At 17:42 09 October 2007, Marc Ramsey wrote:
Martin Gregorie wrote: Nyal Williams wrote: I'm looking for early glass gliders that will carry as much as 110kg. According to the BGA data sheets, even an H.201 Std Libelle or an H.301 Open Libelle is good for 110 Kg - but would you get a 110kg pilot into the cockpit? I'm just under 6 feet and almost exactly 110 kg with parachute, and I managed to get into a Libelle once, and even get out again, but as I alluded to earlier, I couldn't move my arms as my shoulders are slightly too wide. If my shoulders were narrower (or the cockpit wider near the top), it would have worked fine. That didn't quite match the fun of my attempt to fit into a Discus A, it took two people to pull me out... Marc I'm trying to sort this out for other people. Personally, I'm 5.6' and about 60kg. I have to put a 16 lb parachute and 27 lb. of lead in the nose of my Discus B to get the CG about an inch from the aft limit. |
Martin Gregorie skrev:
Nyal Williams wrote: I'm looking for early glass gliders that will carry as much as 110kg. According to the BGA data sheets, even an H.201 Std Libelle or an H.301 Open Libelle is good for 110 Kg - but would you get a 110kg pilot into the cockpit? CERTAINLY YES!!! Just allow 20 minutes to "float out". Robert ASW28-18E RD 118 kg |
How much does an IO-540 weight, wet? | iliad | Home Built | 2 | June 11th 06 02:19 PM |
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
Weight | LJ & Nancy Blodgett | Home Built | 23 | September 27th 04 06:19 AM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
weight | David Smith | Soaring | 0 | December 19th 03 05:37 PM |
