My PIK-20 trailer jockey wheel needs replacement but cannot find any commercially available units which will fit. The shaft size needs to be 40mm to fit the built-in clamp system. I do not want to install a side mount clamped to the side as it will induce too much twist into the frame. Any working used units out there that will fit?
On Sunday, November 18, 2012 8:13:37 AM UTC-8, lynn wrote:
My PIK-20 trailer jockey wheel needs replacement but cannot find any commercially available units which will fit. The shaft size needs to be 40mm In the US a "jockey wheel" is most often referred to as a trailer jack. I Googled "jockey wheel 40mm" and came up with this: http://www.camperlands.co.uk/metal-j...mbly-40mm.html good luck, bumper |
| Thread Tools | |
| Display Modes | |
| Cobra Trailer Replacement Wheel | Chip Bearden | Soaring | 5 | September 29th 09 09:35 PM |
| Komet trailer wheel bearings | Dan[_6_] | Soaring | 7 | February 9th 09 07:13 AM |
| truck + 5th wheel RV + glider trailer ?? | Steve Koerner | Soaring | 16 | March 27th 07 04:44 AM |
| Avionic trailer wheel needed | qflyer1 | Soaring | 6 | December 7th 06 04:30 PM |
| Q about trailer wheel bearings | Ken Ward | Soaring | 1 | September 15th 06 03:40 AM |
