#21
Calibration is also required to assure the flight didn't get into Class A
airspace without clearance. Maybe not a problem a lot of places but it can be a real issue in the west. John Scott |
What kind of tampering are you looking for? I'm curious.
I thought about the comment by another of hooking up something in the unit. Most likely the person would use alligator clips or some other intricate connector. Do you think you would be able to see the scratch marks left by this connector? What else are you testing for? Some code changes or board modifications? More likely someone would hook through the communication connection outside the unit. Then you would never know they were doing that would you when you did the 'in hand inspection'. How about I take a picture and send it to you while you are connected to the unit? There is not much room inside the unit for this kind of modificationl Nor as another put it would someone really invest the time and money? Steve Michalik At 14:37 27 August 2008, Paul Remde wrote: Hi Marc, Good point. I really would need to have the unit in hand. Paul Remde "Marc Ramsey" wrote in message .. . Sam Discusflyer wrote: So why is it not possible to hook up the GPS unit to the PC connected to the internet, connect with the key master and load the serial #? Open up case, insert $2 microcontroller between GPS receiver and flight recorder logic board, close case, call up manufacturer say "hey my flight recorder unsealed itself", reload key, go set some world records. The manufacturer or designated agent is supposed to inspect the interior of the unit for tampering before resealing. Otherwise, there's not much point to sealing it in the first place... Marc |
On Aug 27, 4:39*pm, Sam Discusflyer wrote:
What kind of tampering are you looking for? I'm curious. *I thought about the comment by another of hooking up something in the unit. Most likely the person would use alligator clips or some other intricate connector. Do you think you would be able to see the scratch marks left by this connector? What else are you testing for? Some code changes or board modifications? *More likely someone would hook through the communication connection outside the unit. Then you would never know they were doing that would you when you did the 'in hand inspection'. How about I take a picture and send it to you while you are connected to the unit? There is not much room inside the unit for this kind of modificationl Nor as another put it would someone really invest the time and money? Steve Michalik At 14:37 27 August 2008, Paul Remde wrote: Hi Marc, Good point. *I really would need to have the unit in hand. Paul Remde "Marc Ramsey" *wrote in message .. . Sam Discusflyer wrote: So why is it not possible to hook up the GPS unit to the PC connected to the internet, connect with the key master and load the serial #? Open up case, insert $2 microcontroller between GPS receiver and flight recorder logic board, close case, call up manufacturer say "hey my flight recorder unsealed itself", reload key, go set some world records. The manufacturer or designated agent is supposed to inspect the interior of the unit for tampering before resealing. *Otherwise, there's not much point to sealing it in the first place... Marc Aligator clips? I could solder and unsolder components inside the system, replace or repogram EEPROMS on the boards, etc. All bets are off if I open the container and get to reseal it myself. Nobody is going to ever get to look at it anyhow if you could self seal. The whole point of the seal is you can't do it yourself, but must use a trusted agent. We would not have all been going through this hassle if it was not an issue. With nothing more than what an good electronics hobbiest would have I could open up any of these units and tap into the pressure transducer electrical interface and make it do anything I wanted. Take the altitude part of the GPS signal, fake that as well. Hey presto a new world altitude record. Now sealing and the current mechanisms are not absolutely bullet proof but they are a useful deterent. And as others mentioned there have been attempts to forge flights. You clearly are unhappy you have to pay some money to get this resealed. But you know what you don't. If you don't like all this stuff about having certified loggers and verifyable flights etc. don't use a certified logger or don't have it resealed. Many garden variety, low cost, GPS systems can log your flight and you can look at them all you want in SeeYou etc. Many PDA soaring programs and other systems will create logs suitable for use by OLC. But if you want to try out for badges or records, etc. then you have to follow the rules or go lobby to the IGC to have them changed. Darryl |
#24
On Aug 27, 5:24*pm, Darryl Ramm wrote:
On Aug 27, 4:39*pm, Sam Discusflyer wrote: What kind of tampering are you looking for? I'm curious. *I thought about the comment by another of hooking up something in the unit. Most likely the person would use alligator clips or some other intricate connector. Do you think you would be able to see the scratch marks left by this connector? What else are you testing for? Some code changes or board modifications? *More likely someone would hook through the communication connection outside the unit. Then you would never know they were doing that would you when you did the 'in hand inspection'. How about I take a picture and send it to you while you are connected to the unit? There is not much room inside the unit for this kind of modificationl Nor as another put it would someone really invest the time and money? Steve Michalik At 14:37 27 August 2008, Paul Remde wrote: Hi Marc, Good point. *I really would need to have the unit in hand. Paul Remde "Marc Ramsey" *wrote in message .. . Sam Discusflyer wrote: So why is it not possible to hook up the GPS unit to the PC connected to the internet, connect with the key master and load the serial #? Open up case, insert $2 microcontroller between GPS receiver and flight recorder logic board, close case, call up manufacturer say "hey my flight recorder unsealed itself", reload key, go