Pinout for TERRA TRT-250 transponder
Old November 3rd 06, 12:18 PM
Turaga Turaga is offline
Junior Member
First recorded activity by AviationBanter: Nov 2006
Question Pinout for TERRA TRT-250 transponder
Pinout for the 25-pin connector on my TERRA TRT-250 analog switch button transponder.
and
I have the referencemanual for the King KT76 - 78 (a) if someone have questions...
Tor Rene
Norway
Got my pin-diagram from Juan Jimenez today, THANX
This is how it looks:
TERRA TRT-250 TRANSPONDER
*17 - A2
*5 - A1
*15 - B1
*2 - B2
*14 - B4
*18 - C4
*16 - A4
*3 - C1
*4 - C2
*9 - D4
*1 - SUPPRESSION OUT
*8 and 20 - SWITCHED POWER OUT
*6 - EXT. DME SUPPRESSION IN
*7 and 19 - POWER IN 12 VDC
*11 and 21 - POWER GROUND
*12 and 24 - REMOTE GROUND
Cabel lengths:
RG-58A/U - max 9 ft.
RG-8A/U - 17 ft.
Old November 3rd 06, 04:26 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
Default Pinout for TERRA TRT-250 transponder (and 250D)
Check your email, I already responded to the email you sent me.
Anyone else who wants this...
http://www.bd5.com/trt250-250d_wiringdiagram.pdf
It's a wide page, just tape the two together for the full drawing. The
diagram is for both the 250 and the 250D.
"Turaga" wrote in message
Do anyone have it. Need the piout for the 25-pin connector on my TERRA
TRT-250 analog switch button transponder. Weekend is getting close, and
I was planning of put in order my transponder for regardless flying
inside the controllzone this weekend...
By the way, I have the referencemanual for the King KT76 - 78 (a) if
Tor Rene
Norway
Turaga
Posted via a free Usenet account from http://www.teranews.com
Old November 3rd 06, 05:26 PM
Junior Member
*17 - A2
*5 - A1
*15 - B1
*2 - B2
*14 - B4
*18 - C4
*16 - A4
*3 - C1
*4 - C2
*9 - D4
Cabel lengths:
RG-8A/U - 17 ft.
Old November 5th 06, 11:31 AM posted to rec.aviation.homebuilt
Earls61
*17 - A2
*5 - A1
*15 - B1
*2 - B2
*14 - B4
*18 - C4
*16 - A4
*3 - C1
*4 - C2
*9 - D4
Cabel lengths:
RG-8A/U - 17 ft.
Turaga
Turaga,
Did you know there is an old AD on
those?http://www.airweb.faa.gov/Regulatory...3?OpenDocument
Old November 5th 06, 01:59 PM posted to rec.aviation.homebuilt
Gerry Caron
"Earls61" wrote in message
Turaga,
If you have a TRT-250 with Mod 5 or a TRT-250D with Mod 2 it has the fix
required by the AD.
Gerry
Old November 5th 06, 04:10 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"Gerry Caron" wrote in message
Turaga,
required by the AD.
Gerry
Beat me to it.
And the way to check the mod is to look for the label with the serial
number, the mod level is determined by looking at which number has been
taken off the sticker, or marked.
Old November 6th 06, 08:18 PM
Junior Member
Mine has the number five taken out, and it has just been at service and yellow-taged. So it should be ok, then I guess...
Tor, Norway
Quote:
"Earls61"
Turaga,
those?
required by the AD.
Gerry
Beat me to it.
Old November 6th 06, 11:59 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
Should be.
Tor, Norway
"Earls61"
oups.com...-
Turaga,
those?
http://tinyurl.com/y5dgsh
fix
required by the AD.
Gerry-
Beat me to it.
Turaga
Old November 8th 06, 03:37 AM posted to rec.aviation.homebuilt
Rob Cherney
On Fri, 3 Nov 2006 12:18:06 +0000, Turaga
Here are some links you might find useful:
Rob-
Old November 8th 06, 04:56 AM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"Rob Cherney" wrote in message
Rob-
Nice!
Wanted pinout for KT78 transponder. [email protected] Owning 1 February 21st 06 04:34 AM
Operation without a transponder flyer Piloting 11 September 14th 04 08:48 AM
PINOUT NEEDED - ARC Transponder log General Aviation 1 August 31st 04 03:14 AM
Transponder test after static system opened? Jack I Owning 6 March 14th 04 03:09 PM
More on transponder petition Ian Cant Soaring 1 February 27th 04 06:37 PM
