Emergency Exit
Old June 30th 18, 01:53 PM posted to rec.aviation.soaring
Tim Newport-Peace[_5_]
Default Emergency Exit
At 05:32 30 June 2018, Mike Schumann wrote:
On Friday, June 29, 2018 at 11:49:33 PM UTC-5, Charlie Quebec wrote:
Beacause floating around out of control under a parachute is safer?
BRS sounds good, but in practice I would prefer a personal chute every
time.
If you are in a midair 500 ft above the ground, a BRS will save you.
You'd
never make it trying to bail out with a personal chute.
A Personal Chute assumes you are still a going concern. A friend of mine
was hit by a piece of wreckage as he left the aircraft. Had he had a BRS he
would still be with us.
Old June 30th 18, 02:33 PM posted to rec.aviation.soaring
The Genesis-2 was designed for a BRS system, but production was stopped before testing was done. I have installed 36' BRS (1050) systems in a couple of G-2's. Several years back, I came close to a mid-air in the pattern..............I believe a BRS would have offered my only chance of surviving that day, had we hit. Having the little red handle available, gives me a great sense of confidence! At 84, I can hardly climb out of the cockpit, no way wearing a parachute! Add G forces that would be present in a hard-over rudder situation...........? BRS claims their system will work as low as 350'.
Wishing everyone, happy landings,
JJ
Old June 30th 18, 02:50 PM posted to rec.aviation.soaring
Part of why some (me included) feel a static line is good. If you hit the tail after getting out, you may be unconscious (similar to your ship hitting the bottom of another, etc.).
Yes, you may get tangled in the line and it slows/prevents chute deployment.
I believe ours is usually 20' or so, enough to clear the tail. It is in a small coil (enough slack from cabin mount to rip cord of maybe 4') with a single wrap of electrical tape to maintain the coil until needed.
Old June 30th 18, 03:33 PM posted to rec.aviation.soaring
Dan Marotta
To me the major advantages of a BRS over a personal parachute are the
speed and certainty of deployment.Â* Of course either system may fail or
malfunction, but with the BRS, you lose the difficulty of getting out
into space and deploying at in unfavorable position. Simply pull the
handle and enjoy the ride.
But, upon landing in a windy situation, you run the very real risk of
being killed in a tumbling, disintegrating wreck being dragged along the
ground.Â* Is there a jettison capability that could be armed by the
sudden deceleration of landing?Â* Perhaps an automatic jettison?Â* Might
that malfunction at 500' and give you a last thrilling ride?
BRS sounds good, but in practice I would prefer a personal chute every time.
Dan, 5J
Old June 30th 18, 06:50 PM posted to rec.aviation.soaring
Dan, 5J
For several glider types its a choice between an engine or a BRS chute (or neither!)
Old June 30th 18, 07:12 PM posted to rec.aviation.soaring
Paul Agnew
I'm curious about BRS system deployed when the aircraft/glider is spinning. Structural failures or loss of flight controls/wings in a midair could lead to an unrecoverable spin. Would it be better to eject or to hope the BRS won't get tangled by virtue of the rocket pulling the canopy clear of the spinning airframe. I must assume the manufacturers have already considered this.
https://youtu.be/OOl7Zg4Dyi4 Low deployment in a light sport aircraft on a test flight. (Why no emergency parachute for the test pilot?)
Paul A.
Old June 30th 18, 07:34 PM posted to rec.aviation.soaring
Dave Walsh
parachute are the
system may fail or
getting out
pull the
real risk of
dragged along the
by the
jettison?Â* Might
parachute is safer?
time.
Dan, 5J
Of course you could be struck by lightening as you descend
under your BRS canopy but has anyone ever died being
"dragged along the ground" after a successful BRS escape?
Plenty have died following a conventional parachute mal-
function.
The bottom line is that BRS will work at a lower height but is
hardly available in any common sailplane on sale today.
Retro fitting a BRS to an EASA sailplane would be a
expensive, possibly impossible, task. With ultra-light
sailplanes it's different.
The other major problem, as clearly explained on DG's
website, is that "safety does not sell sailplanes". The
majority of DG sailplanes sold were NOT equipped with the
NOAH system: the new buyers simply did not order the
NOAH system. Even if BRS was available today how many
buyers would buy it?
Dave W
  #28
Old June 30th 18, 08:04 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
parachute are the
system may fail or
getting out
pull the
real risk of
dragged along the
by the
jettison?Â* Might
parachute is safer?
time.
Dan, 5J
function.
Dave W
If a BRS system were available factory installed at a reasonable price, I suspect that a very large percentage of buyers would sign up. It's a huge selling point if you are trying to get the OK from your spouse to upgrade to a new glider.
Offering a BRS system standard on all of their airplanes is probably the #1 reason that Cirrus is now the largest piston engine aircraft manufacturer in the world.
  #29
Old July 1st 18, 09:59 PM posted to rec.aviation.soaring
Dave Walsh
personal=20
parachute are the=20
speed and certainty of deployment.=C2=A0 Of course
either=20
system may fail or=20
of=20
getting out=20
Simply=20
pull the=20
very=20
real risk of=20
being=20
dragged along the=20
ground.=C2=A0 Is there a jettison capability that could
be armed=20
by the=20
sudden deceleration of landing?=C2=A0 Perhaps an
automatic=20
jettison?=C2=A0 Might=20
ride?
Beacause floating around out of control under a=20
parachute is safer?
a=20
time.
--=20
Dan, 5J
descend=20
being=20
escape?
function.
but is=20
Retro fitting a BRS to an EASA sailplane would be a=20
expensive, possibly impossible, task. With ultra-light=20
DG's=20
website, is that "safety does not sell sailplanes". The=20
the=20
the=20
many=20
Dave W
reasonable price, I
s=
up. It's a huge
s=
spouse to upgrade
to=
a new glider. =20
probably the
#1=
manufacturer
in the world.
Yes you're probably quite right about the Cirrus BUT in a
Cirrus you might well have wife and kids along for the ride.
The fact remains that the majority of DG customers do not
specify the NOAH system; it's actually relatively cheap
compared to the new cost of a DG808C or DG1000x. Why is
that?
Dave W
  #30
Old July 1st 18, 10:22 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
personal=20
either=20
of=20
getting out=20
Simply=20
pull the=20
very=20
real risk of=20
being=20
be armed=20
by the=20
automatic=20
ride?
parachute is safer?
a=20
time.
--=20
Dan, 5J
descend=20
being=20
escape?
function.
but is=20
DG's=20
the=20
the=20
many=20
Dave W
reasonable price, I
s=
up. It's a huge
s=
spouse to upgrade
to=
a new glider. =20
probably the
#1=
manufacturer
in the world.
that?
Dave W
Maybe people think that the NOAH system is a half baked solution. Cirrus and Phoenix think that BRS systems are important enough that they make them standard and a significant part of their marketing.
Air exit vent with engine box? [email protected] Soaring 5 December 8th 15 04:14 AM
An elegant exit Frank Whiteley Soaring 2 May 15th 09 02:28 PM
Accident report - PDA's can restrict emergency exit Ramy Soaring 21 December 31st 06 05:45 PM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
