I need the pinout for the Terra A3000 encoder
Thanks Dave |
Are you trying to install it of fix it?
Mike I need the pinout for the Terra A3000 encoder Thanks Dave |
Mike Spera wrote:
Are you trying to install it of fix it? Mike I need the pinout for the Terra A3000 encoder Thanks Dave Mike, A little bit of both. I do transponder/altimeter certifications and have an encoder test box I'm designing up and want to know if it will be compatible with the Terra. If not I will need to make an adapter to go between the two. This will help me adjust them when not connected to the transponder. Thanks Dave |
On Nov 17, 6:03 pm, dave wrote:
I need the pinout for the Terra A3000 encoder It is the same as an AmeriKing AK-350 and Narco AR850 |
Transponder for sale Terra TRT 250D/AK-35 encoder | Bill Dodson | Soaring | 0 | March 29th 07 07:27 AM |
Pinout for TERRA TRT-250 transponder | Turaga | Home Built | 10 | November 9th 06 12:38 AM |
FS: Blind Altitude Encoder | nobody | Aviation Marketplace | 0 | August 6th 05 06:58 PM |
KNS-80/KNI-520 encoder bad? | [email protected] | Owning | 4 | September 7th 04 06:27 PM |
Altitude encoder | Chad Lemmen | Owning | 9 | August 23rd 03 01:13 AM |
