Flarm / Oudie issues
Old July 15th 19, 05:04 PM posted to rec.aviation.soaring
Tim Taylor
Default Flarm / Oudie issues
On Monday, July 15, 2019 at 9:53:44 AM UTC-6, George Haeh wrote:
Latest Oudie update shows IDs.
Current FlarmNet download page:
LXNAV and Naviter
20190715.fln
Copy to RADAR folder
George,
Please post what version of the SeeYou software you are using. I am using 9.15.01 and could not see Flarm ID's last week.
Tim
Old July 15th 19, 06:10 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
LXNAV and Naviter
20190715.fln
George,
Tim
I also can not see Contest IDs. SeeYou PNA9.15.001 20190715.fln
Bench Testing with two PowerFlarm units and Ultimate running SeeYou PNA 9.15.001.
Richard
www.craggyaero.com
Old July 16th 19, 08:03 AM posted to rec.aviation.soaring
Ramy[_2_]
Contest ID not showing is unlikely an issue with the powerflarm but with your display. Since most complaints are about the Oudie I suspect the issue is with the Oudie, or the flarmnet file (wrong format perhaps)?
I don’t have these issues with latest firmwares neither in Xcsoar nor LX9000. The only contest ID not showing is for those which have yet to enter their info on flarmnet (nearly half the pilots apparently find it too challenging).
Reception vary significant between installations, some show up 5 miles while others less than a mile.
If you see someone consistently from more than 5 miles you most likely see their ADSB signal, not flarm signal (the target will look exactly the same in some displays).
Ramy
Old July 16th 19, 04:28 PM posted to rec.aviation.soaring
George Haeh
Running 9.15.001
Settings - Flarm brings up:
Settings - Radar page
Labels Show box is checked.
The IDs were not showing just before the 9.15 upgrade
Old July 16th 19, 05:12 PM posted to rec.aviation.soaring
On Tuesday, July 16, 2019 at 8:28:37 AM UTC-7, George Haeh wrote:
Running 9.15.001
Running v9.15.001
20190715.fln in the Radar Folder of Oudie and PNA
I have on both the Oudie and the SeeYou mobile PNA the settings - Radar Page - Labels Show Box Checked.
Still no Contest ID.
Richard
www.craggyaero.com
Old July 16th 19, 09:41 PM posted to rec.aviation.soaring
Ramy
Any tips on how to record the FLARM IDs seen in flight if the contest ID is not available (missing from FlarmNet data)? It's a hassle to write them down by hand, but they are not recorded in the flight log (except perhaps in the encrypted LFLA lines). I wish my glide computer (Tophat) would let me add the ID seen to the data file with one tap, then I can try and add the contest ID to it later.
Old July 17th 19, 04:51 PM posted to rec.aviation.soaring
George Haeh
I'm using a slightly older.fln file.
My new Core 1.1 is powered by my Air Glide S which is connected to my Oudie with an NMEA adapter.
$PFLAC,S,NMEAOUT1,81
$PFLAC,S,BAUD1,2
$PFLAC,S,NMEAOUT2,81
$PFLAC,S,BAUD2,2
Old July 24th 19, 02:01 PM posted to rec.aviation.soaring
Guys,
thank you very much for this conversation, it helped us pinpoint the problem.
We did have an issue with broken FLN files and when we fixed that we thought that that's "that".
But it turns out that there was another problem with how Power Flarm transmits its ICAO code. We have a new beta version that fixes that. I am very sure that the fix works but it would be incredibly useful if someone who had this problem could test it and report back before we release it:
If you able to test this version please send an email to support at naviter dot com and we'll be glad to give you access to it.
Thanks,
Andrej Kolar
Naviter.com
Running 9.15.001
Running v9.15.001
Richard
www.craggyaero.com
Old July 26th 19, 03:29 PM posted to rec.aviation.soaring
Problem fixed. Thank you Tim Taylor and Richard (Craggy Aero) for confirming this with a live test!
You can download the corrected version he
http://download.naviter.com/oudie_all/UpdateOudie.exe
or wait until after the weekend, when it becomes available through the Naviter Updater.
Along the way, a new feature was added for all those who will participate in the Pan-American championships - Pressing the Pilot Event button will forward this event also to a Flarm / PowerFlarm if connected.
Have a great weekend!
Andrej Kolar
Naviter.com
On Wednesday, July 24, 2019 at 3:01:49 PM UTC+2, wrote:
Guys,
Thanks,
Andrej Kolar
Naviter.com
Running 9.15.001
Running v9.15.001
Richard
www.craggyaero.com
Old July 26th 19, 03:30 PM posted to rec.aviation.soaring
Please read this about adding buddies when they are not present in FlarmNET file:
https://www.naviter.com/2018/06/oudi...-your-buddies/
The article focuses on OGN buddies, but it works just the same with regular Flarm targets.
Regards,
Andrej Kolar
Naviter.com
Ramy
flarm/oudie [email protected] Soaring 3 September 15th 17 02:51 PM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Noise issues with Oudie 2 in a couple different aircraft Doug Mueller Soaring 15 July 25th 14 02:22 PM
Oudie Issues vontresc Soaring 4 July 16th 14 04:44 AM
