control cable protection question
Old March 13th 08, 11:29 PM posted to rec.aviation.homebuilt
Dick[_1_]
Default control cable protection question
good point on hidden cable strands. i will use fairlead or delron..
"Highflyer" wrote in message
"Dick" wrote in message
news:Ud9Cj.19481$er2.14960@trnddc08...
actually fuselage belly has an inspection/access cover. Thanks though.
On Mar 12, 7:33 am, "Peter Dohm" wrote:
BTW, your proposed method looks like a dangerous source of both binding
and
corrosion--at least to me.
Peter
And an uninspectable spot. It's unorthodox, at least, and should
be avoided. The cables need to be rerouted via fairleads or rubbing
blocks to separate them, not sleeved.
Dan
An access cover in the belly does NOT make the cables inspectable when
they are covered by a sleeve. Can you detect broken strands?
Separate them positively with a pulley or fairleads please. It doesn't
add much weight and will prevent all kinds of wear and corrosion problems
while remaining inspectable.
Highflyer
EAA Technical Counselor
FAA Technical Safety Counselor
Old March 13th 08, 11:31 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Good Man!
As a side issue, remember that the cable WILL be excited (mechanically,
if not emotionally), and will want to wiggle all over the place.
(Got to be a better description for this oscillation, but...)
Anyway, cable throught a fairlead (rather that rubbing over a flat
edge) will kill the oscillation at that point - and the cable will
stay in one place.
Fairleads - rather than a protective edge.
Did that make any sense at all???
Richard (I think)
Saturday 072807 in Oshkosh Pt 5 - the US Customs and Border Protection Blackhawk [4/5] - "04 Blackhawk--rapelling in front of what won't be the World's Busiest Control Tower much longer .jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 07:31 PM
Control surface design question Chris W Home Built 16 July 30th 07 04:17 AM
Question on Baron 58 prop control Mxsmanic Piloting 62 December 3rd 06 05:26 AM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
