Manual fuel transfer pumps
Old March 10th 09, 10:21 PM posted to rec.aviation.homebuilt
Default Manual fuel transfer pumps
Looking for suggestions for a aux fuel system transfer pump.
Originally thought of a classic wobble pump but have had tough time
finding and old one or an affordable new one. Have considered 12 volt
but prefer manual.
This RC pump looks promising but a bit slow: http://www.dbproducts.com/store/shtr.htm
I've only got 5-6 gal to move so don't really need anything big I
don't have a lot of room and weight is an issue of course.
Old March 10th 09, 10:54 PM posted to rec.aviation.homebuilt
Bob Hoover
*I've only got 5-6 gal to move so don't really need anything big *I
So go down to your FLAPS and ask to see the BIGGEST manual fuel pump
in stock. For manual operation you'll want to find some lighter
springs. On some, the actuating arm is long enough so that,with the
pump mounted in a suitable position, you can put a threaded ball on
the thing and use it for the handle. Otherwise, you rig a frame to
support the pump then position & pivot a rod or shaft to use as the
pump-handle.
The problem with real fuel pumps is that their output is quite small.
At a steady 60 mph a big V8 is only putting out mebbe 30hp...
something less than 3 gallons per hour. Since an automotive pump is a
variable-output device -- that is, it's output is a function of the
PRESSURE on the outlet -- to get the maximum amount of fuel per stroke
you want to be sure you're delivering pressure into an 'open' tank.
Tricks I've seen or tried: The use of TWO automotive fuel pumps,
rigged so that one pumps on the forward stroke, the other on the aft
stroke. This thing was the closest I've ever FELT to a real wobble-
type TRANSFER pump (as opposed to a primer) in that it required only
finger pressure to deliver about 4 oz per fore-aft 'stroke'.... or
about 35 strokes per gallon.
Slightly better output (about 6oz/stroke) could be achieved using
those RUBBER primer-bulbs used with outboard motors fed by a remote
fuel tank. Rig a pair of them in a fixture of some sort that would
allow them to be mashed flat (or nearly so) by some kind of toggle-
action shoe. Definitely lighter than an automotive f uel pump but
probably more prone to leakage/wear, etc.
Why even consider pumps & primers? Because they come WITH the
required valving.
-R.S.Hoover
Old March 11th 09, 02:14 AM posted to rec.aviation.homebuilt
Maxwell[_2_]
but prefer manual.
What is you budget and max weight? They will both be deciding factors.
http://www.northerntool.com/webapp/w...9224_200129224
Old March 11th 09, 04:25 AM posted to rec.aviation.homebuilt
finding and old one or an affordable new one. *Have considered 12 volt
but prefer manual.
What is you budget and max weight? They will both be *deciding factors.
http://www.northerntool.com/webapp/w...roduct_6970_20...
way lighter, smaller and preferably cheaper than that example.
Old March 11th 09, 12:31 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
but prefer manual.
Then you need one that pumps way less.
Old March 14th 09, 05:00 AM posted to rec.aviation.homebuilt
On Mar 12, 12:38*am, Bryan Martin
In article
http://www.northerntool.com/webapp/w...roduct_6970_20....
How about this:http://tinyurl.com/b4ocs3
Bryan Martin
N61BM, CH 601 XL, Ram Subaru, Stratus redrive.
Bryan
That actually shows promise. Some of these cheap consumer grade pumps
actually pressurize the can with air to drive the gas out the filler
tube. Not suitable for a vented inflight system. Other piston pumps
I've seen are marketed for various fluids and specify that if used
with gasoline must be cleaned after each use, suggesting that they
really aren't tolerant of extended fuel exposure. This pump you've
found might in fact be made of fuel tolerant material since it's
marketed as a fuel specific pump. It's cheap, simple, lightweight...
I'm going to have to get my hands on one and check it out. Thanks for
bringing it to my attention. I was ready to give in and go electric
but this would be great if it checks out.,
Matt
Fly Baby N48ML
Old March 14th 09, 08:10 AM posted to rec.aviation.homebuilt
How about this:
That actually shows promise....This pump you've
Go ahead and give it a shot (since it's cheap enough), but it looks like
the one I bought at Cabella's a year or so ago for tanking up my Fly
Baby. Leaked like a sieve. Gave up on it within 15 seconds.
A friend of mine used a marine bilge pump for years to fill his T-18,
AFAIK, he didn't have any problems with it. This looks like what he was
using:
http://www.go2marine.com/product.do?no=86244F
They've even got an all-aluminum model for about a hundred bucks mo
http://www.thebosworthco.com/product...-H&Num=&S=1483
The manufacturer claims the pumps do not react to gasoline, but do not
recommend them for transferring fuel.
Old March 14th 09, 02:30 PM posted to rec.aviation.homebuilt
I'm going to have to get my hands on one and check it out. *Thanks for
bringing it to my attention. *I was ready to give in and go electric
Baby. *Leaked like a sieve. *Gave up on it within 15 seconds.
AFAIK, he didn't have any problems with it. *This looks like what he was
using:
Thanks Ron, I've been wondering where all the marine pumps were
hiding!
These still seem a little large. I once saw a tiny little wobble pump
in a mooney mite that was exactly what I need. No luck sourcing those
however...
Old March 14th 09, 05:17 PM posted to rec.aviation.homebuilt
Maxwell[_2_]
using:
hiding!
however...
What's the mission? Are you fueling an ultralite?
Old March 15th 09, 01:03 AM posted to rec.aviation.homebuilt
In flight transfer of fuel from aux tank to main header tank in a
Bowers Fly Baby.
Fuel transfer pump rmhou at yahoo.com Home Built 8 August 20th 07 01:35 AM
Trailer tow vehicle fuel pumps Steve Leonard Soaring 2 March 4th 07 09:35 PM
Trailer tow vehicle fuel pumps Bill Daniels Soaring 15 March 4th 07 03:59 PM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 05:53 PM
Fuel Transfer Placards Ben Smith Owning 22 October 16th 03 02:32 PM
