Measurement of CofG
Old January 11th 12, 11:29 PM posted to rec.aviation.soaring
Dan Marotta
Default Measurement of CofG
Why don't the manufactures publish the height to raise the tail as a
difference between the axle center lines above ground? Then you don't need
to cut or calculate.
Oh, gee... That'd be too simple.
"Hagbard Celine" wrote in message
If the shop has a digital protractor you could also convert the rise/
run to degrees, put the protractor on the specified part of the tail
boom and raise the tail until it reads the correct angle.
Arctan(rise/run) = angle in degrees
About 2.1 degrees, sloping down towards the tail in this case.
Old January 12th 12, 04:51 AM
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
Same question, hopefully same answer...could use a little more info.
I'm trying to put together a W&B event at our club, we're bringing in outside help from another club with a set of scales and the experience of knowing what to do.
WRT positioning the glider at the correct angle, my ship is an ASW-19b. Although my owners manual has a page dedicated to CG info, there's nothing in there about what procedure to use to actually weigh the thing. It's just a page with a CG envelope on it.
Now I did find on page 30 of the manual (a page that has general dimensions as well as specs for control deflections) a side view drawing with info presented as the thread starter discussed, mine says 1000 by 45.
SO, to do the procedure correctly, construct a small triangle with those dimensions, inflate the main wheel to proper pressure, put a level on the triangle, then raise the tail till I get a level bubble? It would seem to make sense that this is done with wings level laterally as well, correct? Lightly (fingertips) or is a wingstand under a tip ok? THEN, take the weights?
Finally, this will be the 4th W&B for this glider. All the ones done previously have had a "form" with a glider drawing on it and appropriate spots to fill in main wheel/tail wheel weights, etc. Where can we obtain "blanks" to fill in our ships for our event? We will have an A&P IA overseeing the process and signing off logbooks. As I said, I'm coordinating, so I'm trying to get all the info/materials each owner will need to have on hand at weigh-in so the event goes smoothly.
Thanks much,
Rob
ASW-19b
ZAP
Ps-sorry if this double posts...
Old January 12th 12, 09:55 AM posted to rec.aviation.soaring
Croft Brown
I am sure I am not on my own when I say I have an Excel spreadsheet with
the calculations for C of G to be done. It may not be pretty but it does
the job. If you want a copy email me.
Croft
45.
take the weights?
Thanks much,
Rob
ASW-19b
ZAP
RAS56
Old January 12th 12, 10:16 AM posted to rec.aviation.soaring
Croft Brown
Croft
45.
take the weights?
Thanks much,
Rob
ASW-19b
ZAP
RAS56
Old January 12th 12, 02:09 PM
Member
Croft,
If you could email it to me at:
aggies78 at gmail.com
That would be much appreciated!
Thanks.
Rob S.
Old January 12th 12, 03:05 PM posted to rec.aviation.soaring
James Thomson[_2_]
Thanks much,
Rob
ASW-19b
Try http://www.gliding.co.uk/bgainfo/tec...manual/4-1.pdf which is a good
guide to the process
Old January 12th 12, 03:32 PM posted to rec.aviation.soaring
Dan Marotta
Hey, Rob!
ZAP was my second glider. I flew her between April '88 and Nov '91.
Blast from the past!
"RAS56" wrote in message
45.
take the weights?
Thanks much,
Rob
ASW-19b
ZAP
RAS56
Old January 12th 12, 04:05 PM posted to rec.aviation.soaring
Mike[_37_]
Some do. The Mini Nimbus has the correct height to raise the tail skid
from the floor.
Makes things easier for sure.
difference between the axle center lines above ground? *Then you don't need
Oh, gee... *That'd be too simple.
Old January 12th 12, 05:48 PM posted to rec.aviation.soaring
Cliff Hilty[_2_]
When I did my Ventus (not a club plane) I did it with flying weight. IE I
started with me, flying gear, water ballast, drinking water, batteries ect.
in the plane. Being of sound ballast myself I needed to dump ballast to get
to gross weight. I did this with a stop watch and 5 gallon buckets under
the dump valves and had the "Weigher" tell me when I got to gross, stop and
record both time and gallons dumped, then continued to 9 lbs per sq ft,
stop and record, then dumped the rest. This gave me a very accurate amounts
in both gallons and time (seconds to dump for any wing loading I may want
to fly with.
Now I just time the fill time to half ballast and fly After all its a
Ventus and won't thermal worth a crap with full load
CH Ventus B
CH Ventus B
"If we are all "just dust in the wind", then I want to be at the top of a Huge Dust Devil!"
Old January 12th 12, 08:41 PM posted to rec.aviation.soaring
Andy[_1_]
One possible reason is that the height is not a constant for any
glider that has a compressible pneumatic tyre or a sprung landing
gear. Both have deflection that depends on the glider mass. That
same deflection would need to be applied to the tail height. It may
not be neglible at max gross wt.
Speaking of sprung landing gear - in some cases the deflection changes
not only the height but also the distance between the tyre/ground
contact point and the datum. That applies to modern Schleicher single
seaters and probably other gliders. The best plan is to do the weight
and ballance as defined by the manufacturer.
I also calculated my own pilot arm as I considered the generalities in
the manual to be unacceptable. That can be done with a reasonably
accurate bathroom scale under the tail as the calculation is
independent of weight on the main gear.
Andy (GY)
vibration measurement system Stu Fields Rotorcraft 9 May 27th 11 04:07 AM
fuel flow measurement khanindra jyoti deka Home Built 0 January 5th 05 04:34 AM
TAS measurement Bravo Delta Piloting 4 June 30th 04 11:55 PM
Time Measurement for Inspections O. Sami Saydjari Owning 15 April 7th 04 05:26 AM
units of measurement on altimeters Pat Norton Piloting 30 March 21st 04 06:00 AM
