Why nitrogen?
Old September 19th 08, 06:17 PM posted to rec.aviation.piloting
Mick[_2_]
Default Why nitrogen?
"Bertie the Bunyip" wrote in message
| "Mick" @_#`~#@.^net wrote in :
| Xref: news rec.aviation.piloting:619331
| Path:
| news.glorb.com!npeer01.iad.highwinds-media.com!news.highwinds-
| media.com
| !feed-me.highwinds-media.com!post02.iad.highwinds-media.com!
| newsfe03.ia
| d.POSTED!7564ea0f!not-for-mail From: "Mick" @_#`~#@.^net
| Newsgroups: rec.aviation.piloting
| References:
| Subject: Why
| nitrogen? Lines: 109
| X-Priority: 3
| X-MSMail-Priority: Normal
| X-Newsreader: Microsoft Outlook Express 6.00.2900.5512
| X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.5579
| Message-ID:
| NNTP-Posting-Host: 68.13.227.40
| X-Complaints-To:
| X-Trace: newsfe03.iad 1221789611 68.13.227.40 (Fri, 19 Sep 2008
| 02:00:11 UTC) NNTP-Posting-Date: Fri, 19 Sep 2008 02:00:11 UTC
| Organization: Cox
| Date: Thu, 18 Sep 2008 21:00:03 -0500
| | "Mick" @_#`~#@.^net wrote in news:Z0hAk.14223$Dj1.9558
| | @newsfe01.iad:
| | "Mick" @_#`~#@.^net wrote in message
| | "Mick" @_#`~#@.^net wrote in news:fUgAk.14183$Dj1.8609
| | @newsfe01.iad:
| | Learn to read...
| | Bertie
| | Why you can't.
| | And you might learn to write.
| | Bertie
| | Why you can't.
| | Yeh. You really don't realise what you're saying here, do
| | you, illiterate boi?
| | Bertie
| | Why you don't?
| | And there it is again..
| | Good thing there's usually a picture on the mens room door or
| | you'd
| | be
| | peeing in the transformer room, eh?
| | Zaaaaaaapppp!
| | Bertie
| | Why not you do.
| | And this my good friends, is how you keep a moron busy for 30
| | minutes.
| | aww, give me some credit Maxine. It's been months now.
| | bertie
| | You're a cross posting dumb ass.
| | Oh no! You're wearing me down!
| | Stoooooop!
| | Bertie
| I'm sooooo tired!
| Bwawhahwhahwhahwhahwhahhwha!
| Bertie
  #102
Old September 19th 08, 06:18 PM posted to rec.aviation.piloting
Mick[_2_]
| Xref: news rec.aviation.piloting:619332
| Path:
| media.com
| newsfe03.ia
| References:
| Subject: Why
| nitrogen? Lines: 96
| X-Priority: 3
| Message-ID:
| X-Complaints-To:
| X-Trace: newsfe03.iad 1221789626 68.13.227.40 (Fri, 19 Sep 2008
| 02:00:26 UTC) NNTP-Posting-Date: Fri, 19 Sep 2008 02:00:26 UTC
| Organization: Cox
| Date: Thu, 18 Sep 2008 21:00:18 -0500
| | "Peter Dohm" wrote in news:csYzk.30661
| | $kh2.3884
| | @bignews3.bellsouth.net:
| | "Viperdoc" wrote in
| | So, the O2 fueled an already existing fire or caused it?
| | I suspect that pumping the oxygen into the system somehow
| | started
| | the fi it probably is a new definition for the term "hot
| | start"
| | Mm, nice.
| | You heard about this?
http://www.gadling.com/2007/12/16/qu...tenance-fills-
| | oxygen-
| | tan
| | ks- with-nitrogen/
| | Sounds worse than it was, but still....
| | Bertie
| | It appears that they were lucky and the oxygen was'nt needed;
| | but
| | it
| | does remind me of some of the speculation surrunding the Paine
| | Stewart
| | case. Two hypotheses around my local airport were that 1) the
| | tank
| | was inadvertantly filled with nitrogen or 2) that someone
| | misread
| | the
| | labeling on the regulator on/off handle--which is
| | counterintuitively
| | labeled with "on" or "off" and arrows pointing which direction
| | to
| | turn
| | the knob for the desired result. I don't recall whether the
| | case
| | was
| | ever fully resolved; but a lot of pilots found a couple of
| | areas worthy of their maximum vigilance!
