Garmin GPS 20A with Trig TT22 in Experimental Glider - OK?
Old December 17th 15, 04:56 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Garmin GPS 20A with Trig TT22 in Experimental Glider - OK?
But on an experimental glider, can't one have a non-TSO'd gps engine for a transponder that has ADS-B out? Isn't that what Trig is developing? Why have yet another power drain and another GPS when the modern glider already has one to three GPS's?
On Thursday, December 17, 2015 at 8:31:39 AM UTC-8, Charlie M. (UH & 002 owner/pilot) wrote:
On Thursday, December 17, 2015 at 11:23:00 AM UTC-5, Jonathan St. Cloud wrote:
Why is it that the GPS from Flarm unit cannot be used? That seems perfect as we would get more Flarms in gliders and obviously they are accurate.
I believe because the GPS is not "TSO'd", meaning nobody has spent a ton of money getting it approved.
It may be even better (in performance & features) than an approved unit, it just does not have "the little stamp" that is a FAA blessing.
Along the lines of, "Speed is money, how fast do you want to go?", the FAA version is, "Legal is money, how legal do you want to be?".
I know there is a voltage regulator for our Super Cub that comes from a ~50's vintage Chevy for ~$40, the "FAA approved part" is a few hundred.
But it has the "little stamp".
Old December 17th 15, 05:15 PM posted to rec.aviation.soaring
On Thursday, December 17, 2015 at 11:56:17 AM UTC-5, Jonathan St. Cloud wrote:
My limited understanding is...... "Experimental" means anything goes, just don't try to sue anyone.
Most sailplanes today are certified, thus need TSO'd equipment (meaning, legal for your country)
I'm not well versed on some of this, it's the Internet (thus it may be true), YMMV (Your Mileage May Vary).
Old December 17th 15, 05:46 PM posted to rec.aviation.soaring
Andrew Ainslie
Apparently it can't just be any non TSO'ed GPS to be fully compliant. A few months ago the FAA opened up a new category whereby "equivalent" units could be used in Experimental, and this device of Garmin's is the first to fit this new niche. Hopefully others are following, including Trig. But agreed, it's ridiculous that we can't just use on of the other GPS's floating around our cockpits to give the TT22 the required information. Anything WAAS (hell, actually anything at all) is way better than either radar or nothing at all. Part of the frustration is that without ADS-B we get no input. It would be so nice to know where the power guys with mode C are relative to us.. The FAA definitely needs someone like JC to explain why their strategy of "forcing" us to get ADS-B out in order to get in is deeply flawed, and the requirements to either spend over $3000 or be blind is equally dumb... But that ain't going to happen. In the interim, I'm going to keep hoping that a reasonable solution shows up.
There is an intermediate solution whereby you can hook up a non compliant unit but if you properly declare the signal, I don't think you get ADSB in but I don't recall the exact details. I'd prefer full compliance but I think it might be time to play with that option over winter.
The next problem, of course, is to get a transponder shop to help you get anything done. They are very leery of helping with experimental planes and non TSO'd options. My local guy just told me that he'd no longer do my transponder certification, even though the TT22 is a TSO'd unit and he installed it a year ago - he claims the FAA does not allow him to work on experimental. Sounds like baloney but not much I can do about it if he doesn't want to do the work.
Old December 17th 15, 05:53 PM posted to rec.aviation.soaring
On Thursday, December 17, 2015 at 12:46:45 PM UTC-5, Andrew Ainslie wrote:
Apparently it can't just be any non TSO'ed GPS to be fully compliant. A few months ago the FAA opened up a new category whereby "equivalent" units could be used in Experimental, and this device of Garmin's is the first to fit this new niche. Hopefully others are following, including Trig. But agreed, it's ridiculous that we can't just use on of the other GPS's floating around our cockpits to give the TT22 the required information. Anything WAAS (hell, actually anything at all) is way better than either radar or nothing at all. Part of the frustration is that without ADS-B we get no input. It would be so nice to know where the power guys with mode C are relative to us. The FAA definitely needs someone like JC to explain why their strategy of "forcing" us to get ADS-B out in order to get in is deeply flawed, and the requirements to either spend over $3000 or be blind is equally dumb... But that ain't going to happen. In the interim, I'm going to keep hoping that a reasonable solution shows up.
