flarm/oudie
Old September 15th 17, 01:15 AM posted to rec.aviation.soaring
Default flarm/oudie
Hi
I am in the process of acquiring a flarm.
Today I connected a friend portable flarm to my Oudie 2 to
visualize the result on a oudie screen,
and to evaluate if I need another display.
Not welcome on my small LS6 panel.
The problem; the oudie says it is connected and receiving the signal
but noting appears on the screen.
Advice welcome.
Thank you
Gilles
Old September 15th 17, 01:56 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default flarm/oudie
On Thursday, September 14, 2017 at 5:15:26 PM UTC-7, wrote:
Hi
Advice welcome.
Thank you
Gilles
Giles
Oudie
Menu Settings Radar set to "always"
Range marks and flarm targets should show on the main map screen.
If you Menu setting Radar is set to 2 miles you only see flarm on screen zoom of 2 miles or less. Most fly with a default zoom level on the main screen much higher.
I have PowerFlarm Cores in stock and a variety of antennas.
http://www.craggyaero.com/powerflarm_core1.htm
Richard
www.craggyaero.com
Old September 15th 17, 02:11 AM posted to rec.aviation.soaring
Default flarm/oudie
Le jeudi 14 septembre 2017 20:15:26 UTC-4, a écritÂ*:
Hi
Advice welcome.
Thank you
Gilles
Thank you Richard
A second flarm was on about 20 meters away with range set to 35 km.
I have to check "always"
Gilles
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
flarm flight log download through Oudie? Matt Herron Jr. Soaring 4 January 21st 15 02:28 AM
FLARM-V7-Oudie setup dbrunone Soaring 10 July 9th 13 08:27 PM
