On Saturday, October 26, 2019 at 5:39:05 PM UTC-4, Roy B. wrote:
Per Do you use the same machine for sanding the primer that you use to remove the gel coat? ROY We use Porter Cable orbital sander with Mirka 23-388-080 adhesive backed discs for most of the removal. Other grits are sometimes useful. Last work is by hand. Primer/filler is hand shaped. Final finish sand is orbital with finer grit. Contact directly if you want more info. UH |
Gel coat removal - is this okay?!? | Kevin Christner | Soaring | 13 | July 10th 15 03:44 PM |
Gel coat inspection | Matt Keast[_2_] | Soaring | 12 | October 26th 07 09:14 PM |
Gel Coat Question | Gary Emerson | Soaring | 2 | September 12th 07 11:56 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 12 | December 24th 04 01:12 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 2 | December 12th 04 08:15 PM |
