Replace air lines in Discus tail fin?
Old October 8th 19, 08:43 PM posted to rec.aviation.soaring
Default Replace air lines in Discus tail fin?
On Tuesday, October 8, 2019 at 3:11:47 PM UTC-4, Paul wrote:
I'd like to put a TE probe in an unused tail fin pitot socket, but the 30 year old hose leaks. There doesn't appear to be access from the top, with the horizontal stabilizer removed. Does anybody know if the lines can be accessed with the rudder removed?
Plan B is to mount it in the turtle deck, which is easy peasy, but has the slight downside of adding another hole to the ship.
Before you get too crazy in the fin check the part of the tubing that you can get to between the front and the area just behind the wing. More than one tube going through the belly has been found damaged.
UH
Old October 8th 19, 09:10 PM posted to rec.aviation.soaring
Paul[_10_]
Good point, thanks, but that's not the problem. The leak is between the tail fin socket and the air line behind the seat.
Old October 8th 19, 11:21 PM posted to rec.aviation.soaring
John McLaughlin
Sorry to distract from your question, but what is a turtle deck?
Old October 8th 19, 11:42 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Top of the fuselage, generally between wing leading and trailing edges.
Steve Leonard
Tail Wheels & Tail Booms snapp'n db_sonic[_2_] Soaring 0 November 18th 11 08:35 PM
FS - Discus 2b Tail Dolly. Guy Byars Soaring 0 December 18th 06 06:01 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
