'm just under 6 feet and almost exactly 110 kg with parachute, and I
managed to get into a Libelle once, and even get out again, but as I
alluded to earlier, I couldn't move my arms as my shoulders are slightly
too wide. If my shoulders were narrower (or the cockpit wider near the
top), it would have worked fine.
That didn't quite match the fun of my attempt to fit into a Discus A, it
took two people to pull me out...
Marc
How much does an IO-540 weight, wet? iliad Home Built 2 June 11th 06 02:19 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Weight LJ & Nancy Blodgett Home Built 23 September 27th 04 06:19 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
weight David Smith Soaring 0 December 19th 03 05:37 PM
