Cessna 210 fuel drip
Old March 10th 08, 07:53 PM posted to rec.aviation.owning
John Clonts
Default Cessna 210 fuel drip
We have a 78 Centurion which has developed a fuel "drip" underneath,
from some kind of drain tube protruding from under the fuselage on the
left side, about 12-18" behind the nose wheel opening. I am trying to
figure out what this line is coming from or is for. It is not the
fuel strainer discharge tube, nor is it the sump "quick drain".
Looking at a parts manual for the aircraft, it seems that it may be
some kind of vent or drain line coming from the fuel selector valve?
The drip is about 1 drip per minute, which keeps a wet spot about 5"
in diameter on the hangar floor.
I have discussed it with our mechanic, but only by phone since he is
60nm away, and so far he can't remember what it might be but "we would
just have to look at it".
Is anyone here familiar enough with this installation to shed some
light on it for me? Is this coming from the fuel selector? If so,
does the drip indicate the the selector needs to be serviced or
rebuilt?
Thanks!
John Clonts
Temple, Texas
N7NZ
Old March 11th 08, 05:58 PM posted to rec.aviation.owning
John[_9_]
left side, about 12-18" behind the nose wheel opening. *I am trying to
figure out what this line is coming from or is for. *It is not the
light on it for me? *Is this coming from the fuel selector? *If so,
rebuilt?
Thanks!
John Clonts
Temple, Texas
N7NZ
In all likelihood that is the drain mast for the electric fuel pump.
If it is leaking that means the pump seals have failed and it is
possible that fuel will wash the lubricant for the pump bearings.
Looks like a new pump for you.
John Dupre'
Old March 13th 08, 03:33 AM posted to rec.aviation.owning
rebuilt?
Thanks!
John Clonts
Temple, Texas
N7NZ
John Dupre'
Some Cessnas had an intake manifold drain to remove surplus fuel
if the engine became flooded from overpriming.
If this 210 is carbureted, the carb float valve is leaking. If
it's injected, the leak is from something else, not the manifold.
Dan
Old March 14th 08, 12:47 PM posted to rec.aviation.owning
John[_9_]
rebuilt?
Thanks!
John Clonts
Temple, Texas
N7NZ
John Dupre'
* * *Some Cessnas had an intake manifold drain to remove surplus fuel
* * *If this 210 is carbureted, the carb float valve is leaking. If
* * * Dan- Hide quoted text -
- Show quoted text -
The key is that the leaking line is 12 to 18 inches behind the nose
wheel well on the left side. That is where the electic fuel boost
pump is located.
John Dupre'
Old March 14th 08, 10:21 PM posted to rec.aviation.owning
John Clonts
rebuilt?
Thanks!
John Clonts
Temple, Texas
N7NZ
John Dupre'
wheel well on the left side. *That is where the electic fuel boost
pump is located.
John Dupre'- Hide quoted text -
Yes, I think you are right. This gibes with what I see now in the
parts and service manuals. My mechanic tells me that it may simply be
due to lack of use, over the 4 months that it has sat while our engine
was being rebuilt. Last time I checked it it was dripping slower than
it had been before...
Thanks!
John
Cessna 172 fuel selector Ross Owning 12 December 1st 08 06:44 PM
Cessna 172 Fuel Flowmeter? CVBreard Piloting 9 January 26th 05 08:00 AM
Fuel Drip Containment -- My Solution Jim Weir Home Built 4 November 1st 03 06:22 AM
Fuel Drip Containment Jim Weir Owning 52 October 31st 03 09:30 PM
Fuel Drip Containment Sven Home Built 28 October 27th 03 11:28 PM
