Welded Patch Repair question
Old November 8th 08, 12:11 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default Welded Patch Repair question
On Sat, 8 Nov 2008 00:10:02 -0600, "Highflyer" wrote:
On an old airplane like the Auster, which was probably built with
1020 tubing and not with 4130 tubing, you don't even have to use
4130 for the patch. :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
John
Austers are a mite more sophisticated than that.
the fuselage tubes are in the pommy T45 steel alloy.
T45 equates to an alloy with 45 tons per square inch tensile strength.
I've always thought of it as a precursor to 4130.
Stealth Pilot
Stressed Skin Repair Question RPM the A&P Home Built 9 July 16th 08 04:59 AM
4130 can't be OA welded? wright1902glider Home Built 61 January 4th 08 05:19 AM
Magneto Repair vs Overhaul Question. Ebby Home Built 6 February 24th 07 05:55 PM
172 Repair question Brad Mallard Home Built 2 June 11th 04 02:54 AM
172 Repair question Brad Mallard Aviation Marketplace 3 June 11th 04 02:54 AM
