Cambridge L-Nav audio vario just ate it...
Old November 13th 09, 10:50 PM posted to rec.aviation.soaring
Bruno
Default Cambridge L-Nav audio vario just ate it...
On my last flight my audio vario suddenly started to read a consistent
300-400 fpm too high for the present conditions. I have a mechanical
vario that remained accurate and on my L-Nav screen my average fpm
sink rate was correct. Any ideas what I can check? It was really
annoying when I was sinking at a true 300 fpm on glides but my audio
was telling me I was going up 100fpm. If only it was always that way
in real life!
Bruno - B4
Old November 13th 09, 11:26 PM posted to rec.aviation.soaring
Papa3
300-400 fpm too high for the present conditions. *I have a mechanical
sink rate was correct. *Any ideas what I can check? *It was really
was telling me I was going up 100fpm. *If only it was always that way
in real life! *
Bruno - B4
Hi Bruno,
What you wrote is a little confusing. I wonder if you meant that the
dial was showing high along with the audio tone, while the LNAV LCD
screen showed a believable average (and netto)? As you probably
know, it is possible to adjust the zero and gain on the vario through
the configure screen, and the manual tells you what the acceptable
zero number ranges are. It would at least be interesting to have a
look at those values and see what they show. But, it wouldn't
explain (at least to me) while the dial and audio are out of sync with
the other values.
Sounds like a trip to NK is in order.
P3
Old November 13th 09, 11:53 PM posted to rec.aviation.soaring
Uncle Fuzzy
in real life! *
Bruno - B4
Hi Bruno,
What you wrote is a little confusing. *I wonder if you meant that the
screen showed a believable average (and netto)? * *As you probably
zero number ranges are. * *It would at least be interesting to have a
look at those values and see what they show. * But, it wouldn't
the other values.
P3
That's interesting. I have an old Cambridge CAV series audio vario in
my Speed Astir. Every once in a great while, it will start to read
200-300 fpm climb when I'm NOT climbing. This usually happens several
hours into the flight, when I'm fairly tired of the annoying noises it
makes too much of the time anyhow. In its defense, it is probably just
trying to make up for the seemingly endless fields of sink that force
it to honestly inform me that I'm dropping like a frigging rock (and
have been for the last dozen miles). Perhaps it's just trying to cheer
me up?? I used to think maybe it was voltage related, when I was using
a 12v battery, but it does it even with my 14v setup.
Old November 14th 09, 12:13 AM posted to rec.aviation.soaring
Bruno
in real life! *
Bruno - B4
Hi Bruno,
the other values.
P3
Sorry for being confusing in my description. It is exactly as you
state. I will take a look at those values. Good idea. I wonder why
it would go so out of adjustment when it always was working properly
before?
Thanks for the ideas,
Bruno -B4
Old November 14th 09, 12:44 AM posted to rec.aviation.soaring
ZL
in real life!
Bruno - B4
Hi Bruno,
the other values.
P3
before?
Bruno -B4
Backup battery? All kinds of really weird stuff happens when they go
flat. Its a little internal coin sized battery. Easily replaced.
Or the sensor could have died, which means a trip to NK...
-Dave
ZL
Old November 14th 09, 12:51 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
I am betting with ZL. Data hold battery inside the L-Nav. I had one
that did that. Of course, on the first flight of a new to me plane,
so I had no idea what the varios were trying to tell me. Not that it
mattered, as there was no lift to speak of.
Steve
ZS
Old November 15th 09, 08:01 PM posted to rec.aviation.soaring
in real life! *
Bruno - B4
Look for internal leak on capacity side of fate of climb sensor.
Connected with tubing which gives up. TE suction causes flow through
sensor.
Good luck '
UH
Old November 15th 09, 09:09 PM posted to rec.aviation.soaring
jcarlyle
Ah, yes, the "fate of climb" sensor. I've got a whole new respect for
"final glide", now.
-John
sensor.
Good luck '
UH
Old November 18th 09, 07:32 PM posted to rec.aviation.soaring
Chip Bearden[_2_]
I had a problem with my LNAV some years ago. Can't recall details but
might have been similar symptoms to yours and caused by a faulty G-
meter. Turns out (1) I had a spare G-meter because mine had acted up a
few years earlier; I had contacted CAI, and they sent me a new one
that I never installed because the problem went away; and (2) I was
flying a regional at Sugarbush, VT, HQ of CAI at the time! Dave Ellis
himself came over after I landed and installed the new G-meter and
returned the software offsets the proper values (I had changed them in
the air that day in an attempt to "fix" the problem). He also wired up
my old Magellan handheld GPS (this was many years ago) so I had
automatic wind for the first time.
If you're into tinkering, I suppose you could remove the G-meter (it
just plugs in) to see if that makes the problem go away. I don't have
the manual in front of me but you might have to reconfigure the
instrument to work properly. Anyone have a thought on this?
Chip Bearden
ASW 24 "JB"
USA
Old November 18th 09, 10:49 PM posted to rec.aviation.soaring
Chip Bearden
ASW 24 "JB"
USA
You have to install a jumper across a couple pins when G meter is
removed.
Did once with help from ex Cambridge guy. Gary K at NK would know this
ine.
UH
CAV 11 Audio Vario/no Audio ideas? (Cambridge) Gregg Leslie[_2_] Soaring 3 June 4th 11 12:08 AM
FS: Cambridge CAV-II vario/audio/averager [email protected] Soaring 1 May 13th 09 01:41 AM
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 05:31 PM
Cambridge vario audio control Solo Soaring 4 October 23rd 06 01:03 AM
L-13 + TE + Audio Vario Ray Lovinggood Soaring 4 January 12th 05 03:21 AM
