aerobatic power to weight ratio
Old August 4th 08, 11:33 PM posted to rec.aviation.piloting
Superdoof
Default aerobatic power to weight ratio
Hi,
I've noticed in the videos at www.fulldeflection.com that all the top
aerobatic aicraft, such as the Sukhoi SU-31, Egde 540, Extra 300,
etc., can almost hover.
It seems that within a few years they will be able to climb on power
alone.
Aerobatics will look completely different once that occurs. Can you
imagine Svetlana Kapanina hovering her Sukhoi for a couple of minutes
at 300', then reversing down to an even lower altitude. I can imagine
Peter Besenyei performing the perfect square shaped hover in his Extra
540.
Is this technically feasible, or have the aircraft already reached a
developmental limit ?
Superdoof.
Old August 4th 08, 11:38 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Superdoof wrote in news:649fda93-c79b-45fc-9a41-
Hi,
alone.
540.
Superdoof.
A massive increase in power for a given engine weight with a recip is
unlikely. Significantly lighter structures may be on the cards, OTOH..
Bertie
Old August 4th 08, 11:50 PM posted to rec.aviation.piloting
Kyle Boatright
"Superdoof" wrote in message
Hi,
alone.
540.
Superdoof.
You can always gear the engine to swing a bigger prop slower. Of course at
some point the landing gear geometry and torque drive you to put a tail
rotor on the thing and call it a helicopter...
Old August 5th 08, 12:24 AM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
Hi,
alone.
540.
A. Thrust /weight 1.0 is possible Add Nitrous or something like that. Of
course, you will be replacing engines on a regular basis
B. Control would be a problem. Hanging from the prop results in torque
rolls. Airplanes don't have tail rotors or cyclic control over the
propeller.
Geoff
Old August 5th 08, 12:47 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
propeller.
A VERY effective demonstration of this can be done in a P51. You start
from slow flight with the prop all the way up and slowly begin
increasing angle of attack and feeding in more MP as needed to hold
altitude. Sort of like any entry into a slow flight back side scenario.
As you do this you will need more and more right aileron. You will reach
a point where aileron can't hold it any longer and the airplane will
torque roll on you.
It's a VERY effective technique for demonstrating how NOT to get in high
angle of attack/slow airspeed/high power situations :-))
Dudley Henriques
Old August 5th 08, 12:51 AM posted to rec.aviation.piloting
propeller.
from slow flight with the prop all the way up and slowly begin increasing
angle of attack and feeding in more MP as needed to hold altitude. Sort
torque roll on you.
Dudley Henriques
I'll have to take your word on that...
Geoff
Old August 5th 08, 01:43 AM posted to rec.aviation.piloting
Morgans[_2_]
Sean tucker has already perfected the hover, in his Super Pitts.
Jim in NC
Old August 5th 08, 01:45 AM posted to rec.aviation.piloting
Morgans[_2_]
propeller.
Sean Tucker overcomes the torque with 4 great big ailerons on a biplane,
with the prop wash giving enough deflection to keep him pretty straight.
Jim in NC
Old August 5th 08, 04:42 AM posted to rec.aviation.piloting
Adam Cope
http://video.google.com/videoplay?do...92639009239481
Wayne Handley had his Turbo Raven that crashed in 99. It could hover and
then climb.
Adam
Adam Cope
www.dcaerobatics.com
703-623-9445
Hi,
alone.
540.
Superdoof.
Old August 5th 08, 11:20 AM posted to rec.aviation.piloting
More_Flaps
propeller.
torque roll on you.
I understand the reasoning/description here, but how/why do model
planes do it so well?
Cheers
Fiberglass cloth weight vs 'finished' weight Fred the Red Shirt Home Built 12 April 5th 08 04:24 PM
Glider Weight/Wing Loading and determing speed for best L/D for a given weight 65E Soaring 3 January 26th 06 09:26 PM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
Diesel engines- forced induction, power-weight Jay Home Built 4 December 7th 03 09:23 AM
