I recently purchased a glider which was refinished
in polyurethane and I'm wondering what is the best way to look after the finish? Should I put something like wxblock on it or just use a good automotive wax? should it be hard waxed and buffed like gel coat? What about fixing any problem areas? Is sanding a good idea? Any advice would be appreciated. |
"Uniform Zulu" wrote in message
... I recently purchased a glider which was refinished in polyurethane and I'm wondering what is the best way to look after the finish? Should I put something like wxblock on it or just use a good automotive wax? should it be hard waxed and buffed like gel coat? I would suggest startng with the manufacturer of the paint - many have "how to take care of" information available -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On Feb 5, 11:39*am, Uniform Zulu
wrote: I recently purchased a glider which was refinished in polyurethane and I'm wondering what is the best way to look after the finish? Should I put something like wxblock on it or just use a good automotive wax? should it be hard waxed and buffed like gel coat? What about fixing any problem areas? Is sanding a good idea? Any advice would be appreciated. We need more information there, Uniform Zulu.................What type ship, who painted it, how many coats did he shoot on? If you have at least 3 medium to wet coats, you can wet sand it with a rubber block using 600, then 800 grit paper, then buff out with liquid buffing compound and an 1800 rpm buffer with a wool pad. Repairing scuffed tips requires the edges to be sanded with 220, then shot, when wet sanding out this repair you may show the grey primer at the edge..............that's why white primer is the best. PCL Polyprimer 907 white, it's PE.............use any wax that doesn't have silicone, I use Mothers (milk?), don't like the way WX block goes on after buffing the ship out.......doesn't seem to spread evenly. JJ |
At 14:12 06 February 2008, Jj Sinclair wrote:
We need more information there, Uniform Zulu.................What type ship, who painted it, how many coats did he shoot on? If you have at least 3 medium to wet coats, you can wet sand it with a rubber block using 600, then 800 grit paper, then buff out with liquid buffing compound and an 1800 rpm buffer with a wool pad. Repairing scuffed tips requires the edges to be sanded with 220, then shot, when wet sanding out this repair you may show the grey primer at the edge..............that's why white primer is the best. PCL Polyprimer 907 white, it's PE.............use any wax that doesn't have silicone, I use Mothers (milk?), don't like the way WX block goes on after buffing the ship out.......doesn't seem to spread evenly. JJ LS-3, I don't have much info on the finish (long story). The finish is 10 years old and still looks good except for a few rough areas on the wings. I'm not sure about the paint thickness but it appears thin in areas on the tops of the wings. I will probably take it down to M&H next year to fix since any sanding on the tops of wings will probably go through. Can you just shoot new paint on these areas after sanding down and blend in? |
Can you just shoot
new paint on these areas after sanding down and blend in? Yes, but any wet sanding at the edges runs the chance of going thin and showing primer through. Not that hard to shoot the tops only with enough paint to allow a complete sanding and buff-out. I did this on my Genesis after the re-build, most areas were just scraped up, so I filled and painted without primer in most areas.........came out good. JJ |
I use Farecla G3 light cutting compound with a splash of water added to make
a toothpaste type consistency. Another splash of water on the wing with the polish before I buff with a foam buff. Goes on consistently. I then use a polish like Nu Finish and polish with a lambs wool buff. I finish sanding with 2000 grade, spanwise. Comes up like a mirror. Repairs are done by wet sanding the area with 400 (care not to sand through to the primer outside of the repair area). If repairing scratches by 'layering in" PU (for small chips or small scratches), remember that PU will shrink to half its size when it dries. Generally used for on field repairs. If the area has not been prepared properly, you will get a shadow/watermark around the repair when you sand it back. Chris |
| Blistering of Finish | Uniform Zulu | Soaring | 10 | December 24th 07 05:40 PM |
| Quickie / Rutan plans with polyurethane foam | [email protected] | Home Built | 3 | March 28th 06 02:04 AM |
| Finish lines | Thomas Knauff | Soaring | 72 | May 24th 05 07:09 AM |
| Taking care of my Jantar polyurethane | Miguel Lavalle | Soaring | 1 | February 18th 04 03:41 PM |
| Best Polyurethane Paint for Homebuilt | jls | Home Built | 2 | February 8th 04 02:25 AM |
