We used Ditzler. What do *you* use? I noticed Joe Schumacher and Mark
Annick used a NAPA polyurethane paint (Martin Senour?) on the RV-8 they erected and floo on teevy. Thanks and eternal gratefulness. And best regards. LarrygettingreadytopaintS. |
The DuPont Imron is popular. Be sure you have a breathing apparatus or
make arrangements for your demise. On Fri, 6 Feb 2004 16:52:21 -0500, " jls" wrote: We used Ditzler. What do *you* use? I noticed Joe Schumacher and Mark Annick used a NAPA polyurethane paint (Martin Senour?) on the RV-8 they erected and floo on teevy. Thanks and eternal gratefulness. And best regards. LarrygettingreadytopaintS. |
I just finished painting mine. Had a local body man (a pilot) spray "PPG
Concept DCC Acrylic Urethane" on it. A bit pricey stuff ($300/gal) but it took only about 1.3 gallons to spray the whole plane with two coats. That kept the weight down. It really shines like a mirror. Paul Lee, SQ2000 canard project: http://www.abri.com/sq2000 " jls" wrote in message ... We used Ditzler. What do *you* use? I noticed Joe Schumacher and Mark Annick used a NAPA polyurethane paint (Martin Senour?) on the RV-8 they erected and floo on teevy. Thanks and eternal gratefulness. And best regards. LarrygettingreadytopaintS. |
| Thread Tools | |
| Display Modes | |
| Need Paint Booth Info | Tom Haughton | Home Built | 1 | December 7th 03 10:58 PM |
| Choice of Paint for use over Copper foil Antennas | Charlie Precourt | Home Built | 1 | December 2nd 03 03:51 AM |
| hi vis Paint | Ben Haas | Home Built | 0 | November 8th 03 03:58 PM |
| rivet and dimple paint prep | Dick | Home Built | 2 | August 12th 03 09:31 AM |
| Velocity Paint scheme | Ezaviator | Home Built | 0 | July 31st 03 05:09 AM |
