Why nitrogen?
Old September 19th 08, 02:59 AM posted to rec.aviation.piloting
Mick[_2_]
Default Why nitrogen?
"Bertie the Bunyip" wrote in message
| Doubt it. Would you ever feel better if you were maxie?
| Bertie
Maxie feel fine.
  #82
Mick[_2_]
| "Mick" @_#`~#@.^net wrote in :
| "Mick" @_#`~#@.^net wrote in news:86hAk.14226$Dj1.12895
| @newsfe01.iad:
| Aww, and now you cuttin and pasting your replies..
| Bwawahwhhahwhahwhahwhahhwhahwhahwhahwhahwhhahwhahh wha!
| Bertie
| Learn to read.
| I know how. Read many many books.
| I didn't cut and paste anything. Just your head rattling
| again.
| Yeh, OK illiterate boi.
| Bertie
| You're a cross posting dumb ass.
| Snort!
| bertie
  #83
Old September 19th 08, 03:00 AM posted to rec.aviation.piloting
Mick[_2_]
| "Mick" @_#`~#@.^net wrote in news:Z0hAk.14223$Dj1.9558
| @newsfe01.iad:
| "Mick" @_#`~#@.^net wrote in message
| "Mick" @_#`~#@.^net wrote in news:fUgAk.14183$Dj1.8609
| @newsfe01.iad:
| Learn to read...
| Bertie
| Why you can't.
| And you might learn to write.
| Bertie
| Why you can't.
| Yeh. You really don't realise what you're saying here, do you,
| illiterate boi?
| Bertie
| Why you don't?
| And there it is again..
| Good thing there's usually a picture on the mens room door or
| you'd
| be
| peeing in the transformer room, eh?
| Zaaaaaaapppp!
| Bertie
| Why not you do.
| And this my good friends, is how you keep a moron busy for 30
| minutes.
| aww, give me some credit Maxine. It's been months now.
| bertie
| Oh no! You're wearing me down!
| Stoooooop!
| Bertie
  #84
Mick[_2_]
| "Peter Dohm" wrote in news:csYzk.30661
| $kh2.3884
| @bignews3.bellsouth.net:
| "Viperdoc" wrote in
| So, the O2 fueled an already existing fire or caused it?
| I suspect that pumping the oxygen into the system somehow
| started
| the fi it probably is a new definition for the term "hot
| start"
| Mm, nice.
| You heard about this?
| http://www.gadling.com/2007/12/16/qu...tenance-fills-
| oxygen-
| tan
| ks- with-nitrogen/
| Sounds worse than it was, but still....
| Bertie
| It appears that they were lucky and the oxygen was'nt needed; but
| it
| does remind me of some of the speculation surrunding the Paine
| Stewart
| case. Two hypotheses around my local airport were that 1) the
| tank
| was inadvertantly filled with nitrogen or 2) that someone misread
| the
| labeling on the regulator on/off handle--which is
| counterintuitively
| labeled with "on" or "off" and arrows pointing which direction to
| turn
| the knob for the desired result. I don't recall whether the case
| was
| ever fully resolved; but a lot of pilots found a couple of areas
| worthy of their maximum vigilance!
| Moe likely was they passed out before they even realised they were
| in
| trouble on that one. More easily done than I'd certainly expect.
| Bertie
| That was also suggested, and could well be the real answer.
| Doesn't really matter. It's done and the only thing that matters is
| that
| all the possibilities are looked at and equipment and training are
| geared towards avoiding a repetition of the accident. Easier said
| than
| done.
| Bertie
| Guess again fjukkktard.
| Bertie
  #85
Mick[_2_]
| "Peter Dohm" wrote in news:csYzk.30660
| $kh2.574
| "JGalban via AviationKB.com" u32749@uwe wrote in message
| news:8a4950eac1beb@uwe...
| Peter Dohm wrote:
| The only difference that would make nitrogen seen really
| beneficial
| to me would be in the case of an aircraft which is kept hangared
| and
| seldom operated. Then, if the tire threads last a number of
| years,
| and the tires are sheltered from UV radiation, the inert nature
| of
| the nitrogen could be usefull.
| In theory, perhaps. In practice, tires oxidize from the outside
| as
| well
| as
| the inside. I've noticed that every time I've bought expensive,
| long-life tires, they have to be chucked because the sidewalls
| are
| rotting, even though
| the tread is still good. It's not just air, but pollutants
| (particularly in
| the cities). Ozone, a common urban pollutant, is particularly
| bad
| for tires.