set some world records. The manufacturer or designated agent is supposed to inspect the interior of the unit for tampering before resealing. *Otherwise, there's not much point to sealing it in the first place... Marc Aligator clips? I could solder and unsolder components inside the system, replace or repogram EEPROMS on the boards, etc. All bets are off if I open the container and get to reseal it myself. Nobody is going to ever get to look at it anyhow if you could self seal. The whole point of the seal is you can't do it yourself, but must use a trusted agent. We would not have all been going through this hassle if it was not an issue. With nothing more than what an good electronics hobbiest would have I could open up any of these units and tap into the pressure transducer electrical interface and make it do anything I wanted. Take the altitude part of the GPS signal, fake that as well. Hey presto a new world altitude record. Now sealing and the current mechanisms are not absolutely bullet proof but they are a useful deterent. And as others mentioned there have been attempts to forge flights. You clearly are unhappy you have to pay some money to get this resealed. But you know what you don't. If you don't like all this stuff about having certified loggers and verifyable flights etc. don't use a certified logger or don't have it resealed. Many garden variety, low cost, GPS systems can log your flight and you can look at them all you want in SeeYou etc. Many PDA soaring programs and other systems will create logs suitable for use by OLC. But if you want to try out for badges or records, etc. then you have to follow the rules or go lobby to the IGC to have them changed. Darryl And yes I know technically the altitude record is a bad example. (outside the specs of many loggers), here is a better one... I could magically stay below 18,000' all day regardless of how high I flew. I think Marc and I could go into business on some of these add on options if you did not require sealed loggers. Darryl |
#25
I'm not unhappy at all. I like to fly for records even if they are modest
at best. But why not improve things for everyone and use technology to make it easier. Your note backs up my point that the 'in hand inspection' is more of a ceremonial task than prevention. Ok I didn't mean to cause problems so I'll say thank you for the comments. Good Lift, Steve At 00:28 28 August 2008, Darryl Ramm wrote: On Aug 27, 5:24=A0pm, Darryl Ramm wrote: On Aug 27, 4:39=A0pm, Sam Discusflyer wrote: What kind of tampering are you looking for? I'm curious. =A0I thought about the comment by another of hooking up something in th= e unit. Most likely the person would use alligator clips or some other intricate connector. Do you think you would be able to see the scratch marks left by this connector? What else are you testing for? Some code changes or board modifications? =A0More likely someone would hook throu= gh the communication connection outside the unit. Then you would never kno= w they were doing that would you when you did the 'in hand inspection'. How about I take a picture and send it to you while you are connected t= o the unit? There is not much room inside the unit for this kind of modificationl N= or as another put it would someone really invest the time and money? Steve Michalik At 14:37 27 August 2008, Paul Remde wrote: Hi Marc, Good point. =A0I really would need to have the unit in hand. Paul Remde "Marc Ramsey" =A0wrote in message .. . Sam Discusflyer wrote: So why is it not possible to hook up the GPS unit to the PC connect= ed to the internet, connect with the key master and load the serial #? Open up case, insert $2 microcontroller between GPS receiver and fli= ght recorder logic board, close case, call up manufacturer say "hey my flight recorder unsealed itself", reload key, go set some world records. The manufacturer or designated agent is supposed to inspect the interior of the unit for tampering before resealing. =A0Otherwise, there's no= t much point to sealing it in the first place... Marc Aligator clips? I could solder and unsolder components inside the system, replace or repogram EEPROMS on the boards, etc. All bets are off if I open the container and get to reseal it myself. Nobody is going to ever get to look at it anyhow if you could self seal. The whole point of the seal is you can't do it yourself, but must use a trusted agent. We would not have all been going through this hassle if it was not an issue. With nothing more than what an good electronics hobbiest would have I could open up any of these units and tap into the pressure transducer electrical interface and make it do anything I wanted. Take the altitude part of the GPS signal, fake that as well. Hey presto a new world altitude record. Now sealing and the current mechanisms are not absolutely bullet proof but they are a useful deterent. And as others mentioned there have been attempts to forge flights. You clearly are unhappy you have to pay some money to get this resealed. But you know what you don't. If you don't like all this stuff about having certified loggers and verifyable flights etc. don't use a certified logger or don't have it resealed. Many garden variety, low cost, GPS systems can log your flight and you can look at them all you want in SeeYou etc. Many PDA soaring programs and other systems will create logs suitable for use by OLC. But if you want to try out for badges or records, etc. then you have to follow the rules or go lobby to the IGC to have them changed. Darryl And yes I know technically the altitude record is a bad example. (outside the specs of many loggers), here is a better one... I could magically stay below 18,000' all day regardless of how high I flew. I think Marc and I could go into business on some of these add on options if you did not require sealed loggers. Darryl |
#26
#27
#28
On Aug 27, 6:09*pm, Sam Discusflyer wrote:
I'm not unhappy at all. I like to fly for records even if they are modest at best. But why not improve things for everyone and use technology to make it easier. Your note backs up my point that the 'in hand inspection' is more of a ceremonial task than prevention. Ok I didn't mean to cause problems so I'll say thank you for the comments. Good Lift, Steve At 00:28 28 August 2008, Darryl Ramm wrote: On Aug 27, 5:24=A0pm, Darryl Ramm *wrote: On Aug 27, 4:39=A0pm, Sam Discusflyer *wrote: What kind of tampering are you looking for? I'm curious. =A0I thought about the comment by another of hooking up something in th= e unit. Most likely the person would use alligator clips or some other intricate connector. Do you think you would be able to see the scratch marks left by this connector? What else are you testing for? Some code changes or board modifications? =A0More likely someone would hook throu= gh the communication connection outside the unit. Then you would never kno= w they were doing that would you when you did the 'in hand inspection'. How about I take a picture and send it to you while you are connected t= o the unit? There is not much room inside the unit for this kind of modificationl N= or as another put it would someone really invest the time and money? Steve Michalik At 14:37 27 August 2008, Paul Remde wrote: Hi Marc, Good point. =A0I really would need to have the unit in hand. Paul Remde "Marc Ramsey" =A0wrote in message .. . Sam Discusflyer wrote: So why is it not possible to hook up the GPS unit to the PC connect= ed to the internet, connect with the key master and load the serial #? Open up case, insert $2 microcontroller between GPS receiver and fli= ght recorder logic board, close case, call up manufacturer say "hey my flight recorder unsealed itself", reload key, go set some world records. The manufacturer or designated agent is supposed to inspect the interior of the unit for tampering before resealing. =A0Otherwise, there's no= t much point to sealing it in the first place... Marc Aligator clips? I could solder and unsolder components inside the system, replace or repogram EEPROMS on the boards, etc. All bets are off if I open the container and get to reseal it myself. Nobody is going to ever get to look at it anyhow if you could self seal. The whole point of the seal is you can't do it yourself, but must use a trusted agent. We would not have all been going through this hassle if it was not an issue. With nothing more than what an good electronics hobbiest would have I could open up any of these units and tap into the pressure transducer electrical interface and make it do anything I wanted. Take the altitude part of the GPS signal, fake that as well. Hey presto a new world altitude record. Now sealing and the current mechanisms are not absolutely bullet proof but they are a useful deterent. And as others mentioned there have been attempts to forge flights. You clearly are unhappy you have to pay some money to get this resealed. But you know what you don't. If you don't like all this stuff about having certified loggers and verifyable flights etc. don't use a certified logger or don't have it resealed. Many garden variety, low cost, GPS systems can log your flight and you can look at them all you want in SeeYou etc. Many PDA soaring programs and other systems will create logs suitable for use by OLC. But if you want to try out for badges or records, etc. then you have to follow the rules or go lobby to the IGC to have them changed. Darryl And yes I know technically the altitude record is a bad example. (outside the specs of many loggers), here is a better one... I could magically stay below 18,000' all day regardless of how high I flew. I think Marc and I could go into business on some of these add on options if you did not require sealed loggers. Darryl We are all using technology to make things easier. You seem to be arguing against that. If you enjoy record flying that is great. But to support that you need a technology based logging system that has traceable compliance. Letting people mess with the logger is therefore a non-starter. I don't know what I could have possibly said that implied that resealing loggers is mostly ceremony, serious hacking like I mentioned would be detectable (altitude out of calibration, modifications that would be visible etc. While you cannot absolutely control what any service center will do I have pretty high expectations of those vendors, especially of folks like Gary at MK. |
#29
I'm not unhappy at all. I like to fly for records even if they are modest at best. But why not improve things for everyone and use technology to make it easier. I've done record flights with a barograph, and I've done them with a secure logger, and my experience is the secure logger DOES make record and badge flights much easier to fly and to document. It's also easier for the official observer and the records keeper. I've never had to reseal a logger (not even my old CAI model 20). The barographs I used had to be recalibrated yearly, so I'm quite happy my secure logger can go two years between calibrations. I've saved enough to reseal several loggers just because of that, compared to the old barographs. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#30
On Wed, 27 Aug 2008 21:19:18 +0100, Tim Newport-Peace wrote:
Not quite right Martin. Calibration is required for observance of the 1% rule for distance flights. Point noted: I'd assumed that the relative height difference would do and that sensor drift would not affect height differentials. FWIW my logger was out of calibration when I made my Gold distance claim and that wasn't questioned. OTOH I started at 3500 and ended at 1600 on a day when the GPS and pressure altitude difference was under 100 ft, so there was no need for careful measurement to verify that I'd met the height difference rules. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Sealing The PIK-20B Canopy | P. Corbett | Soaring | 5 | August 21st 05 08:32 PM |
Sealing an ASW 28 canopy | Bob Caldwell | Soaring | 13 | August 10th 05 09:59 PM |
Sealing a Schweizer; 1-35 mainly | TOM RENT | Soaring | 0 | April 11th 04 08:46 PM |
Libelle Gap Sealing | Owain Walters | Soaring | 4 | April 11th 04 07:13 PM |
sealing cork float against gasoline - how to... | jt | Home Built | 13 | July 18th 03 10:51 PM |