| | Moe likely was they passed out before they even realised they
| | were
| | in
| | trouble on that one. More easily done than I'd certainly expect.
| | Bertie
| | That was also suggested, and could well be the real answer.
| | Doesn't really matter. It's done and the only thing that matters
| | is
| | that
| | all the possibilities are looked at and equipment and training are
| | geared towards avoiding a repetition of the accident. Easier said
| | than
| | done.
| | Bertie
| | Guess again fjukkktard.
| | Bertie
| Bertie
  #103
Mick[_2_]
| Xref: news rec.aviation.piloting:619333
| Path:
| wns11feed!worldnet.att.net!63.218.45.11!nx02.iad01 .newshosting.com!
| news
| hosting.com!69.16.185.11.MISMATCH!npeer01.iad.high winds-media.com!
| news.
| highwinds-media.com!feed-me.highwinds-media.com!post02.iad.highwinds-
| me
| dia.com!newsfe03.iad.POSTED!7564ea0f!not-for-mail From: "Mick"
| @_#`~#@.^net Newsgroups: rec.aviation.piloting
| References:
| 8a4950eac1beb@uwe
| Subject: Why
| nitrogen? Lines: 279
| X-Priority: 3
| Message-ID:
| X-Complaints-To:
| X-Trace: newsfe03.iad 1221789648 68.13.227.40 (Fri, 19 Sep 2008
| 02:00:48 UTC) NNTP-Posting-Date: Fri, 19 Sep 2008 02:00:48 UTC
| Organization: Cox
| Date: Thu, 18 Sep 2008 21:00:41 -0500
| | "Peter Dohm" wrote in news:csYzk.30660
| | $kh2.574
| | "JGalban via AviationKB.com" u32749@uwe wrote in message
| | news:8a4950eac1beb@uwe...
| | Peter Dohm wrote:
| | The only difference that would make nitrogen seen really
| | beneficial
| | to me would be in the case of an aircraft which is kept
| | hangared
| | and
| | seldom operated. Then, if the tire threads last a number of
| | years,
| | and the tires are sheltered from UV radiation, the inert
| | nature
| | of
| | the nitrogen could be usefull.
| | In theory, perhaps. In practice, tires oxidize from the
| | outside
| | as
| | well
| | as
| | the inside. I've noticed that every time I've bought
| | expensive, long-life tires, they have to be chucked because
| | the sidewalls
| | are
| | rotting, even though
| | the tread is still good. It's not just air, but pollutants
| | (particularly in
| | the cities). Ozone, a common urban pollutant, is particularly
| | bad
| | for tires.
| | John Galban=====N4BQ (PA28-180)
| | Ordinarily, I would just let this slide; but since the greenies
| | have
| | decided that CO2 (which is nature's means of recycling oxygen)
| | and
| | O3
| | (which is nature's cleanser of the atmosphere) are "pollutants"
| | according to the strange reasoning of their adled brains,
| | Here is an explanation for you.
| | If you find it too difficult to understand I'll have a look
| | around
| | for
| | the Litle Golden Book of Wonder version for you.
http://earthguide.ucsd.edu/globalcha...arming/03.html
| | Bertie
| | You are too kind!
| | BTW, it did make a good case for the expansion of nuclear power--
| | which
| | I
| | have long favored.
| | No, it didn't.
| | Maybe if I find something with pictures for you.
| | Bertie
| | Shooting for another AUP violation fjukkkwit?
| | Bertie''
| Snort!
| Bertie
  #104
Mick[_2_]
| Xref: news rec.aviation.piloting:619347
| Path:
| nx01.iad01.newshosting.com!newshosting.com!69.16.1 85.21.MISMATCH!
| npeer0
| 3.iad.highwinds-media.com!news.highwinds-media.com!feed-me.highwinds-
| me
| dia.com!post01.iad.highwinds-media.com!newsfe03.iad.POSTED!7564ea0f!
