Manual fuel transfer pumps
Old March 15th 09, 05:45 AM posted to rec.aviation.homebuilt
Default Manual fuel transfer pumps
On Mar 14, 9:56*pm, Brian Whatcott wrote:
What's the mission? Are you fueling an ultralite?
In flight transfer of fuel from aux tank to main header tank in a
Bowers Fly Baby.
That suggests a minimum transfer rate of a pint a minute would be needed
to keep up with the greatest conceivable flow - but a gallon a minute
would do nicely?
Brian W
Header tank is 16 gal. After that has gone down to 10 the aux fuel
can be sent to it. That allows approximately 2 hours to transfer the
6 aux gallons to the main (allowing for half hour reserve). Not that
I want to do it that slowly. Actually, for optimal CG it would be
nice to send the aux up when the main is down to reserve so that would
require a much faster rate.
Old March 15th 09, 05:49 PM posted to rec.aviation.homebuilt
Tri-Pacer[_3_]
Bowers Fly Baby.
Do you have an electrical system? If so how about one of the "clicker" pumps
like the Cherokee uses. They are made in uncertified versions that are quite
cheap. The Ercoupe O-200 engine installation STC uses one of the uncertified
versions to pump from the wing tanks to the header tank.
If you have C-75 or 85 why not fit an engine driven pump?
Cheers:
Paul
N1431A
KSDM
Old March 15th 09, 07:43 PM posted to rec.aviation.homebuilt
Bowers Fly Baby.
Cheers:
Paul
N1431A
KSDM
electrical system is gel cell. Engine is A75
Thinking about this pump. Half a pound and $35
http://www.sigmfg.com/cgi-bin/dpsmar...883.html?E+Sig
Fuel transfer pump rmhou at yahoo.com Home Built 8 August 20th 07 02:35 AM
Trailer tow vehicle fuel pumps Steve Leonard Soaring 2 March 4th 07 10:35 PM
Trailer tow vehicle fuel pumps Bill Daniels Soaring 15 March 4th 07 04:59 PM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 06:53 PM
Fuel Transfer Placards Ben Smith Owning 22 October 16th 03 03:32 PM