(In the US, 'Your tax dollars at work', or not, your choice....).
I'm only commenting on my limited knowledge of how some of this works, I also agree some of it "sorta sucks"...... but what do I know....
Old December 17th 15, 08:20 PM posted to rec.aviation.soaring
Richard Pfiffner
I would guess that any GPS that outputs RS232 sentences would work with a TT22.
6.1.9 GPS/TIS Line Speed
If a GPS input or TIS output has been configured, you should select the appropriate line speed using the rotary knob. Traffic displays using the Garmin protocol run at 9600 bps. Panel mount GPS units with Aviation format outputs generally also run at 9600 bps. NMEA GPS units generally run at 4800 bps. Freeflight 1201 and NexNav 3101 GPS receivers generally run at 19200 bps.
Of course only for Experimental.
Richard
www.craggyaero.com.
Old December 17th 15, 10:34 PM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Thu, 17 Dec 2015 09:46:39 -0800 (PST), Andrew Ainslie
much text deleted....
If you have a normal PowerFlarm unit you have a full function ADS-B IN
unit. Any aircraft transmitting ADS-B OUT will show up on the Flarm
display.
From https://flarm.com/products/powerflarm/powerflarm-core/
PowerFLARM Core comes in two variants, PURE and ADS-B. The ADS-B
variant has all the functionality of PURE, but with an additional SSR
(Transponder) and ADS-B receiver. In addition to FLARM equipped
aircraft, you will also be able to see transponder equipped aircraft.
Aircraft without ADS-B Out capability will be shown with approximate
range and altitude difference (Mode-C). Aircraft with ADS-B Out will
be shown identical to FLARM aircraft.
Bob
Old December 18th 15, 12:02 AM posted to rec.aviation.soaring
Darryl Ramm
display.
Bob
Not strictly a completly clear statement. The PowerFLARM documentation should say "1090ES" instead of "ADS-B". They are writing in part for a European audience/bias where they don't have the UAT silliness to deal with. Pf the ADS-B soup in the USA... PowerFLARM only sees 1090ES Out equipped aircraft, does not see UAT Out and will not receive ADS-R or TIS-B services either.
Old December 18th 15, 02:01 AM posted to rec.aviation.soaring
Stephen Damon
There is a 2-33 in West Texas that has a Skyview!
Old December 18th 15, 05:49 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
Gliders are currently exempt from the 2020 ADS-B rules. As a result, you should be able to use a non-compliant GPS source with a Trig21 or Trig22, as long as the Trig is compatible with the GPS's datastream. Even though the GPS source is non-compliant, it will trigger the ADS-B ground stations so that you will get TIS-B and ADS-R transmissions.
This is what the Dynon Skyview systems do today. According to Dynon, this will continue to work after 2020 if you are flying in airspace where ADS-B is not required.
I expect that we will see affordable 2020 compliant GPS sources in the relatively near future. The Dynon units, which are suppose to start shipping by the end of this year, have set a pretty aggressive price point (under $600). While the Dynon module only works with the Skyview system, I was talking to an engineer at Trig a couple of months ago, who told me that they were planning to introduce an affordable compliant GPS source at a similar price point shortly after the Dynon units start shipping.
One thing that you should think about if you want to be fully 2020 compliant is that you buy a Trig21, NOT a Trig22 transponder. The Trig22, while it is ADS-B OUT compatible and will trigger the ADS-B ground stations, is NOT 2020 compliant.
Old December 18th 15, 06:49 AM posted to rec.aviation.soaring
jfitch
Other way around isn't it? Trig 22 has legal power, Trig 21 does not? What happened to all the noise around the FAA survey and a lower cost alternative (forget the name of it)? That is the place to push for Trig21 and Flarm GPS.
Mods to glider = experimental? Bret Soaring 3 June 16th 10 09:29 PM
New Trig TT22 Transponder Paul Remde Soaring 1 January 14th 10 07:27 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Licensing new Experimental glider in USA John Bojack[_2_] Soaring 5 January 2nd 09 01:54 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
