Connecting my 2 Batteries to 1 Solar Panel
Old January 2nd 13, 07:07 PM posted to rec.aviation.soaring
JS
Default Connecting my 2 Batteries to 1 Solar Panel
ZAP:
The HQRP looks great. I wonder if three conductor cable (for example, commonly available cable reels) can be used with this. Do you know if the charger read 0 Ohms measured between the two battery negative terminals?
On Tuesday, January 1, 2013 6:26:13 PM UTC-8, RAS56 wrote:
I took the easy way out and ordered one of these:
http://www.amazon.com/gp/product/B00...ls_o05_s00_i00
ZAP
Old January 3rd 13, 06:58 AM posted to rec.aviation.soaring
Scott,
First off, I'm a student pilot so I do not post on this forum much because I try to stay silent and learn from you all. That being said, I do have some knowledge with electronics. My initial assumption was that the diodes will act as an rectifier to prevent reverse polarity connections with the batteries. However, the solar cells could become a "load" at night and the situation you present did happen if there were not diodes there to prevent that. However, I have to believe the controller's internal circuits would prevent that from happening. So, I'll admit, my knowledge of the controller is limited. Anyone have some input on this?
Chris,
Old January 4th 13, 05:40 PM posted to rec.aviation.soaring
RAS56 RAS56 is offline
Member
First recorded activity by AviationBanter: Dec 2010
Jim,
I am unsure of the question you are asking me...But all I use is a couple of lengths of 2 conductor cable to each battery. If you can be a little more detailed for this non-electrical engineer type, I am glad to do a little research for you.
Rob
ZAP
Old January 5th 13, 11:12 PM posted to rec.aviation.soaring
JS
Rob metered his charge controller and discovered that the negative terminals on the HQRP Duo Charge Controller are common.
A three conductor cable can be used for two batteries.
Connecting lap top to CAI 302 apsoars Soaring 10 June 8th 11 03:24 PM
Batteries, Solar Panels, Transponders, etc. JS Soaring 7 August 31st 06 09:12 PM
sizing solar panel Udo Rumpf Soaring 18 February 17th 06 01:36 AM
Connecting a GNS 430/530 to a PC PA34 F-GFTF General Aviation 4 September 26th 04 07:09 PM
Connecting a GNS 430/530 to a PC PA34 F-GFTF Aviation Marketplace 7 September 25th 04 04:38 AM
