Fuel Drip Containment
Old October 25th 03, 07:42 PM
Jim Weir
Default Fuel Drip Containment
Snarly Charlie, the 182, has the classic "Cessna drip" from the fuel vent when
the tanks are filled and the hangar gets warm. I've tried everything I know to
stop it, but all I can do with all the mechanical fixes is slow it down.
I'm getting ready to patch the asphalt under the drip and paint the hangar
floor. Since I can't stop the drip, I want to contain it safely. Anybody got
any thoughts on how to neutralize gasoline and contain the drip without being a
fire hazard?
One thought is to provide a bucket with a nonflammable liquid lighter than
gasoline. Let the gas drip into the bucket with a "blanket" of nonflammable
liquid on top of it. The problem is finding such a liquid.
Another thought is to put some sort of oven pan with a mat of some sort that
would let the gasoline evaporate slowly from under the mat. The problem is
finding a nonflammable mat that gasoline will not attack chemically.
Any ideas?
http://www.rst-engr.com
Old October 25th 03, 08:30 PM
J. Severyn
"Jim Weir" wrote in message
when
know to
snip
Any ideas?
I used to use a coffee-can with a small wire hangar, hung from the overflow
pipe. If the drips were slow enough, it would evaporate before the can
filled......but not always....if I filled the tanks too agressively. So for
the last few years, I just gave up and now I do not fill the tanks
completely. I just got tired of the fuel dripping. I have not noticed any
significant amount of water from condensation (as the tanks are nearly
full).
Yes, I'd like a better solution too.
John Severyn
Old October 25th 03, 08:33 PM
Sven
Hi Jim,
I have seen people hang an empty plastic oil bottle on the fuel vent to
catch the dripping fuel on Cessnas. Have you tried this? It shouldn't be too
much of a fire hazard and will save your hangar floor. Just make sure that
you drain the bottle regularly because the angle it sits on the vent, it
won't hold a whole quart of fuel. Using a GATT jar or some other filter, you
can reuse the fuel.
when
know to
Old October 25th 03, 08:39 PM
Jon Woellhaf
How about letting it drip into a fuel cell of the type used by NASCAR?
when
know to
got
being a
fire hazard?
nonflammable
that
is
Any ideas?
Old October 25th 03, 08:51 PM
Montblack
("Jim Weir" wrote)
that
is
Pet store (or a garage sale) buy a lizard heating rock. $10.
Put the flat rock UNDER, maybe a large brownie pan, and insulate around the
rock.
We used a 2" thick piece of rigid pink insulation and cut out the shape of
the rock. Rock fit flush in the hole. Then we also put another piece of
rigid pink UNDER the rock, So now the rock/insulation layer is sandwiched
between a solid piece of 2" insulation on the bottom and the container on
top.
The rock should be upside-down in the insulation hole to mate up with the
bottom of whatever you're using as a drip pan.
Run a couple of bands of duct tape around the pink edges for that "finished"
look and you're all set.
For us it was an aquarium for the lizard (anole) brought home from school at
the end of the year, by the 3rd grade niece. Kept that sucker alive for 2
years.
http://www.tpwd.state.tx.us/nature/w...iles/anole.htm
You know, any small heating pad would work in this setup. I had a waterbed
heater that I kept for years after the bed had been thrown away. Used the
pad all the time. Gave the pad to my sister a while back, haven't seen it
since.
Or ...a can of yellow foam insulation is $2.95 - $3.95 ...and it's fun to
play with. Wear latex gloves because that stuff turns your hands black,
before it hardens.
Whatever you choose, just separate the heating thing from the thermal mass
pan thing.
Good luck.
Montblack
"Styled by the laws of nature.............Concorde"
Old October 25th 03, 09:12 PM
Frank
"Jon Woellhaf" wrote in
news:Jrzmb.12980$9E1.63303@attbi_s52:
vent
when
I
know to
down.
hangar floor. Since I can't stop the drip, I want to contain it
safely. Anybody
got
without
being a
fire hazard?
than gasoline. Let the gas drip into the bucket with a "blanket" of
nonflammable
sort
that
problem
is
Any ideas?
Battery mat or fiberglass mat in a cookie sheet. Lots of area for
evaporation.
Old October 25th 03, 09:46 PM
clare @ snyder.on .ca
On Sat, 25 Oct 2003 18:33:46 GMT, "Sven"
Hi Jim,
can reuse the fuel.
when
know to
The RIGHT way to solve the problem is to go flying!!!!
Old October 26th 03, 01:48 AM
David Lesher
Jim Weir writes:
fire hazard?
There are asphalt mixes that resist gasoline "softening"... They
get used on fueling pads, etc. Ask a paving guru.
How about a bucket full of kitty litter?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old October 26th 03, 02:31 AM
G.R. Patterson III
My suggestion is to use one of the hot water heater overflow pans from Home
Depot (or the like) and fill it with a clay-based cat litter.
George Patterson
You can dress a hog in a tuxedo, but he still wants to roll in the mud.
Old October 26th 03, 04:48 AM
C J Campbell
Don't fill your plane before putting it away?
We turn the fuel valve off or turn it to left or right tank -- this seems to
mitigate the problem considerably, though I am not sure why it does this.
spaceship one Pianome Home Built 169 June 30th 04 06:47 AM
Fuel Drip Containment -- My Solution Jim Weir Home Built 4 November 1st 03 06:22 AM
Fuel Drip Containment Sven Home Built 28 October 27th 03 11:28 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
