GPS-NAV security sealing
Old August 26th 08, 04:54 AM posted to rec.aviation.soaring
Sam Discusflyer[_2_]
Default GPS-NAV security sealing
Is there a way to input a security code in a Cambridge GPS_NAV and seal it
without spending hundreds of dollars?
Inquiring minds want to know.
Steve Michalik
Old August 26th 08, 05:41 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
May I assume that is what NK wants to charge you? It's a 15 minute job
if is nothing else is wrong with the unit. You can also try your local
authorized Cambridge dealer, but they'll have to call NK to get the
resealing code...
Marc
Old August 26th 08, 11:20 AM posted to rec.aviation.soaring
ContestID67
First, there is no way that you, an average Joe (Steve), can do this.
Everything to do with flight recorders must be secure so that you can
be in contests, set records, get badges or post to the OLC.
http://www.craggyaero.com/calibration.htm does reseals for $40 (which
isn't "hundreds of dollars").
- John
Old August 26th 08, 02:39 PM posted to rec.aviation.soaring
So humor me some education, and cost aside for the moment, why is it that
CraggyAero or John can do this? Is there some special procedure, some
special certification or training that is required by the FAI? What
ensures and/or audits a commercial operation who is using computer
software to set the security to ensure it is done properly? I want to
understand the difference between the average joe (me) and a commercial
operation doing this task that was / still is in some instances conducted
by the 'official observer' on paper?
- John
Old August 26th 08, 04:37 PM posted to rec.aviation.soaring
5Z
On Aug 26, 6:39*am, Sam Discusflyer wrote:
I want to understand the difference between the average joe (me) and a commercial
What task is that?
The FR is a "secure" instrument that is protected by a variety of
methods to prevent tampering. The GPS-NAV is the oldest of these
devices and depends on an internal battery to keep the seal intact, so
this battery must be replaced regularly (for example, during
calibration). If the battery goes bad, then an authorized facility
must reseal the unit. This way, that facility is held responsible for
any "unusual" IGC files that may come out of this FR.
If 'any Joe' could seal the FR, then prior to sealing, the electronics
inside the unit could be modified or replaced by 'Joe', and nobody
would be the wiser. The OO would see a sealed FR, trust it to
generate a true record of the flight, and a valid IGC file would be
generated.
The OO ensures that the pilot and FR were actually onboard the same
glider at the same time, and that, to his best ability, no funny
business was performed by the pilot during the flight. Since the FR
is out of the OO's control during the flight, it must be sealed by a
3rd party, and that seal must not be modifiable by just anyone at any
time.
Yes, there are a lot of holes and vulnerabilities in this system, and
all sorts of interesting ways to hack it, but so far as we know, that
has not been done yet. And the bottom line, is that those are the
rules. If you don't like them, then you can lobby to change them.
But in the meantime, this is what we have.
-Tom
Old August 26th 08, 05:08 PM posted to rec.aviation.soaring
vontresc
What task is that?
methods to prevent tampering. *The GPS-NAV is the oldest of these
calibration). *If the battery goes bad, then an authorized facility
must reseal the unit. *This way, that facility is held responsible for
would be the wiser. *The OO would see a sealed FR, trust it to
generated.
business was performed by the pilot during the flight. *Since the FR
time.
has not been done yet. *And the bottom line, is that those are the
rules. *If you don't like them, then you can lobby to change them.
-Tom
OK I am relatively new to the Soaring world, but some of the security
protocols on these loggers seem a bit over the top. Was/is there so
much cheating and mistrust that all of these procedures are
neccessary? I realize that some assurance of not tampering with the
device is neccesary, but does it have to cost so damn much?
Pete
DRN
http://www.craggyaero.com/calibration.htmdoes reseals for $40 (which
- John
Shhhhh !!
It is very important to maintain the illusion of security !!
See ya, Dave "YO electric"
PS: That's why Tim's reply is written with disappearing ink ;-)
Old August 26th 08, 03:20 PM posted to rec.aviation.soaring
On Aug 25, 10:54*pm, Sam Discusflyer
Steve Michalik
Exact cost for 1 day turnaround by Gary at NK the week before last was
$130 including memory battery , calibration chart,and next day return
delivery.
My experience is that this is excellent service for a very fair price.
Certainly not the "hundreds of dollars" you seem to anticipate.
UH
Old August 27th 08, 04:38 AM posted to rec.aviation.soaring
Fred Blair
Can't you change the internal battery before it gets real low without
breaking the seal?
On Aug 25, 10:54 pm, Sam Discusflyer
Steve Michalik
delivery.
UH
Old August 27th 08, 04:50 AM posted to rec.aviation.soaring
Paul Remde
Hi,
Yes, it is possible to change the backup battery without breaking the seal.
Just keep the unit powered with 12V power while replacing the backup
battery.
The customer that started this thread had the backup battery get too low and
die before it was replaced. The unit then had a security failure and needs
re-sealing.
Paul Remde
"Fred Blair" wrote in message
breaking the seal?
it
Steve Michalik
delivery.
UH
Sealing The PIK-20B Canopy P. Corbett Soaring 5 August 21st 05 09:32 PM
Sealing an ASW 28 canopy Bob Caldwell Soaring 13 August 10th 05 10:59 PM
Sealing a Schweizer; 1-35 mainly TOM RENT Soaring 0 April 11th 04 09:46 PM
Libelle Gap Sealing Owain Walters Soaring 4 April 11th 04 08:13 PM
sealing cork float against gasoline - how to... jt Home Built 13 July 18th 03 11:51 PM