| not
| References:
| Subject: Why
| nitrogen? Lines: 13
| X-Priority: 3
| Message-ID:
| X-Complaints-To:
| X-Trace: newsfe03.iad 1221790872 68.13.227.40 (Fri, 19 Sep 2008
| 02:21:12 UTC) NNTP-Posting-Date: Fri, 19 Sep 2008 02:21:12 UTC
| Organization: Cox
| Date: Thu, 18 Sep 2008 21:21:01 -0500
| | Bertie
| I love the radical cross posts. Shows your lever of desperation.
| Actually, it just shows the level of enertainment you're providing. I
| don;t get desperate, maxine....
| Calling all kooks, calling all kooks. I'm getting my ass kicked, I
| need back up!
| They'll come a runnin for you i'm sure Maxine.
| Bertie
  #105
Mick[_2_]
| Xref: news rec.aviation.piloting:619353
| Path:
| nx01.iad01.newshosting.com!newshosting.com!69.16.1 85.11.MISMATCH!
| npeer0
| 1.iad.highwinds-media.com!news.highwinds-media.com!feed-me.highwinds-
| me
| dia.com!post02.iad.highwinds-media.com!newsfe08.iad.POSTED!7564ea0f!
| not
| References:
| Subject: Why nitrogen?
| Lines: 14
| X-Priority: 3
| Message-ID:
| X-Complaints-To:
| X-Trace: newsfe08.iad 1221797698 68.13.227.40 (Fri, 19 Sep 2008
| 04:14:58 UTC) NNTP-Posting-Date: Fri, 19 Sep 2008 04:14:58 UTC
| Organization: Cox
| Date: Thu, 18 Sep 2008 23:14:51 -0500
| "Viperdoc" wrote in message
| | Mick:
| | Not to change the subject, but why do you think nitrogen is better
| | than
| dry
| | air for tires and struts?
| Proven results in high performance use.
| But you said before that it wasn't true, fjukkktard.
| Make up your so called mind Maxine.
| Bertie
  #106
Mick[_2_]
| Xref: news rec.aviation.piloting:619346
| Path:
| npeer0
| me
| dia.com!post02.iad.highwinds-media.com!newsfe03.iad.POSTED!7564ea0f!
| not
| References:
| Subject: Why
| nitrogen? Lines: 207
| X-Priority: 3
| Message-ID:
| X-Complaints-To:
| X-Trace: newsfe03.iad 1221790182 68.13.227.40 (Fri, 19 Sep 2008
| 02:09:42 UTC) NNTP-Posting-Date: Fri, 19 Sep 2008 02:09:42 UTC
| Organization: Cox
| Date: Thu, 18 Sep 2008 21:09:35 -0500
| | "Bob F." wrote in
| | "Viperdoc" wrote in
| | The thread on brakes raised a question from the past- why
| | nitrogen in the tires of big jets and heavies? Air is around
| | 78% nitrogen anyway, and the coefficient of expansion of the
| | remaining 20%
| | that's
| | oxygen can't make that much difference in volume.
| | Why not just use dry air? I couldn't imagine that dry air or
| | dry nitrogen could make that much difference in corrosion,
| | either.
| | I seem to recall someone giving me the rationale for this a
| | long time ago, but also seem to remember thinking it didn't
| | make that much sense at the time.
| | Well, the greasemonkies say it preserves the rubber. Having said
| | that
| | we go
| | through them pretty quick and even considering retreads there
| | wouldn't be years of exposure or anything..
| | Wheel fires may be another good reason...
| | bertie
| | Right, they are called Napoleon tires. You heard of "Napoleon
| | Blown Apart" haven't you. :-)
| | groan!
| | A guy i used to work with witnessed the aftermath of someone
| | trying
| | to
| | fill a 707 nosewheel wiht an incorrect type reduction on the
| | bottle.
| | The
| | guy was pretty much vaporised. My friend spent months as a witness
| | in the subsequent lawsuit.
| | Bertie
| | And you're a fjukktard wannbe just about anythign.
| | Bertie
| Give'm hell, Squirty ****drip.
| I always do.
| Bertie
  #107
Mick[_2_]
| Xref: news rec.aviation.piloting:619334
| Path:
| nx02.iad01.newshosting.com!newshosting.com!69.16.1 85.11.MISMATCH!
