Emergency Exit
Old June 27th 18, 03:39 PM posted to rec.aviation.soaring
Dan Marotta
Default Emergency Exit
Not to change Dave's thread on leaving the Arcus, I was intrigued by
Francois' mention of the slippery cockpit floor in the front cockpit of
the Numbus 4DM.Â* I've noticed that in most single seaters I've flown and
I'm happy to say that my Stemme is fully carpeted to the forward
bulkhead which makes for better traction when climbing out. It still
takes a lot of upper body strength and, at 70 years old, I'm working out
3 days per week to try to keep some of that.
Everyone, please make every exit after a flight a simulated exit. Locate
those jettison handles, but don't actuate them.Â* Raise the canopy
normally and then bail out.Â* Release that belt, rise up, and roll over
the side.Â* You should have enough slack in oxygen and water hoses to not
stretch them.Â* But please practice!
Dan, 5J
Old June 27th 18, 05:14 PM posted to rec.aviation.soaring
Dave Walsh
intrigued by
cockpit of
I've flown and
forward
out. It still
working out
exit. Locate
canopy
roll over
water hoses to not
Dan, 5J
Or, of course, you could just fly a DG with their NOAH
system? It seems a pity that more manufacturers do not
offer NOAH given the age of many pilots...
I had one in a DG808C and although I never had cause to
use it I miss it.
Dave W
Old June 28th 18, 04:40 PM posted to rec.aviation.soaring
kirk.stant
Remember that if you still have an elevator, you may still be able to use negative G to get out of the glider: Jettison canopy, unstrap, the push the stick forward HARD and you should pop right out. If you have time you could even run the trim full forward.. ;^)
Might not work in a spin, but would probably work well in a wind-up hi-speed spiral.
Used a lot during WW2, there is even gun camera film of pilots "popping" out of their cockpits while under attack.
Kirk
Old June 29th 18, 01:49 AM posted to rec.aviation.soaring
Dan,
As you said, "Not to change Dave's thread on leaving the Arcus," On every flight, we have training opportunities.
I like your comment to make "every exit after a flight a simulated exit."
In that light, every release from tow can be a simulated PT3 maneuver.
Raul Boerner
DM
Old June 29th 18, 02:15 AM posted to rec.aviation.soaring
son_of_flubber
First step in PT3 is to push stick forward, then AFTER establishing stable airspeed, initiating a steep turn. People stall-spin on PT3 because they initiate the turn before establishing stable airspeed.
Pushing the stick forward after pulling the tow release, and before initiating the turn, is asking for trouble.
Old June 29th 18, 02:21 AM posted to rec.aviation.soaring
"Pushing the stick forward after pulling the tow release, and before initiating the turn, is asking for trouble."
You just contradicted yourself. What are you suggesting? Pull the stick BACK and then initiate a turn? Put the bong down.
Old June 29th 18, 02:38 PM posted to rec.aviation.soaring
kirk.stant
Huh? If you think of flying as pushing and pulling on the stick (unless doing aerobatics) you are already setup for a problem at some time in the future. Pressure, dude, pressure...
Establishing the appropriate airspeed after a release on tow may require lowering the nose (slow tow behind an Agcat), or raising the nose (the towplane loses his engine and starts going down before you release). Neither response requires any pulling or pushing, just using pressure on the stick to establish the appropriate angle of attack (nose position) to initiate a turn..
Rote responses to emergencies are not always the best solution - even a PTT at 200 ft gives you plenty of time to figure out what to do and do it right - not just blindly shove the controls around!
Next time you get a tow, brief the tow pilot to reduce power at the top of the tow (simulating engine failure), lower his nose to descend at glide speed, then rock you off - it is a LOT different from the usual release during a stabilized climb at normal tow speed. Also a good time to brief and practice open spoilers (at safe altitude) with towplane rudder waggle response..
Plus it's fun!
Kirk
Old June 29th 18, 05:13 PM posted to rec.aviation.soaring
use it I miss it.
Dave W
Were there any downsides to the NOAH system in day to day use of the glider - comfort, thickness of the inflatable bag, space for the gas cylinder (I presume there is a cylinder) etc?
John Galloway
Old June 29th 18, 06:51 PM posted to rec.aviation.soaring
Dave Walsh
to
use it I miss it.
Dave W
cylinder (I
John Galloway
No, no downsides to the system in daily use. There is one
extra cable to the pilots seat harness buckle; not really a
problem. There is also the "bag", un-inflated of course,
beneath the seat cushion, again no problem. In use this bag
is inflated by a gas bottle permanently fixed to the airframe
(in the DG it's behind the seat/oxygen bottle). The whole
system just requires the pilot to pull one handle.
There are of course maintenance and inspection costs, I
think the tank and the bag have a 10 year life?
In the unlikely event the pilot activates the system without
jettisoning the canopy the bag deflates. Plenty of detail and
videos on DG's website; just search NOAH.
The DG8800 designs have low cockpit walls. Some gliders
have significantly higher cockpit walls; I'd rate the rear seat
of a DuoDiscus as significantly more difficult to get out of
than a DG800; the front Duo seat is more difficult too.
For the older pilot I think NOAH might be a life saver.
Dave W
Air exit vent with engine box? [email protected] Soaring 5 December 8th 15 04:14 AM
An elegant exit Frank Whiteley Soaring 2 May 15th 09 02:28 PM
Accident report - PDA's can restrict emergency exit Ramy Soaring 21 December 31st 06 05:45 PM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
