Metric aircraft countersunk machine screws
Old February 4th 18, 04:56 AM posted to rec.aviation.soaring
Charles Longley
Default Metric aircraft countersunk machine screws
The empty package says 4 mm and a 4 mm screw from the hardware store screws in perfectly. Sooo I am guessing it’s a 4 mm screw....
Old February 4th 18, 05:21 AM posted to rec.aviation.soaring
AS
Well, in that case, let us know what standard that strange screw is when you find it.
Uli
'AS'
Old February 4th 18, 12:05 PM posted to rec.aviation.soaring
On Saturday, February 3, 2018 at 11:51:27 AM UTC-9, Charles Longley wrote:
Does anyone have a source for metric aircraft countersunk machine screws? Similar to MS24693S28. They need to be aircraft hardware store screws have the wrong taper on them. This is for Blanik L-23 & L-33’s.
'Aircraft Spruce and Specialty' has metric aircraft hardware
Old February 5th 18, 05:11 PM posted to rec.aviation.soaring
john firth
aircraft hardware stores parts is an oxymoron!
JMF
Old February 6th 18, 03:01 AM posted to rec.aviation.soaring
Charles Longley
Yeah I didn’t punctuate that correctly. It should have read- “ They need to be aircraft screws. Hardware store screws have the wrong taper on them.
Old February 6th 18, 06:29 AM posted to rec.aviation.soaring
One example a part number of a countersunk metric screw is 22256BC040010L.
22256 is the type of screw,
BC is the metal type,
040 is the diameter,
010 is the length,
If you google the part, number lots of suppliers come up. If you need a few, contact a helicopter operator that maintains Eurocopter Astar AS350 helicopters. There are thousands in the US, if that is where you are. there may be one close to see what you are getting.
Rob
Old February 6th 18, 04:43 PM posted to rec.aviation.soaring
Wade G
When I had my beloved L33, I tried to track these down with no success. I spent a lot of time hunting and ordering what seemed to be close. Nothing was close. Only source was through Blanik and they were priced somewhere near $20 each from Czech Republic. They were for an inspection panel cover so I decided to go with the wrong taper and negate my OCD.
Old February 6th 18, 05:48 PM posted to rec.aviation.soaring
Bob Kuykendall
When I needed a batch of metric screws with 100-degree countersink, I just sharpened a bunch of hardware store 90-degree screws on my lathe. Took maybe a minute each.
Old February 6th 18, 05:49 PM posted to rec.aviation.soaring
Bob Kuykendall
Link?
Old February 7th 18, 03:50 PM posted to rec.aviation.soaring
Soartech
Link?
http://www.aircraftspruce.com/menus/...inescrews.html
Fairey Long-range Monoplane pics 2 [4/9] - Like the first machine, it is fitted with a Napier Lion engine. Refinements have been added to this second machine, such as the spats over the undercarriage wheels.jpg (1/1) Miloch Aviation Photos 0 January 6th 18 04:31 PM
Blanik screws? Wade G Soaring 10 March 28th 16 03:03 AM
Metric Aircraft Hardware [email protected] Soaring 2 November 27th 07 06:23 AM
FAA Screws Up Again BushOKDemocratsSTUPID Instrument Flight Rules 2 March 22nd 06 10:39 PM
Metric Aircraft Nuts and Bolts John Scott Soaring 6 December 14th 05 08:54 PM
