Epoxy and Saran wrap question
Old November 25th 18, 02:12 AM posted to rec.aviation.homebuilt
Default Epoxy and Saran wrap question
On Friday, February 3, 1995 at 4:26:02 PM UTC-5, wohlsen wrote:
Thank you to all who responded to my previous query concerning foam core
construction.
I have heard that common epoxies used in composite construction do not adhere to
plastic films such as Saran wrap. Is this correct? If so is it feasible to
employ it as a release agent when building a thin wall, non-structural component
such as a cowling? That is, can I wrap a male plug made of styrofoam with
Saran wrap, lay on the epoxy and glass, smooth and fill to desired finish, and
then pull out the plug and add any internal bracing necessary to maintain its
shape?
Thanks for any comments.
vinyl wrap [email protected] Soaring 14 October 8th 18 05:55 PM
Uvalde wrap-up DRN Soaring 9 August 21st 08 01:27 PM
Tie Wrap on Ventus Fin??? Gary Emerson Soaring 5 March 30th 08 08:18 PM
Question about epoxy resin chemistry.. Chris Home Built 26 April 15th 04 12:55 AM
question: differences between epoxy layup and plaster Morgans Home Built 3 August 6th 03 04:46 AM
