gel coat
Old September 24th 19, 07:14 PM posted to rec.aviation.soaring
Default gel coat
On Tuesday, September 24, 2019 at 1:35:38 PM UTC-4, wrote:
The guy in the cockpit makes up for the craising on the wings.
A couple of wrong decisions by the guy flying the super true laminar perfect winged machine, and a few right decisions by the bondo wing flying guy and they'l be tied lol.
True- BUT- All the points made by good glider preparation are points that don't have to be given back.
From a guy who had two 999 point days this year. One of those made the difference between silver and bronze in nationals.
UH
Old September 24th 19, 07:30 PM posted to rec.aviation.soaring
Default gel coat
Yes, agreed. I just finished working up an article regarding 5 principles necessary to win at low performance racing. The first principle is all about preparation.
But one of the other (and imop) more important factors is making the proper inflight decisions necessary to fly further or faster.
You know that the presence of a single point difference between 1st and 2nd place amounts to about a single false-thermal attempt, or maybe a few degrees of heading difference along an energy line. Its the "Moffat" principle revisited; namely "win by not loosing".
Old September 25th 19, 11:54 PM posted to rec.aviation.soaring
Default gel coat
UH
Ironically, UH oversaw/assisted/provided the skilled work (vs. the grunt sanding work) on the glider that was the 1 point beneficiary of a complete refinish job.
No good deed goes unpunished.
JB
Old September 26th 19, 01:59 PM posted to rec.aviation.soaring
Default gel coat
UH
JB
The reward was seeing one of my best friends in soaring get his best ever nationals finish.
UH
Old September 26th 19, 04:10 PM posted to rec.aviation.soaring
Default gel coat
UH
JB
UH
Thanks, Hank! It was one of the high points of my 50+ years in soaring. Just to reinforce your message, on the last day I made a 20 mile desperation final glide thru mostly sinking air and took a small penalty because I was slightly below the floor of the finish cylinder. IIRC, if I had been 3 feet lower, I would have lost that one point. Sure, there were all kinds of things I could have done earlier in the flight to more than make up for that. But I didn't. At the end of the flight, it came down to one tenth of one percent on that glide. That was my reward for all those hours spent with you pulling templates off my ASW 24 wing, removing the old gel coat carefully, and then building the profile back up the right way. Thanks, again, for your care and attention (and patience!) in that effort.
The above situation is rare. More typically, having that small extra percentage makes it possible to stay with the fleet moving down a fast leg on a blue day vs. slowly being dropped. It's probably not worth worrying about it unless you're flying competitively but it is for me. We're all different. Fortunately, soaring accommodates all of us.
Chip Bearden
JB
Gel coat removal - is this okay?!? Kevin Christner Soaring 13 July 10th 15 03:44 PM
Gel coat inspection Matt Keast[_2_] Soaring 12 October 26th 07 09:14 PM
Gel Coat Question Gary Emerson Soaring 2 September 12th 07 11:56 AM
Gel Coat for Dummies Ray Lovinggood Soaring 12 December 24th 04 01:12 AM
Gel Coat for Dummies Ray Lovinggood Soaring 2 December 12th 04 08:15 PM