| John Galban=====N4BQ (PA28-180)
| Ordinarily, I would just let this slide; but since the greenies
| have
| decided that CO2 (which is nature's means of recycling oxygen) and
| O3
| (which is nature's cleanser of the atmosphere) are "pollutants"
| according to the strange reasoning of their adled brains,
| Here is an explanation for you.
| If you find it too difficult to understand I'll have a look around
| for
| the Litle Golden Book of Wonder version for you.
| http://earthguide.ucsd.edu/globalcha...arming/03.html
| Bertie
| You are too kind!
| BTW, it did make a good case for the expansion of nuclear power--
| which
| I
| have long favored.
| No, it didn't.
| Maybe if I find something with pictures for you.
| Bertie
| Shooting for another AUP violation fjukkkwit?
| Bertie''
  #86
Old September 19th 08, 03:04 AM posted to rec.aviation.piloting
Mick[_2_]
| "Mick" @_#`~#@.^net wrote in news |
| "Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote in
| "Viperdoc" wrote in message
| Need to see the aging data on rubber kept in air versus nitrogen.
| I've seen it at work, fwiw. Some difference.
| But, for car tires, I would say there is more hype than benefit.
| Used to put it in the tires of my light plane, mostly because it was
| free.
| I flew off grass and reckoned they'd rot before I wore them out
| anyway, so I might as well get the most bang for the buck out of the
| tires.
| Bertie
| Snort!
| Bertie
  #87
Old September 19th 08, 03:05 AM posted to rec.aviation.piloting
Mick[_2_]
Default Why maxine will just never get it.
| "Mick" @_#`~#@.^net wrote in news:bBgAk.13838$Dj1.12866
| @newsfe01.iad:
| John Godwin wrote in
| news:Xns9B1BD7A3321FBAvSvcs@ 208.49.82.60:
| In the case of light plane tires, I agree with you that really
| dry
| air should work well enough to make the issue trivial. But, if
| you need nitrogen for any other reason, it is the cheapest thing
| that I know of in an L bottle or larger and using it in the tires
| may be essentially free--because you may have to pay rental on
| the
| tanks if they are not refilled at a prescribed interval.
| My daughter is a Crew Chief on a C-130 Herc and said that Nitrogen
| is used in the struts.
| Your daughter smokes cigars?
| Bertie
| You're a dumb ass.
| Nope.
| Bertie
| Please stop! You're hurting meeeeeee!
| Bwahwhahwhahwhahwhhahwh!
| Bertie
  #88
Old September 19th 08, 03:09 AM posted to rec.aviation.piloting
Mick[_2_]
| "Bob F." wrote in
| "Viperdoc" wrote in
| The thread on brakes raised a question from the past- why nitrogen
| in the tires of big jets and heavies? Air is around 78% nitrogen
| anyway, and the coefficient of expansion of the remaining 20%
| that's
| oxygen can't make that much difference in volume.
| Why not just use dry air? I couldn't imagine that dry air or dry
| nitrogen could make that much difference in corrosion, either.
| I seem to recall someone giving me the rationale for this a long
| time ago, but also seem to remember thinking it didn't make that
| much sense at the time.
| Well, the greasemonkies say it preserves the rubber. Having said
| that
| we go
| through them pretty quick and even considering retreads there
| wouldn't be years of exposure or anything..
| Wheel fires may be another good reason...
| bertie
| Right, they are called Napoleon tires. You heard of "Napoleon Blown
| Apart" haven't you. :-)
| groan!
| A guy i used to work with witnessed the aftermath of someone trying
| to
| fill a 707 nosewheel wiht an incorrect type reduction on the bottle.
| The
| guy was pretty much vaporised. My friend spent months as a witness in
| the subsequent lawsuit.
| Bertie
| And you're a fjukktard wannbe just about anythign.
| Bertie
Give'm hell, Squirty ****drip.
  #89
Old September 19th 08, 03:21 AM posted to rec.aviation.piloting
Mick[_2_]
| Bertie
I love the radical cross posts. Shows your lever of desperation.
Calling all kooks, calling all kooks. I'm getting my ass kicked, I need back
up!
  #90
Old September 19th 08, 04:55 AM posted to rec.aviation.piloting
Viperdoc[_5_]
Mick:
Not to change the subject, but why do you think nitrogen is better than dry
air for tires and struts?
Tire inflation with Nitrogen or ? [email protected] Home Built 52 April 29th 07 04:49 AM
Filling with nitrogen scott moore Owning 21 December 8th 06 07:48 PM
172 Nosewheel Struts Leak Nitrogen jls Owning 4 April 9th 04 06:28 PM
