Metric aircraft countersunk machine screws
Old February 3rd 18, 08:51 PM posted to rec.aviation.soaring
Charles Longley
Default Metric aircraft countersunk machine screws
Does anyone have a source for metric aircraft countersunk machine screws? Similar to MS24693S28. They need to be aircraft hardware store screws have the wrong taper on them. This is for Blanik L-23 & L-33’s.
Old February 3rd 18, 09:54 PM posted to rec.aviation.soaring
AS
US-standard countersunk screws have a taper angle of 82degr. or 100 degr. vs. a metric screw having a 90degr. taper angle.
Is there a DIN or ISO standard specified by LET? If so, McMaster Carr carries them but I am not sure how an aircraft standard plays into that.
Uli
'AS'
Old February 3rd 18, 10:43 PM posted to rec.aviation.soaring
Tim Taylor
Last time we ordered some it was from Fastenal.
Old February 3rd 18, 11:36 PM posted to rec.aviation.soaring
Charles Longley
Well it’s not DIN 965. That’s pretty much what you find in a hardware store.
Old February 3rd 18, 11:52 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Find an L-13 that won't be brought back - buy it cheap - lots of good spares. Gear etc like the L-23...
Old February 4th 18, 12:43 AM posted to rec.aviation.soaring
AS
Could they be DIN 7991 or ISO 10642? These are hex-insert type and not Philips screws. Here is an online source for them in grade 10.9:
https://www.fullerfasteners.com/prod...ersunk-socket/
Uli
'AS'
Old February 4th 18, 02:52 AM posted to rec.aviation.soaring
Charles Longley
No they’re philips screw.
Old February 4th 18, 03:41 AM posted to rec.aviation.soaring
AS
Sorry - I should have been more clear: could you substitute the Philips type with the hex-insert type as per DIN 7991 / ISO 10642?
Uli
'AS'
Old February 4th 18, 04:21 AM posted to rec.aviation.soaring
Charles Longley
The head diameter on that screw is too big. I need a 4 mm screw with a head diameter around 6.5 mm. I am not sure what the countersink angle is. Looks closer to 100 though.
Old February 4th 18, 04:44 AM posted to rec.aviation.soaring
AS
If it is not 90degr., then it is not likely to be a metric screw! Just because the Blanik is from Europe doesn't mean that the hardware they used on that glider is metric. My Caproni was made in Italy and it uses all imperial sized hardware.
Uli
'AS'
Fairey Long-range Monoplane pics 2 [4/9] - Like the first machine, it is fitted with a Napier Lion engine. Refinements have been added to this second machine, such as the spats over the undercarriage wheels.jpg (1/1) Miloch Aviation Photos 0 January 6th 18 04:31 PM
Blanik screws? Wade G Soaring 10 March 28th 16 03:03 AM
Metric Aircraft Hardware [email protected] Soaring 2 November 27th 07 06:23 AM
FAA Screws Up Again BushOKDemocratsSTUPID Instrument Flight Rules 2 March 22nd 06 10:39 PM
Metric Aircraft Nuts and Bolts John Scott Soaring 6 December 14th 05 08:54 PM
