Emergency Exit
Old June 29th 18, 07:17 PM posted to rec.aviation.soaring
Default Emergency Exit
On Friday, June 29, 2018 at 7:00:07 PM UTC+1, Dave Walsh wrote:
At 16:13 29 June 2018, wrote:
On Wednesday, June 27, 2018 at 5:15:06 PM UTC+1, Dave
Walsh wrote:
Or, of course, you could just fly a DG with their NOAH
system? It seems a pity that more manufacturers do not
offer NOAH given the age of many pilots...
I had one in a DG808C and although I never had cause
to
use it I miss it.
Dave W
Were there any downsides to the NOAH system in day to
day use of the glider
- comfort, thickness of the inflatable bag, space for the gas
cylinder (I
presume there is a cylinder) etc?
John Galloway
No, no downsides to the system in daily use. There is one
extra cable to the pilots seat harness buckle; not really a
problem. There is also the "bag", un-inflated of course,
beneath the seat cushion, again no problem. In use this bag
is inflated by a gas bottle permanently fixed to the airframe
(in the DG it's behind the seat/oxygen bottle). The whole
system just requires the pilot to pull one handle.
There are of course maintenance and inspection costs, I
think the tank and the bag have a 10 year life?
In the unlikely event the pilot activates the system without
jettisoning the canopy the bag deflates. Plenty of detail and
videos on DG's website; just search NOAH.
The DG8800 designs have low cockpit walls. Some gliders
have significantly higher cockpit walls; I'd rate the rear seat
of a DuoDiscus as significantly more difficult to get out of
than a DG800; the front Duo seat is more difficult too.
For the older pilot I think NOAH might be a life saver.
Dave W
Obviously in the case of accidental activation it is good that the Noah airbag deflates rapidly but I I guess that means that if you do activate it in an emergency and for some reason you don't get out of the cockpit immediately then the benefit is lost. Unlikely I know.
Old June 29th 18, 09:16 PM posted to rec.aviation.soaring
Dave Walsh
Dave=20
NOAH=20
not=20
cause=20
to=20
use it I miss it.
Dave W
to=20
gas=20
cylinder (I
John Galloway
one=20
a=20
course,=20
bag=20
airframe=20
whole=20
=20
I=20
=20
without=20
and=20
=20
gliders =20
seat=20
of=20
=20
=20
Dave W
the Noah
air=
activate it
in=
the cockpit
immediat=
Look at the videos on DG's site: you'd be hard put to remain
in the cockpit when the bag inflates!
Dave W
Old June 29th 18, 09:41 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
to
use it I miss it.
Dave W
cylinder (I
John Galloway
Dave W
Why not just install a ballistic recovery chute in the glider? That's a lot cleaner solution and saves your butt at a lot lower altitude than bailing out.
Old June 29th 18, 09:42 PM posted to rec.aviation.soaring
I believe there is also a cable to the canopy jettison lever, you can't "fire the NOAH" until it's armed by dumping the canopy.
Old June 30th 18, 03:27 AM posted to rec.aviation.soaring
Because "just installing" a ballistic recovery chute for a particular airframe takes a very large amount of structural analysis, determination of proper attach points, modification of the fuselage for installation of the rocket extraction system, blow-off panels to allow for chute extraction, actuation cable routing, FAA approvals for certified aircraft or approvals from an IA to determine the feasibility and installation of a system that very few certified aircraft mechanics (IA or A&P) have any familiarity with. This also applies to sailplanes certified as Experimental.
It's not just strapping a pack to your glider. It is WAY more complex and has to be done right.
I started flying hang gliders with a Ballistic Recovery System (BRS) in 1993. I have had two systems from BRS Inc. and one gas propelled unit from (now defunct) Second Chantz. Never had to actually use either one, but I see the advantages for sailplanes. Unfortunately, the mechanics and complex design issues pretty much eliminate practical retrofits to existing airframes.
It is sad that sailplane manufacturers do not seem to be interested in providing the guidance and engineering to incorporate ballistic recovery systems in current designs.
The only glider I know of that has a factory installed BRS system is the TsT-14 Bonus, which operates in the US with a Desert Aerospace installed retractable jet engine capable of self launch and in-flight engine extension and startup. (www.desertaerospace.com)
There may be other sailplanes incorporating ballistic recovery systems, but I have no knowledge of them. If there are others, perhaps RAS participants can offer their input.
Old June 30th 18, 03:40 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
I started flying hang gliders with a Ballistic Recovery System (BRS) in 1993. I have had two systems from BRS Inc. and one gas propelled unit from (now defunct) Second Chantz. Never had to actually use either one, but I see the advantages for sailplanes. Unfortunately, the mechanics and complex design issues pretty much eliminate practical retrofits to existing airframes..
I totally agree that retrofitting a BRS system in a glider is a major undertaking. I am baffled why someone like DG would be screwing around with cockpit extraction systems rather than making a BRS system available for their gliders.
One example of a manufacturer who has their act together is the Phoenix Motorglider. It comes standard with a BRS system.
Old June 30th 18, 05:49 AM posted to rec.aviation.soaring
Charlie Quebec
Beacause floating around out of control under a parachute is safer?
BRS sounds good, but in practice I would prefer a personal chute every time.
Old June 30th 18, 06:01 AM posted to rec.aviation.soaring
Tango Whisky
Schempp-Hirth does offer a BRS for the Ventus.
Old June 30th 18, 06:32 AM posted to rec.aviation.soaring
Mike Schumann[_2_]
If you are in a midair 500 ft above the ground, a BRS will save you. You'd never make it trying to bail out with a personal chute.
Old June 30th 18, 01:51 PM posted to rec.aviation.soaring
Dave Walsh
I have seen no data for the reliability of ballistic recovery
systems in sailplanes (or, indeed, in ULM/Microlights) but the
German data for survivability of conventional parachute bail-
outs from gliders makes very sobering reading.
I'd be very surprised if ballistic recovery chutes didn't turn out
to have a better record than conventional parachutes.
A majority of ULM/Microlights here in France have ballistic
recovery systems; you don't here of malfunctions very often,
but again I have no data.
I know three glider pilots who have had mid-airs, all three
bailed out, only one is still alive.
Dave W
Air exit vent with engine box? [email protected] Soaring 5 December 8th 15 04:14 AM
An elegant exit Frank Whiteley Soaring 2 May 15th 09 02:28 PM
Accident report - PDA's can restrict emergency exit Ramy Soaring 21 December 31st 06 05:45 PM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
