Audio vario for the iphone
Old May 15th 12, 09:31 AM posted to rec.aviation.soaring
Ramy
Default Audio vario for the iphone
With nearly million iphone apps, I still can't find a simple audio vario app, one which can be used as a backup if all else fails or when flying gliders with mechanical varios. Non compensated and based only on GPS altitude, but still better than nothing. Graphic display optional. Any iphone app developers out there? Should be a simple app.
Ramy
Old May 15th 12, 01:07 PM posted to rec.aviation.soaring
Tony[_5_]
Ramy
make it a pellet variometer display and i might just be tempted to get an iphone
Old May 15th 12, 02:41 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
Ramy
@ Ramy - great idea!
@ Tony - LOL!
Not what you were asking for, but I have a Malletec mini audio vario
I've had for many years. Uncompensated, very small. Extremely well
supported by the maker. I've dropped mine and broken it - he repaired
(or replaced) it for free. Ten years later, it just quit working -
fixed for free again. Under $200, though I can't look up the price
right now....
Old May 15th 12, 04:20 PM posted to rec.aviation.soaring
db_sonic[_2_]
Ramy
This one for android with a trace:
https://play.google.com/store/apps/d...Beeper&hl=e n
Old May 15th 12, 07:45 PM posted to rec.aviation.soaring
Three Uniform
Aahh, the benefits of the nicely walled garden for the iSheep.
On my Android phone I run of course XCSoar.
A fully functional flight computer as a backup, not just a vario.
And my Moto Atrix is very readable in sunlight, even better than my
Ipaq310.
If I need to switch to the Atrix early in flight, I just plug it into
my USB outlet for power, to avoid the battery running out after 2-3
hours.
And finally, I like the larger 4' screen size on the Atrix.
3U
Old May 15th 12, 08:17 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
Ipaq310.
hours.
3U
Smokin' idea! AUDIO* vario for XCSoar!! Max, are you listening?? 6.4
maybe??
*GPS based for those of use with pressureless NMEA sources or internal
GPS only.
Old May 15th 12, 08:20 PM posted to rec.aviation.soaring
BruceGreeff
So - the question is - has anyone worked out how to connect an Android
device with XCSoar to Condor?
Ipaq310.
hours.
3U
Bruce Greeff
T59D #1771
Old May 15th 12, 09:10 PM posted to rec.aviation.soaring
Ipaq310.
hours.
3U
Bruce Greeff
T59D #1771
This method works perfectly to connect Condor to XCSoar via Wi-Fi link.
http://forum.condorsoaring.com/viewt...hp?f=1&t=12538
Robert
Old May 15th 12, 10:05 PM posted to rec.aviation.soaring
Ramy
Ramy
The same app is available for the iphone, but after reading the description it sounds like it is not using GPS altitude but using the camera instead to read the vario needle movement, or something strange like this. Maybe useful for someone who wants to add sound to mechanical vario, but not useful as a backup.
Old May 15th 12, 10:13 PM posted to rec.aviation.soaring
Ramy
Ipaq310.
hours.
3U
I don't think we are talking about any iphone limitation here. I am also using XCSoar on my Android Dell Streak, but this is not a backup audio vario. By backup I am looking for something else than my current system, in case of total failure (such as dead battery). Or when flying club gliders with no audio vario. The ability to pull out my iphone from my pocket and turn it into an audio vario will be very helpful. And yes, adding audio tone to XCSoar will also be a very nice feature. XCSoar has indeed an option to display a vario (But only in landscape mode from some reason), and adding tone to it will make it more useful.
Ramy
CAV 11 Audio Vario/no Audio ideas? (Cambridge) Gregg Leslie[_2_] Soaring 3 June 4th 11 12:08 AM
Schematics for Cambridge CVS50 vario and audio unit? Or anyoneselling a similar working audio variometer? Bret Soaring 0 August 30th 10 04:24 AM
FS: PIEP II audio vario - new Phil Jones Soaring 0 August 15th 10 09:35 PM
Cambridge L-Nav audio vario just ate it... Bruno Soaring 9 November 18th 09 10:49 PM
L-13 + TE + Audio Vario Ray Lovinggood Soaring 4 January 12th 05 03:21 AM