| npeer0
| me
| not
| References:
| Subject: Why
| nitrogen? Lines: 396
| X-Priority: 3
| Message-ID:
| X-Complaints-To:
| X-Trace: newsfe03.iad 1221789899 68.13.227.40 (Fri, 19 Sep 2008
| 02:04:59 UTC) NNTP-Posting-Date: Fri, 19 Sep 2008 02:04:59 UTC
| Organization: Cox
| Date: Thu, 18 Sep 2008 21:04:52 -0500
| | "Mick" @_#`~#@.^net wrote in news | |
| | "Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote in
| | Need to see the aging data on rubber kept in air versus
| | nitrogen.
| | I've seen it at work, fwiw. Some difference.
| | But, for car tires, I would say there is more hype than benefit.
| | Used to put it in the tires of my light plane, mostly because it
| | was free.
| | I flew off grass and reckoned they'd rot before I wore them out
| | anyway, so I might as well get the most bang for the buck out of
| | the tires.
| | Bertie
| | Snort!
| | Bertie
| Snort!
| bertie
  #108
Old September 19th 08, 06:29 PM posted to rec.aviation.piloting
Mick[_2_]
| Have you trained at the Anthony Atkielski School of Circular Logic? Would
| you care to cite some actual data that says nitrogen is superior to dry
air
| for tires or struts?
Why? Unlike a anal ******* like you, I have no probem accepting decision of
NASCAR and so many aircraft companies.
| My hypothesis is that nitrogen or argon is in some way superior to dry air
| is simply an old wive's tale, not substantiated by data. So far, I have
| heard a lot of rationales, but not seen any data. In graduate school in
| organic chemistry, we used dry nitrogen or argon to distill a variety of
| compounds that were sensitive to water (nothing like distilling
| tetrahydrofuran over sodium metal to remove even trace water). It was like
| an explosion waiting to happen.
I could give a **** less about your hypothesis. What qualifies you to
question so many experts?
| None of the posts I have read has offered a logical explanation as to why
| nitrogen is superior in some way to dry air.
I don't know anyone that give a **** what you think.
| If you think you, or anyone else has something to add to this topic,
please
| feel free.
Here, www.google.com is your friend.
| I could give a **** about you or Bertie, the logic of those interactions
has
| long been gone. I challenge you or anyone else to give some information
that
| actually educates the rest of us, because I honestly don't know the
answer.
First you need to find someone that gives a **** about your personal doubts.
Have you tried therapy.
  #109
Old September 19th 08, 06:31 PM posted to rec.aviation.piloting
Mick[_2_]
"Robert M. Gary" wrote in message
On Sep 16, 4:04 pm, "Vaughn Simon"
I just got new tires for my wife's car. They're usnig Nitrogen too.
They put green caps on the valve steam to show its not air.
Yes, those green caps have proven to be much better at keeping the snake
oil
inside the tire where it belongs. Also, I have never once seen a car with
green
valve stem caps get attacked by elephants, (but that is just anecdotal
evidence
and your experience may vary).
Well the Nitrogen they used was free so I reallly don't care too much
if its better or not.
-Robert
I think that's the point. Cost.
In applications where cost is not a big issue, it becomes the default
because of somewhat superior quality.
  #110
Old September 19th 08, 07:27 PM posted to rec.aviation.piloting
Peter Dohm
I am curious regarding the tire and strut pressures used on the Baron.
The treatise from several Ford Motor Company engineers, which was referenced
elsewhere in the thread, appeared to only be on the web for sale and as a
second hand source. Therefore, I am left with my partial pressure
model--which simply does not justify using inert gas in tires at 60 or 70
psi (roughly 4 to 5 ATM) nor in struts at roughly twice that
pressure--unless you just happen to have it in the shop.
OTOH, on a heavy with the struts presumably pressurized to 100 ATM or more,
the partial pressure would would dramatically exceed 20 ATM of pure oxygen
on full bounce--so inert gas makes good sense.
Based on my presumption of the pressures involved for a light aircraft, dry
inert gas is mainly justified by eliminating the need for a good quality
dryer. In anything like normal service, it sounds like hype to me as well.
Tire inflation with Nitrogen or ? [email protected] Home Built 52 April 29th 07 04:49 AM
Filling with nitrogen scott moore Owning 21 December 8th 06 07:48 PM
172 Nosewheel Struts Leak Nitrogen jls Owning 4 April 9th 04 06:28 PM
