Tire inflation with Nitrogen or ?
Old April 11th 07, 05:59 PM posted to rec.aviation.homebuilt
Default Tire inflation with Nitrogen or ?
Michelin recomends inflating tires with nitrogen. What about Argon? I
got a bottle of argon I use in Mig welding aluminum. Isn't argon
better than Nitrogen? What about the common 75% Argon and 25% CO2
welding mixture?
Old April 11th 07, 10:01 PM posted to rec.aviation.homebuilt
Scott[_1_]
What about hydrogen? It's lighter than air and will boost lift at the
same time
Scott
welding mixture?
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Old April 11th 07, 10:46 PM posted to rec.aviation.homebuilt
Maxwell
welding mixture?
I'm not sure about the other aspects, but nitrogen is about 1/3 the price.
Old April 11th 07, 10:47 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
same time
Scott
Little bitty molecules will leak out faster.
Old April 11th 07, 11:04 PM posted to rec.aviation.homebuilt
Dan[_2_]
same time
Scott
The nice thing about filing tyres with hydrogen is one can easily
find leaks with a lighted match.
Dan, U.S. Air Force, retired
Old April 11th 07, 11:07 PM posted to rec.aviation.homebuilt
Dan[_2_]
Gig 601XL Builder wrote:
same time
Scott
Not as fast as helium which has a smaller molecule. For a good time
partially fill the tyre with water.
Old April 11th 07, 11:54 PM posted to rec.aviation.homebuilt
Paul Tomblin
In a previous article, "Maxwell" said:
roups.com...
welding mixture?
And ordinary compressed air is already 80% nitrogen.
Paul Tomblin http://blog.xcski.com/
"Faced with the prospect of rereading this book, I would rather have my brains
ripped out by a plastic fork." - Charles Cooper reviews the new Gates book.
http://zdnet.com.com/2100-1107-514105.html
Old April 12th 07, 12:08 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Wed, 11 Apr 2007 22:54:43 +0000 (UTC),
groups.com...
welding mixture?
But the oxygen and ozone, along with a few other gasses does
accellerate the deterioration of the rubber, and the nitrogen stays in
better than the rest (co2 included) Also more temperature stable,
pressure-wize.
Posted via a free Usenet account from http://www.teranews.com
Old April 12th 07, 12:26 AM posted to rec.aviation.homebuilt
Maxwell
clare at snyder.on.ca wrote in message
egroups.com...
welding mixture?
price.
pressure-wize.
Yeah, I forgot to mention the pressure aspect until after I hit send. But a
lot of the racers love it because they have less pressure rise as the tires
heat up. Probably the best reason I can see for using it in a auto.
Especially in summer.
Old April 12th 07, 12:59 AM posted to rec.aviation.homebuilt
Peter Dohm
welding mixture?
price.
pressure-wize.
a
tires
When I saw that 8 replies were already posted, I was sure that someone had
provided a serious response; but it was not bo be.
I have long forgotten the periodic table, so I used Wiki. Argon is shown as
atomic number 18, so it is a good sized molecule--although possibly smaller
than N2--and is supposedly used when Nitrogen is not sufficiently inert.
It seems like it should work just fine, even if mixed later with dry
nitrogen or even with air; but I would call the tire manufacturer and ask.
Peter
Filling with nitrogen scott moore Owning 21 December 8th 06 07:48 PM
Tire tread wear vs inflation pressure Ben Jackson Owning 22 October 6th 06 04:35 AM
FS: New 1-26 Tire Slick Soaring 0 April 20th 04 01:27 AM
172 Nosewheel Struts Leak Nitrogen jls Owning 4 April 9th 04 06:28 PM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
